Canon ir 1650 e000 - Office Equipment & Supplies
  • 10 Answers
SOURCE: copier canon ir 1600
CHANGE THE FIXING UNIT.
Posted on Nov 06, 2007
  • 121 Answers
SOURCE: Canon IR 1600 Error message E000
You'll need to replace the fuser unit. Not exactly the cheapest part of the machine...
Unless, that it, you were taking things apart and happened to unplug something accidentally. If you take the cover off where the paper comes out, look at the connectors directly inside there under the black piece of paper that you'll see. If one of those are pulled out, it could cause the problem.
Otherwise you need to replace the fuser unit.
Erice
Posted on Nov 23, 2007
SOURCE: How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
Posted on Jul 12, 2008
  • 18 Answers
SOURCE: ir 2000, system error E000
The main thermistor reading does not reach 40°C 14 sec after the fixing
heater goes ON. (fixing low temperature error)
If E000 is indicated, the RAM on the image processor will
retain the error memory of the fixing assembly after the power switch has
been turned off an then on. Execute the following in service mode, and
turn off and then on the power switch to clear the memory: #7
PRINTER>#4 PRINTER RESET>YES=(*).
Entering service mode: press "aditional function" and after "#(ID)"
Posted on Jul 16, 2008
SOURCE: Canon IR 1600 error message
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
Posted on Jan 12, 2009
Error E000
E000: FIXING UNIT PROBLEM
replace or repair the fuser unit:
The fixing temperature is very low:
• The thermistor has poor contact or an open circuit.
• The fixing heater has an open circuit.
• The thermal switch has an open circuit.
Jun 17, 2015 | Canon Office Equipment & Supplies
Canon iR 2022 gives a system error E000 and error E003, what could be a problem?
how to clear error code e000 please help me copier ir 2022 show me how to clear
May 19, 2011 | Office Equipment & Supplies
Canon IR 2016
Additional Functions>2 key>8 key>Additional Functions (each key is pressed seperately, unlike regular iR copiers) Go to Copier>Functions>Clear> Err_ or Err_Clr. An E000 is a fuser code.
Aug 29, 2008 | Office Equipment & Supplies
Ir 2000, system error E000
Jul 16, 2008 | Canon ImageRunner 1600 Copier
Jul 11, 2008 | Canon Office Equipment & Supplies
Copier canon ir 1600
Problem with fixing Unit, simple simulation will help. otherwise need to change fixing unit,, contact ur service engineer
Nov 03, 2007 | Canon imageCLASS D860 All-In-One Laser...
22 people viewed this question
jasbo
jasbo
