Question about Activision Empires: Dawn of the Modern World for Windows
Windowed mode - Activision Empires: Dawn of the Modern World for Windows
Bought a Fugitsu T4020D with a broken screen at a yard sale. Fixed the screen but it is password locked at BIOS, and before Windows loads. How can I unlock the BIOS to get into this thing?
1. Bypass Windows 7 Logon Password with Command Prompt While computer couldn't boot normally or notebook is infected with Trojans or malware, you can get rid of them by starting computer in Windows Safe Mode. Furthermore, when lost or forgot Windows password, you can also bypass Windows 7 logon password easily in Safe Mode.
In Windows 7, there are 3 different types of safe modes to choose, Safe Mode, Safe Mode with Networking and Safe Mode with Command Prompt. And the following guide is about how to bypass Windows login password with Command Prompt in Safe Mode. With net user command in Windows safe mode, you can reset Windows password effectively. Details as follows:
Step 1: Start or restart your Windows 7 computer.
Step 2: Press F8 to enter Advanced Boot Options before the Windows 7 loading screen appears.
Step 3: Choose Safe Mode with Command Prompt in the coming screen, and then press Enter.
Step 4: Wait for Windows 7 files loading until Windows login screen comes up.
Step 5: Log in Windows with an administrator account until you see login screen.
Step 6: A Command Prompt appears. Type net user in the Command Prompt and then hit Enter. All Windows user accounts will be listed for you.
Step 7: Type net user iSunshare 12345 and hit Enter.
Note: "iSunshare" is your locked Windows user account name. And "12345" means the new password you want to reset for the locked account. User account "iSunshare" will be reset with new password "12345".
Step 8: The new password has been successfully reset for user when the command is completed successfully.
Step 9: Login Windows 7 PC with the new password.
Whenever you need to access Windows in Safe Mode, an administrator account password is necessary. So it is highly recommended that write down Windows password and store it or creating a Windows password recovery disk before Windows password lost.
May 11, 2016 | Computers & Internet
Tip
How to Turn Off Safe Mode on Windows Vista
The Safe Mode is used to detect the technical and software problems in windows Vista. This is an effecting way to diagnosing the problem, that's why most of the technicians prefer this way to resolve the problem. But Safe Mode disables the most of the advance functionality of your computer. So use the Safe Mode only for diagnosing the problem and as you diagnose and repair the problem get back your windows to normal mode. <br /><br />For reverting back to normal mode at windows Vista, an option occurred which has to be select within limited time and if you select the Normal Mode option within this limited time, your windows will revert back successfully but if you waste the time, you have to restart your computer again for getting this option. You can select the Normal Mode option through arrow keys or by pressing the number at which the Normal Mode will appear.<br /><br />Sometime your computer does not display the Mode Selection Menu. This is not a problem you can get this menu and revert back your windows Vista into Normal Mode through the following instructions.<br /><br />Instructions<br />If you want to revert your Windows Vista into Normal Mode from the Safe mode but your system is not giving you option to select the mode, follow the given instructions: <br /><br />Restart Your Computer: To restart the computer you need to take the following step:<br />- Click on "Start" button at the left side of Task Bar. In Safe Mode of windows Vista the Start button appears at the same place where it appears in the Normal mode. Select "Turn Off Computer" from the Start Menu. Then, Select 'Restart" from the pop-up menu.<br />When your computer has been shut down place your finger at F8 key. As your computer starts to boot computer devices for restarting your computer, press F8 key again and again unless a menu appears on the screen. This menu is Mode Selection Menu.<br /><br />Note: If your computer won't give you Mode Selection Menu at the screen that's means you have lost the time of getting option. In this condition restart your computer again and again, and then press F8. <br /><br />When you get Mode Selection Menu on your computer screen, stop pressing F8 key. Now choose the Normal Mode from the list by the following method:<br />- You can select the Normal Mode by pressing the number on which Normal Mode appears in the list.<br />- You can select the Normal Mode manually through the Arrow Keys. Press the down key to reach at the Normal Mode option in the list and press Enter. <br /><br />Then wait for a while to reboot your Windows Vista in Normal Mode. <br />This is the method of changing Mode in windows Vista. You can follow these instructions at any time to revert your windows Mode.
on Jun 24, 2011 | Computers & Internet
Tip
Windows Virtual PC & Windows XP Mode Resources for Windows 7 These are some of...
Windows Virtual PC & Windows XP Mode Resources for Windows 7 These are some of the resources for IT Professionals for deploying Windows Virtual PC and Windows XP Mode in the corporate environment. This new desktop virtualization platform enhances the overall business productivity for the corporations by leveraging the Application Compatibility with the help of XP MODE delivering easier migration to the newer version of Windows operating environment. Installation instructions and Release Notes for Windows Virtual PC and Windows XP Mode Windows Virtual PC is the latest Microsoft virtualization technology. You can use it to run more than one operating system at the same time on one computer, and to run many productivity applications on a virtual Windows environment, with a single click, directly from a computer running Windows 7.
For more information about Windows Virtual PC, please visit the Windows Virtual PC website.
The Setup and Install instructions document describes how to install and setup Windows Virtual PC and Windows XP Mode. You should familiarize yourself with all of the information especially if you are upgrading from the Windows Virtual PC and Windows XP Mode Beta or Release Candidate builds.
The Release notes provide important information you should know prior to installing and using Windows Virtual PC, including known issues. You should familiarize yourself with all of the information prior to installing the software.
DOWNLOAD HERE
Deploying Windows XP Mode This document and files provides the guidance and scripts necessary to deploy Windows XP Mode in a corporate environment.
DOWNLOAD HERE
Windows XP Mode IT Pro Deployment Video This video highlights the many features of Windows Virtual PC and Windows XP mode and provides guidance on deploying in a corporate environment.
DOWNLOAD HERE
on Jan 10, 2010 | Computers & Internet
Window7 scanjet4300c
I am assuming you used this in windows xp if so
How does Windows XP Mode work?
Windows XP Mode works in two ways-both as a virtual operating system and as a way to open programs within Windows 7. It runs in a separate window on the Windows 7 desktop, much like a program, except it's a fully-functional, fully-licensed version of Windows XP. In Windows XP Mode, you can access your physical computer's CD/DVD drive, install programs, save files, and perform other tasks as if you were using a computer running Windows XP.
When you install a program in Windows XP Mode, the program appears in both the Windows XP Mode list of programs and in the Windows 7 list of programs, so you can open the program directly from Windows 7.
Nov 28, 2014 | Office Equipment & Supplies
I'm forgot my password to login
If you are not able to boot your computer in normal mode or supposed your notebook is infected with Trojans or malware, you are able to get rid of them with Safe Mode. Furthermore, it is easier and safer to bypass Windows 7 logon password in Safe Mode when lost or forgot Windows password.
For Windows 7, there are 3 different types of safe mode, Safe Mode, Safe Mode with Networking and Safe Mode with Command Prompt. The following guide is about how to bypass Windows login password with Safe Mode with Command Prompt. With command in safe mode, you can reset Windows password. Details are as follow:
Step 4: Wait for Windows 7 files to load until Windows login screen comes up.
Step 5: Log in with an administrator account until you see login screen.
Step 7: Type "net user iSunshare 12345" and hit Enter.
reset-windows-password-with-cmd.png Step 8: The new password has been successfully reset when the command is completed successfully.
Step 9: Log on your PC with the new password.
Aug 21, 2014 | Computers & Internet
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
My notebook will not powerup
Try tapping F8 from a cold start and see if you can start windows in safe-mode. If it is a Windows machine. Please advise if your machine does not use Windows or what happens, as to whether the system starts in safe-mode.
Here is a guide on how to start a Windows computer in safe-mode:
http://windows.microsoft.com/en-gb/windows/start-computer-safe-mode#start-computer-safe-mode=windows-vista
Jan 29, 2014 | Computers & Internet
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Microsoft Windows Vista and Windows 7 users
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
Can i install windows-xp on my laptop which is currently working on windows-7 and use both of them.
Yes you can install windows xp in windows 7.
Windows XP Mode is a virtual PC image of Windows XP Service Pack 3 that could be run on Windows 7 Professional, Enterprise or Ultimate versions. Applications installed into Windows XP Mode could be run in Desktop Mode or Seamless Mode. In Seamless Mode, applications appear to run natively within Windows 7, but they are actually running inside the Windows XP virtual machine. Windows XP Mode might also provide additional integration that traditional Virtual PC images might not be giving. Applications installed on the Windows XP image could be exposed to the Windows 7 Start menu. Applications run in seamless mode is having automatic access to the Windows 7 known folders like Documents, Pictures, Desktop, Music, etc. Also the Cut-and-paste is enabled between native Windows 7 applications and those running in Windows XP Mode. Applications running in Windows XP Mode might also access your Windows 7 network connection and USB devices.
Nov 30, 2010 | Computers & Internet
How do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Computers & Internet
Activision Empires: Dawn of the Modern World for Windows Logo
88 people viewed this question
Top Activision Video Game Consoles & Games Experts
Zhenya Ogorodnikov
James Wishart
ray gallant
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
