Question about Denon AVR-1802 Receiver
How to turn off standby light on denon av1802 receiver
  • 163 Answers
You can not do this. this option is no available.
Posted on Oct 14, 2013
3 Suggested Answers
simplemitch
  • 752 Answers
SOURCE: Denon AVR-4800 5.1Channel Standby light blinking
It's going into protect. Unhook ALL the speakers and see if it still shuts itself off. If so, then it will have to be taken in for service.
Posted on Oct 27, 2007
  • 5 Answers
SOURCE: Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Posted on Mar 09, 2010
How to reset denon s 301receiver?
Instructions
  1. How to Reset Denon Receivers
    • 1 Save the information currently stored in your Denon receiver, such as device commands and multi-zone controls. Some Denon receivers can control multiple rooms and each room needs to be setup properly to provide the correct controls. If the receiver was installed professionally it may be best to contact the installer before resetting the device.
    • 2 Press the "Power" button or the "On/ Standby" button to shut off the receiver. On some receivers it is best to press the button on the device instead of the remote as the remote will normally put the receiver in standby mode. Ensure the display and all other lights on the device are off. Do not unplug the Denon receiver as it will not reset.
    • 3 Press the "Power" button and at the same time press two buttons on the front panel, which are determined by the model Denon you own. Most receivers identify the two buttons inside the user's manual, while some older Denon receivers require you contact Denon for the right button combination. For example, some Denon models require the "Standard" and "DSP Simulation" buttons to be pressed simultaneously.
    • 4 The display will start flashing at about one second intervals. Release the two buttons. Turn on the receiver by pressing the "Power" or the "On/ Standby" button to verify the previous settings and saved radio stations have been erased. If the interface does not flash, the reset was not complete and needs to be re-done. Re-enter the previous settings to ensure there are no further issues with the receiver.
Sep 09, 2014 | Toshiba DVR40 Multi System DVD Recorder...
Blinking standby light on Denon
could be a couple things. Either a blown channel in the amp, or a bad voltage regulator. would have to investigate further with a meter to find out.
Aug 27, 2014 | Denon AVR-1601 Receiver
Does not turn on
If there is no reaction at all on standby button, the receiver most likely has a problem with standby power supply or mcu. If you get flashing red standby light, there is a problem with one of the channels or main power supply. Either case you need to bring it to a reoair facility.
Dec 10, 2011 | Denon AVR-1803 Receiver
My Denon AVR-75 seems to stay in standby (red standby light is on) and I don'd get surround sound through it. How do I get it out of standby?
if the receiver does not power on from standby there is a problem like bad power supply or even bad macroprocessor. You need to bring it to a service center for diagnosing. 10-years old receiver, maybe better to buy new one.
Nov 23, 2011 | Denon AVR-75
Aug 20, 2009 | Denon AVR-1908
My Denon AVR5800 Receiver Shut itself off after I turned it on?
This amp is going into protect mode as it is sensing an internal overload,needs to be repaired...
Jan 08, 2009 | Denon AVR-5800 Receiver
Turns off after 4 secs or so....From Green to Red,
Receiver turns on Green but on pressing button again for red light standby, red light will not come on for this Denon receiver. Recently light came on saying Panel Lock is on. I was not able to get tuner to work.
Aug 25, 2008 | Denon AVR-1905 Receiver
Standby light on and system not working
OK either a channel has blown or it has the Denon Curse. At the factory, denon installed some surge protecting resistors in the power supply. They are a little too small and well after warranty expires, one day, while playing music, or just turning it on, the resistors open up and the unit stays in protection mode. Denons were FAMOUS (or infanous) for this problem. I have repaired DOZENS of them. Take it to a denon repair shop as I GUARANTEE they have seen this before. Don't try ro repair this yourself as to get at the 4 resistors you have to disassemble the ENTIRE unit. Good luck....Rob
Apr 18, 2008 | Denon AVR-1602 Receiver
Oct 27, 2007 | Denon AVR-4800 Receiver
Denon AVR-1802 Receiver Logo
94 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
