My pendrive is not recognized by computer. as the message comes as "USB not recognised" i need your help as i have very important data in it. pls assist me for the same.
  • 22 Answers
Suggest you try a different USB port and possibly a different computer. Didn't say what version of Windows you are using (if windows). Windows Xp is older and may not have the drivers needed to see the device. Go to the vendors web site and see if they have drivers for your product. Helps to include Make and Model number of any product you are asking about to help with solutions.
Posted on Oct 15, 2013
  • 37 Answers
SOURCE: bent lexar secure II usb drive - how to recover data?
I would suggest using a program like data rescue: http://www.datarescue.com/photorescue/index.htm
They have a trial version which you can use to at least tell you if the files are recoverable - to recover the files you will likely have to pay for the product, but at $29 it's probably worth it for your information!
Posted on Jan 08, 2008
  • 1257 Answers
SOURCE: pls help me man
CAUSE loadTOCNode(1, 'cause'); During initialization, devices are reset too soon after they are powered on. In this situation, some devices may use the wrong connector.
Solution:
Power Management system can sometimes cause issues. follow these instructions:
Right-click on My Computer/Properties/Hardware Tab/Device Manager. Now look for the Universal Serial Bus controllers tree....then expand it. You should see a number of USB Root Hub insertions. Right-click one of them/properties/Power Management. Take the check out of the box labeled "Allow the computer to turn off this device to save power".
If you still get "Usb device not recognized" in Windows and the above solution doesn't work for you, there might be other causes:
A) USB device worked before but suddenly stopped working:
The following solution might be applicable:
1) Remove all oem*.inf files
1. Click start and click run then under the run line type in the command “cmd” (without the quotation marks)
2. In the command line, type in the following (without the quotes) and press enter after each command:
“cd \windows\inf”
“ren infcache.1 *.old”
“ren oem*.inf *.old”
“del C:\windows\setupapi.log”
2) Removing all entries under HKEY_LOCAL_MACHINE/Enum/USB that start with VID ==
Removing the VID entries from the registry will cause them to be redetected at restart.
CAUTION: If you have a USB keyboard or mouse, do not remove the VID entry for these devices, otherwise, Windows may not restart correctly.
1. Click Start and click Run. Type regedit and click OK. The Registry Editor window will open.
2. Go to HKEY_LOCAL_MACHINE\System\CurrentControlSet\Enum\USB.
3. Highlight and delete all the VID_…. entries.
Permissions may be set allowing the deletion of the VID_ entries by following the steps below:
a)Right-click the key to be deleted, and then click Permissions. The VID_… Permissions window will open.
b)With Everyone highlighted in the Group or User name section, select Full Control in the Permissions section.
c)Click Apply, and then click OK.
4. Turn off the computer.
Reconnect the USB device to the computer system: ==
1. With the computer system turned off, reconnect the USB hub to the the USB port.
2.Restart the computer.
3.A New Hardware Detected window should open and reload the drivers.
low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not
dilipbagdi
Posted on Apr 26, 2008
  • 11 Answers
SOURCE: DATA INSIDE 32GB KINGSTON PENDRIVE CANT BE RETRIVED
I have worked through this problem. It is a new virus attack. you should get your antivirus updated and then get your drive cleaned. It surely will help you solving your problem.
Posted on Feb 20, 2009
aviral_srms
  • 1216 Answers
SOURCE: kingston 2gb datatraveler malfunctioned
there is absolutely no problem in your pc .
your pen drive is faulty.
Posted on Feb 14, 2010
  • 110 Answers
SOURCE: when i try to use
Don't be panic. you can try this power data recovery software. download the file recovery software from
http://www.asoftech.com/data-recovery-software-download.html
It tells the steps how to perform data recovery.
If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
Posted on Oct 23, 2012
My toshiba 8 gb pendrive is not recognised by desktop,
does this pendrive work on other computers if it does then use a different usb port if it wont replace pendrive
Aug 01, 2014 | Microtoolz PenDrive Autorun
My pendrive (d33193) gets heated up & it is not detecting now. I have important data on that pendrive.How i can recover the data? Pls help me.
No solution, it is damaged now due to high voltage current which it could not handle. Flash drives are easily damaged by such problems. All data gone, bye bye.
Dec 01, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to Repair my 4 GB Malfunctioning USB Pendrive ? Windows is not recognizing it .. :\
try it on another machine....else u need to download an application called KILLDISK (windows version) from google and use that to kill the USB pendrive...then format it...
warning...this operation will wipe ur pendrive.,..so be ready to loose all data in that....
pls revert back and kindly leave a feedback and rating for this solution....it will help me become a "Guru" here...from Master...
regards...
Sep 29, 2010 | Transcend (589307) Media
My transcend pen drive didn't blinks...?
the connector that is build into the pen may be broken, if i were you i'd send pendrive to onrack recovery company, as home-way-fixing may corrupt data on pendrive
Sep 22, 2009 | Transcend (589307) Media
Not able to format imation pendrive
use a computer with XP OS.
right click 'my computer'
select 'manage'
then select 'disk management' to format ur memory stick. but sad to say, all data will be lost
Aug 06, 2009 | Transcend (589307) Media
HDS72505 0KLAT80 USB Device recognised by Vista but the two partitions/drives are said to be unknown devices Any help?
Make SURE you dont' have any data on the drive that is important (or you have a good back up) Click "COmputers" and "manage" you will need to initialize the drive for VIsta to recognize it.
Jun 24, 2009 | Hitachi Deskstar 7K500 500 GB Hard Drive
Error Message re: KIngston 2G Pendrive
since the device uses usb power there is no way that you might be able to retrive data if the computer wants to format it.
Dec 10, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Pendrive not recognised
So your saying its not recognized on the same computer it used to be recognized on?
What have you resantly installed?
Oct 11, 2008 | Electronics - Others
Sandisk 4GB pendirve not recognised by PC - Driver issue?
Dear Friend,
I have problem in my pen drive which which built by SAN Disk its storage capacity in 4 GB i am using winxp but this pendrive is not recognize by OS pls solve my problem
Thanks
Aug 09, 2008 | SanDisk ULTRA II 4GB Compact Flash Card...
Msg while start up
Yes, you can recovery it. There is a lot of recovery program available on the web, most of it is need to pay. You can try using below free recovery tool to recover your data.
http://www.freewarefiles.com/Pandora-Recovery_program_30715.html
http://www.freewarefiles.com/MediaDoctor_program_38001.html
Jul 23, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
