Question about Calvin Klein Watches
K30371 not working - Calvin Klein Watches
Not working . Never worked. Dead battery? Which kind?
You or a jeweler will have to open it up to find out. Replacement of the battery does not guarantee that it will start working if it has never worked.
Dec 26, 2015 | Watches
Eco drive watch not working
Watch is not working had watch in window seal for the whole summer still not working
Feb 24, 2013 | Citizen 8700 BL8000-54L Wrist Watch
My armitron all sport watch works, it's only 1 month old, buttons stopped working. any ideas
try to put a new battery..whether it's only 1 mo old ypu can't tell the watch you bougth has a new battery inside.
Feb 02, 2013 | Armitron Watches
Backlight for my breitling aerospace has stopped working, otherwise watch is working perfectly.
I am in South Korea. My back light has stopped working and I took it to the dealer/service office in Seoul and asked them if they could repair it. Then took it apart and said everything works find, but for the back light, I should just order a whole new analog works...is he just trying to make some money off me?
Oct 15, 2012 | Breitling Aerospace 455 Wrist Watch
My watch stops working, the mechanism works on motion or kinetics. However, even with a bit of a shake it works for a bit then loses time and stops altogether
It may require rather more than a bit of a shake! Some makers say that you have to swing it gently form side to side for 200-300 times to fully wind up the watch.
I bought one some years ago that didn't work well and I had it cleaned, after which it worked perfectly for years.
If giving your watch the shaking I described above it still does not work, try having it cleaned.
Automatic watches thrive on being used but should run for 2-3 days before stopping.
Mar 08, 2011 | Jacques Lemans Classic Automatic...
My watch has stopped keeping time but i can still hear it clicking. The indiglo still works as well so its not the battery. i will change the time and it will work again untill about 30 seconds to 1 minute...
Quartz watches do get gummy or dirty gears and slow down or just quit. I know that I have the cleaning chemicals that generally works to unstick the gears, but I also have the equipment that pulses the watch with enough power to get the mechanism working again. If that doesn't work then it's time to replace the movement with a new one. This is generally cheaper than spending lots of money on the labor to get the old movement working again. Best of luck on this one.
Nov 04, 2009 | Timex Expedition 40141 Wristwatch
Athletic works watch owners manual
if you press both buttons on the right at the same time it might work. Im not sure if it will for ur model, but it worked for mine =)
Aug 17, 2009 | Watches
Light won't work
I suggest you have to check your battery first. It may be underpowered. Replace it with the new one and then check light again.
Dec 19, 2008 | Polar F6 Wrist Watch
Watches Logo
42 people viewed this question
Top Calvin Klein Watches Experts
aravind shet
aravind shet
Joseph Hoffmann
Are you a Calvin Klein Watch Expert? Answer questions, earn points and help others
