Question about Brother HL 5250DN Laser Printer
The printer gives black sheets of paper
After a printer command there comes only a black-tonered sheet of paper out of the printer. From each computer, and also when I make a test print. I trew out the cardridge, but there's nothing to see or a damage. It happens suddenly, after always printing good. The cardridge is rather new, and has made - I think - some hundreds of prints.
  • 55 Answers
Some time cartriage drum get short so fist of all check printout with new cartriage , if problem is net fix then
it is a scaner sction problem of yor printer
may be scaner laser diode is get shot
Posted on Apr 24, 2009
Why is my printer only printing a black sheet of paper?
Hi it is not the toner but it could be a developing unit or transfer roller.
But since on b6500 the developer unit is changed with the toner it is probably the transfer roler or HV unit.
Regards
Apr 10, 2015 | OKI B6500 Led Printer
I have a laser printer 8150n. when i gives 20 print on it. on sheet print after another sheet vacant and third print fourth sheet vacant.. what is the reason
Might be page size mis match> Check paper size in system as well as in printer.> Remove tray &check for paper size.> Clean paper path sensors.
Dec 18, 2011 | HP LaserJet 8150n Printer
Laserjet 4050 - black streaking on right hand side of page
It is either the toner cartridge or the fuser.
Put paper in the manual feed tray.
Print the Configuration Pages.
When the sheet is half way fed into the printer, open the top cover.
Remove the toner and look at the sheet of paper. If you see the black streak, the toner is bad.
If the sheet looks good, the fuser is bad. Probably a bad roller, which you can see looking at the fuser.
Jan 21, 2011 | HP LaserJet 4050 Printer
I have a HP Laserjet 4250 that is printing dirty prints. I have replaced the toner and the fuser unit and cannot correct the problem. I have 2 of these printers and the toner and fuser unit works no...
Try printing from the manual feed tray(tray 1). Put a few sheets of paper in the tray. Print anything that is more than two or three sheets of paper. The paper path test is good, 10 sheets. As the paper gets about halfway into the printer, open the top door. Pull out the toner cartridge. Look down at the paper. If it's dirty it has to be the toner or the transfer roller. If it's clean it could be a dirty paper path or fuser.
Vacuum out the printer, if you have mounds of toner laying in the paper path, everything that comes out of the printer will be dirty.
Aug 02, 2010 | HP LaserJet 4250n Printer
Our copies are streaky like the drum is not clean.... help! There is black streaks on the top of all of our copies on our canon imagerunner 3300.
A) Black Streaks, Shadows, And Ghosting
Adjust the printer's lightness/darkness setting to 2-3 different variables and see if problem disappears. Look at the fusing assembly - is the roller torn or does it have any black buildup? Use caution!!! It gets HOT!
Try another toner also.
Feb 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Printing
The Phaser 7400 starts at $2,799. see models and prices see cost per print Color: up to 36 ppm Black: up to 40 ppm First-page-out time as fast as 12 seconds 800 MHz PowerPC processor Maximum paper size: 12" x 18" All models come standard with 10/100Base-TX Ethernet connectivity Standard paper input capacity: 800 sheets Maximum paper input capacity: 3,000 sheets Finisher/stacker/stapler/hole puncher capable of handling up to 1,000 sheets Maximum duty cycle up to 150,000 pages per month What comes in the box show/hide contents Color toner cartridges (capacity: 9,000 pages each 1 ) Black toner cartridge (capacity: 15,000 pages 1 ) Imaging units (capacity: 30,000 pages per color 2 ) Waste cartridge (capacity: 30,000 pages 2 ) Fuser (capacity: 100,000 pages 2 ) Transfer unit (capacity: 100,000 pages 2 ) Finisher ships with 5,000 staples Power cord Software and documentation.
Aug 13, 2009 | Xerox Phaser 7400/N Printer
What is the difference between a toner and a drum on a BB4400 OKI printer?
The toner is the black powder which the printer uses to turn type and pictures into a printed piece. The drum is the device that actually fuses the image to the paper. Toner cartridges and drums have a service life. Toner cartridges will have say a 3000 sheet capacity. When it is empty you replace it. The drum will have a 10-20,000 sheet capacity. Typically the drum is three to four times more expensive to replace. Many companies will give you a credit for turning them in vs ending up in a landfill.
Good luck.
Aug 04, 2009 | Office Equipment & Supplies
Paper jam on initial feed
It sounds to me like your pickup rollers are worn. You should order a new set and replace them. That should solve your paper jam issue.
Feb 15, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother HL 5250DN Laser Printer Logo
221 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
