Question about Denon AVR-1802 Receiver
Denon Receiver AVR 1802 Standby light is on and there is no sound. I cant get it off standby
simplemitch
  • 752 Answers
SOURCE: Denon AVR-4800 5.1Channel Standby light blinking
It's going into protect. Unhook ALL the speakers and see if it still shuts itself off. If so, then it will have to be taken in for service.
Posted on Oct 27, 2007
Foxyjay
  • 13 Answers
SOURCE: Denon AVR-1508
If your amp looks like it's going to work as normal (ie the front display lights up as it should etc), but then the amp goes into protection mode when the anti-thud circuit times out, then I know what's likely to be wrong.
It's one of the power amplifier channels which has gone faulty.
I just found this out after having this problem with my AVR-1906.
I took the amp apart and de-soldered the suspected channel power transistors (centre channel in my case).....and hey-presto! it fired up as normal (obviously the centre channel would be out of service).
I have ordered the replacement transistors from Farnell (UK) at a miserly cost of around £2-£3 each.
Just waiting for them to arrive.
An alternative is, if you don't use all your channels, take the transistors from a known working but not needed channel and swap them over with the duff ones.
Hope thats of use!
Posted on Aug 16, 2008
  • 5 Answers
SOURCE: Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Posted on Mar 09, 2010
  • 3 Answers
SOURCE: how do i get a denon avr-3200 receiver off of
You need the remote.
Posted on Sep 16, 2010
  • 163 Answers
SOURCE: My Denon AVR-75 seems to stay in standby (red standby light is on) and I don'd get surround sound through it. How do I get it out of standby?
if the receiver does not power on from standby there is a problem like bad power supply or even bad macroprocessor. You need to bring it to a service center for diagnosing. 10-years old receiver, maybe better to buy new one.
Posted on Nov 27, 2011
Blinking standby light on Denon
could be a couple things. Either a blown channel in the amp, or a bad voltage regulator. would have to investigate further with a meter to find out.
Aug 27, 2014 | Denon AVR-1601 Receiver
How to turn off standby light on denon av1802 receiver
you can not do this. this option is no available.
Oct 14, 2013 | Denon AVR-1802 Receiver
Receiver is on standby light is on and there is no sound
May be wrong setup- try to reset to factory default setting. if doe snot help you have a problem with the receiver.
Nov 23, 2011 | Denon AVR-75
My Denon AVR-1804/884 standby light stays on but the receiver wil not power up
ok my denon avr 1804 was jamming and it shut off on standby red light flashing comes on then goes back off what is wrong ?????
Feb 27, 2011 | Audio Players & Recorders
AVR-1802 5.1 Channels Receiver: My Denon AVR-1802 LED is flashing rapidly. I have...
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
May 16, 2010 | Denon AVR-1802 Receiver
Has power but keeps switching to standby
Disconnect all speakers at the receiver and turn it back on, if it stays on post a comment and I will help you troubleshoot further. If it still cuts out, it needs to go to service for repair. Hope this helps.
Aug 21, 2009 | Denon AVR-1907 Receiver
Aug 20, 2009 | Denon AVR-1908
Oct 27, 2007 | Denon AVR-4800 Receiver
Denon AVR-1802 Receiver Logo
98 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
