Question about Denon AVR-1802 Receiver
Receiver is on standby light is on and there is no sound
  • 163 Answers
May be wrong setup- try to reset to factory default setting. if doe snot help you have a problem with the receiver.
Posted on Oct 14, 2013
How do I get my sound back on my receiver. a red light is on it
HI David, please try the following reset:
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "CBL/SAT" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings. If the reset does not correct the problem please give our Product Support Team a call at 800-229-1687 as they are available 24/7 ready to assist, Thanks, JT
Nov 15, 2015 | Onkyo TX-NR626 7.2 Channel Network A/V...
Why is my receiver stuck in standby?
sounds like unit is in protection due to a fault in ether a speaker or pa stage of unit
Nov 24, 2014 | Pioneer Audio Players & Recorders
Blinking standby light on Denon
could be a couple things. Either a blown channel in the amp, or a bad voltage regulator. would have to investigate further with a meter to find out.
Aug 27, 2014 | Denon AVR-1601 Receiver
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
Unit does not reset
Sounds like it it going in to protect mode. Very likely to have a bad output transistor(s). If discrete outputs are used in your receiver they are the larger components mounted to the heat sink. Sometimes only one transistor shorts other times many transistors, diodes, resistors and capacitors go bad. Take it to a service tech if you or no one that you know has some level of amp repair knowledge. Good luck!
Jul 04, 2013 | Pioneer VSX-1022-K Receiver
My Denon AVR-75 seems to stay in standby (red standby light is on) and I don'd get surround sound through it. How do I get it out of standby?
if the receiver does not power on from standby there is a problem like bad power supply or even bad macroprocessor. You need to bring it to a service center for diagnosing. 10-years old receiver, maybe better to buy new one.
Nov 23, 2011 | Denon AVR-75
Receiver stays on stand by
Turning On and Standby
On the AV receiver, press the [ON/STANDBY] button.
On the remote controller, press the [RECEIVER] button, followed by the
The AV receiver comes on, the display lights up, and the STANDBY indicator goes off.
To turn the AV receiver off, press the [ON/STANDBY] button, or press the remote
controller's [ON/STANDBY] button. The AV receiver will enter Standby mode.
If you have any trouble using the receiver, a simple reset could solve your problem.Note that resetting the AV receiver will delete your radio presets and custom settings.
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VCR/DVR] button, press the [ON/STANDBY] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Onkyo TX-SR307 A/V Receiver
Blinking standby button
Hi...1st off ...make sure all the speakers are connected at both ends.
2nd..buy a new cat..one that doesnt drool.
If it's still stays in Stdby after checking speakers, It might have blown an internal fuse cause thats where those darn stereo people put them now.
Jan 09, 2009 | Onkyo TX-SR605 Receiver
Denon AVR-1802 Receiver Logo
102 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
