Fax l100 canon error code 0048
Can't receive fax, show error 0048.
SOURCE: CANON FAX L100 COMES UP MEMORY FULL
We had the same memory full problem. Just unplug the main switch and it will automatically reset the printer and you will be able to send and receive faxes after.
Posted on Feb 20, 2008
  • 64 Answers
SOURCE: Canon Fax L100 - toner required even though not empty
hi
first do use the original toner if no use the original toner if yes check the toner cartridge may could be brocken ore the toner jammed on it if its ok you have to check the toner sensor that located in side the fax m/c under the toner cartridge may its came out of position .
thanks
Posted on May 21, 2008
  • 385 Answers
SOURCE: Problems sending faxes with B820
make sure it says doc ready before pressing start!
Posted on Apr 01, 2010
canontech
  • 1219 Answers
SOURCE: Canon Fax L100 has Comm Error. Seems to re-appear
evry time press red button to clear it. It means that there are interferences in send or recive. Check your tel. lines.
Posted on Jun 14, 2010
canontech
  • 1219 Answers
SOURCE: Canon L100 fax receives messages but doesn't print them
Try to clear the fax, with Menu and #, then clear, and select all. Then from begining enter all parameters ( name, number, reports,... ) it should help.
CANON E225-002 L 100 ERROR
Please check Contact Image Sensor & Flat Sensor Cable.
Most probably is Contact Image Sensor in fault.
Aug 26, 2014 | Canon FAX PHONE L100-MONO LASER
What is the error e225-002 on a faxphone L100 ?
Can't find exactly the error, but e225 indicates in internal error...unfortunately the 002 indicates exactly where the error is occurring and can't find that indicated anywhere.
Found a few suggestions that a firmware update can fix a number of e225 errors. Firmware can be download directly from the Canon website here.
Canon Support Drivers FAXPHONE L100
Failing that, Canon's direct support number is 800-652-2666
Hope that helps in some way, and good luck!
Jun 17, 2014 | Canon FAXPHONE L100
Fax L100 codice errore durante rx 0033
Information from service manual Canon L100:
Error Code 0033 :DCN was received through a non-normal procedure
Jan 18, 2011 | Canon FAX-L100 Plain Paper Laser Fax
What is a com 01 error?
Information from Canon L100 Service manual
Error code 0001 : The sender may not be using a G3 fax machine
Dec 23, 2010 | Canon FAX-L100 Plain Paper Laser Fax
Canon Fax L100 has Comm Error. Seems to re-appear often. Presently not recieving faxes. Please help!
Oct 09, 2009 | Canon FAX-L100 Plain Paper Laser Fax
Aug 10, 2009 | Canon FAX-L1000 Plain Paper Laser
Getting 0048 error while faxing with a bizhub 161f
For the 0048 error code the malfunction is in the reception part and the possible causes of error is can`t receive correct signal after receive PPS_PRI_Q or PRI_Q,EOR_PRI_Q.
Aug 05, 2009 | Minolta BIZHUB 161F Black and White Copier
Error code e100 on canon laser fax L100
E100 means that you have laser trouble, probably laser pcb is bad. Replace it.
But also check the laser shutter.
Jan 30, 2009 | Canon FAX-L1000 Plain Paper Laser
I've got error message on fax-l100 canon
I have been having the same problem from my cannon l100.
If you switch off the fax machine for 30min the switch it back on again the fax will resets its self and will clear this error.
Martin
Jan 31, 2008 | Canon FAX-L1000 Plain Paper Laser
21 people viewed this question
jasbo
jasbo
