Question about Kodak EasyShare V550 Digital Camera
V550 lens cover does not open when camera is turned on
My Kodak v550 seems to be working ok but when I turn it on in the picture taking mode the lens extends out but the cover does not open. I can open the manually open the cover with a toothpick or another small object and I can see the target in the LCD but the lens cover will not open automatically and stays in the closed position all the time.
t00nz
  • 4738 Answers
SOURCE: Kodak DX6340 Lens Cover Does Not Open
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Posted on Nov 25, 2007
SOURCE: Kodak DX7440 Lens Cover does not open or close properly
It is a common, but in most cases intermittent problem with many cameras regardless of brand/model. I also own Kodak DX7440 since late 2004, and I had this problem twice, in 2007 and 2008. First suggestion: fully recharge the battery, it helped me the first time. Second: play with the lens cover, that is try to open/close it with the camera on/off. With me, in 5 min of these attempts, it suddenly fixed itself and stays this way for one month now. Another suggestion: dont use a toothpick, since it can scratch the lens. Use a q-tip, and to avoid cotton threads sticking to lens, wet the q-tip and let it dry.
Posted on Apr 22, 2008
SOURCE: Kodak z730 lens
Ok found out my particular fix...
Had to recharge battery 2 times in a row, no idea why this worked.
Camera now operating as usual.
Posted on Jul 06, 2008
SOURCE: Kodak v550 digital camera
THANKS!! I thought my camera was gone for! This worked for me!
Christie
Posted on Sep 01, 2008
  • 11967 Answers
SOURCE: M883 Kodak camera won't stay on. Lens is frozen in
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 15, 2009
Screen and view finder not showing anything
Just covering the bases...
Make sure the lens cap is removed
Turn the ON/OFF switch to Favorite mode
Press EVF/LCD does it toggle
Look to see if the battery level ICON shows better then half
Battery combination sometimes will show a strong icon level
It may be strong in the other modes which draws less power then the picture taking mode.
My guess would be New Battery replacement.
Some tests were done that may be of value to your solution
http://reviews.cnet.com/digital-cameras/kodak-easyshare-z740/4505-6501_7-31294317.html
Jun 13, 2010 | Kodak EasyShare Z740 Digital Camera
Battery won't charge on Kodak Easyshare V550
I don't think its the battery. My just did this this week..If I slide the Favorites switch up (switch by hand strap mounting hole) I can view the pictures in it, but it won't use in photo mode, Lens won't extend, and it shuts off?
Jul 08, 2008 | Kodak EasyShare V550 Digital Camera
Kodak z730 lens
Jun 29, 2008 | Kodak EasyShare Z730 Digital Camera
Regina's camera
Hey Regina I had the exact same problem.. Update the V550 firmware via kodak's website and follow the instructions. Hope that helps!! let me know!
Mar 31, 2008 | Kodak EasyShare V550 Digital Camera
Kodak V550 EasyShare
hmm, that happened to me too when the battery was dead. try recharging your camera. make sure it is sitting on the charging dock right. make sure the charger is plugged in and it's working. see if the battery was put in correctly. if none of this helps, try a different battery, maybe the one you bought is no good. who knows what shelflife is on those
Mar 08, 2008 | Kodak EasyShare V550 Digital Camera
Kodak Easy Share V550
mine fell in water and now the lens retracted and won't shut and i have error #45lol
try charging your camera, if it hasn't been broken from the fall, hope it had a soft landing!
Feb 25, 2008 | Kodak EasyShare V550 Digital Camera
Kodak V550 Camera Problems
Sounds like a new battery would do wonders. I would contact Kodak and see if hey will offer you a new battery. If not then I would go buy one. The battery is probably the most likely to go bad so fast on a camera.
Aug 23, 2007 | Kodak EasyShare V550 Digital Camera
Lens Problem
my camera is also doing this and i need help the lens comes out and straight back in also i lost my manual on kodak easyshare v550 amd cant get my camera to work at all i brought a new battery and it makes no difference please help.
Nov 06, 2006 | Kodak EasyShare V550 Digital Camera
Camera Won't Stay On
hi change the battries good luck
Apr 16, 2006 | Kodak EasyShare V550 Digital Camera
Kodak EasyShare V550 Digital Camera Logo
61 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
