Question about Electronics - Others
How long should it take to charge my iPhone using a solar charger?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 5 Answers
Solar chargers imply you could hold your USB devices complete of juice, without having to rely on a mains power supply, or maybe a battery ?C while utilizing a sustainable supply of power. A brand new wave of chargers has come onto the marketplace. Some are ultra-portable, pocket-sized choices, even though other individuals are larger, more powerful set-ups that you could take on camping trips or anywhere where mains electricity is tough to come by.When you are in search of the appropriate solar charger, look at what you??re charging with it. An iPhone can charge twice the speed as a Samsung Galaxy, one example is, so owners with the latter would wish to look at a charger using a higher, quicker Wh output. By far the most straightforward way to examine them can be a ratio of energy to smartphone battery life, or Wh output. Around 10Wh is sufficient for a slower charge (as an example, 12 watts requires 1 hour and 50 minutes to charge an iPhone 6), although 40-50Wh is usually a super-quick power-up. Using the solar chargers, genuine sunlight is required. Nevertheless it does not matter if it is overcast - it is the UV rays which give the chargers life.
Here I introduce one for you that I love :https://www.amazon.com/dp/B01MTNOS2R, hope you like it.
Posted on Nov 18, 2016
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 24 Answers
Charging should take the same amount of time as it would charging from the wall or depending on the output power of the charger. solar chargers aren't really designed for charging from 0 to 100% they're made for topping up your battery when you're running low.
Posted on Oct 14, 2013
How long does it take to charge battery in solar fence charger?
    1. A solar powered electric fence energizer usually contains a battery for energy storage. The solar panel collects the energy from the sun and charges the battery. Lead acid batteries, which are used in solar fence chargers, typically last around 3 years, or around 1,000 days of charging.
      About Fence Chargers - Zareba Systems
      www.zarebasystems.com/learning-center/all-about/fence-chargers
    Feedback
  1. About Fence Chargers - Zareba Systems
    A solar powered electric fence energizer usually contains a battery for energy storage. The solar panel collects the energy from the sun and charges the battery. Lead acid batteries, which are used in solar fence chargers, typically last around 3 years, or around 1,000 days of charging.‎What can I do to prevent ... - ‎What factors should I consider ...
    [PDF]Fence Controller Installation - Zareba Systems
Jan 01, 2016 | Cars & Trucks
How do i convert my 1.2kw solar inverter on my roof so i can run my home on stored energy ?
Solar panels produce DC voltage.
some solar panels have the inverter integrated into each solar panel.
I would suggest contacting a local solar panel supplier and asking them if they could add a Battery Charging System to the Solar panels you use. An then what sort of inverter to add to the bank of batteries.
An inverter converts DC voltage to AC voltage to use in the grid.
The AC voltages and DC voltages involved have the possiblity to kill if you much around with electricity.
Jan 15, 2015 | Inverter Electronics - Others
Bell + Howell Solar portable keychain Charger
http://maskelena.org/maskelena-solar-charger-solar-power-bank-12000mah/ Here is what you want~
Jun 04, 2014 | As Seen On TV Bell Howell Solar Charger...
Unit does not light up
Check the input voltage terminals for power from your array. if there is no power at the input terminals, remove the wires from the controller and check for voltage again on the input wires. If there is still nothing, trace them back and keep checking each connection all the way to the panels. May be a bad connection or wiring. If you have input to the controller, it is being grounded for some reason or the circuit is open. Look for a fuse or reset on the controller. The controller its self may be bad.
Dec 22, 2013 | Morningstar ProStar PS-15M-48V, 15 Amp 48...
Are solar chargers heavier than regular chargers?
Naturally due to the size of solar chargers they are going to be a little heavier than a regular charger, but keep in mind that solar chargers are able to charge you device so long as the sun is up.
Oct 14, 2013 | Electronics - Others
Can I charge my HP 632 (that has rechargeable batteries in it; from the USB hooked to a solar charger?
You may recharge the batteries using any compatible charger. It doesn't matter to the camera whether the charger is powered by a nuclear reactor or a hamster running in a wheel. Bear in mind that the HP M632 is NOT a battery charger. The batteries must be recharged outside the camera.
Dec 12, 2012 | HP Photosmart M632 Digital Camera
KA500 ip will not charge iPhone 5
The BEST Great watch.Easy to work around bezel concerns Great watch,easy to use.The production GARMIN forerunner running watch fitness is HOT THE Garmin Forerunner Heart Rate MonitorYou can view and order THE BEST products at this.
Dec 12, 2012 | Kaito Voyager KA500IP Solar/Dynamo...
CHARGING FAULT
hi friend,
step 1
Make sure you have all of the accessories. Some phones need special adapters for charging. If you're having problems fitting the charger into your cigarette lighter socket, check with your cell phone company. You may need an adapter ring.
  • Step 2 Find the right battery. Certain phones can only be used with batteries from the same company. If you are using a counterfeit battery, be aware that you may not be able to charge it with your current set up.
  • Step 3 Read the manual. Something as simple as charging a battery may take specific instructions. For example, some cell batteries need to be charged immediately while others come fully charged.
  • Step 4 Use your charger. Most cell phone chargers are easy to use plugging right into your phone and home outlet or car electrical cigarette socket. Read your manual on specific steps needed for charging your phone.
  • Step 5 Try Cellboosts. These convenient devices are disposable battery packs that plug into your phone, charging it when the charger isn't accessible. Cellboosts usually last for an hour and are not compatible with all cell phones.
  • Step 6 Go solar. This innovation allows you to charge your phone wherever there is light. Just attach your cell to a portable adapter and let the light do the rest
  • hope this helps u
    please rate me..........................
    thank u for using fixya
    regards
    sivaranjini
    Nov 26, 2009 | Televison & Video
    Electronics - Others Logo
    478 people viewed this question
    Top Electronics - Others Experts
    Are you an Electronics - Other Expert? Answer questions, earn points and help others
