Question about Hardware & Accessories
Handleiding legrand 03761 - Hardware & Accessories
How do I program a Legrand 04761 timer?
Generally, the instructions are shown below: you will have to fiddle around to tweak the instructions since this model Legrand is discontinued, and replaced with the 412641
There are 4 programming buttons located on face of timer: menu, on, +, -
Press menu, use +- to scroll down to GCFEIL, Press on, select language
Press menu, use +- to scroll down to set, press on, set current time and date using same basic commands.
Press menu, use +- to scroll down to program, press on, select new, press on, select day-days of operation for program 1, select individual, set On and OFF times for program 1, save
Press menu, use +- to scroll to function, select auto to run programs.
http://waterheatertimer.org/pdf/legrand-412641-D22-manual.pdf
http://waterheatertimer.org/Din-rail-timers-and-manuals.html
Gene
Water Heater Timers Save Money
Mar 02, 2015 | Legrand Hardware & Accessories
Legrand 03700
Check you have 230V power on terminals 1-2.
Reset timer: on bottom row of buttons, push and hold both buttons for a few moment and then release. Then reprogram.
http://waterheatertimer.org/How-to-wire-Legrand-03700-timer.html
Add a comment
May 21, 2013 | Hardware & Accessories
Legrand03740 intstuctions
Legrand 03740 vertical analog timer instruction manual with wiring diagram:
http://waterheatertimer.org/pdf/Legrand-03740-timer-instruction-manual.pdf
Nov 20, 2012 | Hardware & Accessories
How can i set the on and off of my legrand timer switch
You posted under GE timer, but say you have Legrand, and don't include the model number or type of Legrand timer.
1) The only Legrand timer I have in my files is the RT1 countdown timer
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#RT1
http://waterheatertimer.org/images/RT1-timer.jpg
To set RT1, you push one of the buttons, and fan-or-light turns on for a duration of time, then automatically turns off. Use the large button as ordinary light switch.
2) Legrand also makes commercial line of timers, including din rail timers and pin-type timers
http://www.legrandcommercial.com/control_timers.htm
3) If this is not your timer, add a comment and include in-focus photo of your timer for possible identification.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 26, 2011 | GE 60minute Automatic ShutOff Timer Switch...
Ik zoek een handleiding voor de powerbook G3
Je moet in staat zijn om de handleiding voor de macht boek G3 vinden op
http://support.apple.com/nl_NL/manuals/#powerbook Hoop dat dit helpt.
Apr 18, 2011 | Apple PowerBook G3 Mac Notebook
If the legrand dimmer 400w - pro21 can function with led dimmable light "philips master led spot "
The answer is NO. You need a Trailing Edge dimmer to control LEDs.
The Phillips master LED spot manual says
Lighting controls: bulbs are dimmable 20-100% with ""select"" Trailing Edge RC devices
http://www.prismaecat.lighting.philips.com/FredhopperPDFWebServiceInter/docts/1d8ea75f-e889-424d-92dc-450fbeb85f6a/Smart_LED_Spot_da.pdf
The Legrand pro21 manual does not say anything about being a Trailing edge dimmer.
http://www.legrand.com.gr/gr/gr/liblocal/internet_greece/PDFS/NOTICES/IOBL/ROOSTATES/775637EN.pdf
Legrand diagrams show what appears to be incandescent bulbs, and say nothing about LEDs
LEDs cannot be dimmed as ordinary incandescent (tungsten) bulb.
More reading:
Wikipedia article on dimmers includes technical stuff on Trailing edge dimmers
http://en.wikipedia.org/wiki/Dimmer
2 sites show LEDs bulbs that dim:: both seem new ...
http://news.thomasnet.com/fullstory/LED-Bulbs-feature-smooth-dimming-range-566574
http://www.earthled.com/lumiselect-dimmable-led-light-bulbs.html
Oct 11, 2010 | Legrand On-Q/ ALC 600W Dimmer Switch,...
USBkabel en handleiding
Naar het beste van mijn kennis is er geen nederlands handboek nog, maar u **** de usb kabels van ebay.de of ebay.com kopen
Jan 25, 2010 | Dual Electronics CECT P168 Cellular Phone
Handleiding
I found the Handleiding
Thank you
Dec 28, 2009 | Philips DVP 520 DVD Player
Hardware & Accessories Logo
307 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
