Question about Freezers
I have a Haier chest freezer model HCF208A that is always wet on the bottom. I have it well clear of all walls and a nearby washing machine but it drips so much that the timber flooring is in danger of rotting. I have lifted it up on wooden blocks so that there is 80mm clearance under, and have placed a large collection tray underneath, but that can overflow. It is at a holiday home so visits are sparodic. It is not frosting internally and is not more than 1/3rd full. If it wasn't on an island that makes tech visit difficult I would have had it pro fixed. Any ideas anyone? Its otherwise a very good freezer. ta, Mark
    Sergeant:
  • 216 Answers
Great question.
Before i can access the issue I need to ask if you have a humidity gauge in your home?
You need to check the overall moisture content in your home. Because Freezers and refrigerators create a lot of heat and have to condensate moisture they will have some water that should be evaporated by the pan under or on top of the compressor.
However, if you home has a high humidity, which may not be noticed by yourself, Freezers will condensate a large mount of water. If the freezer is in the basement or near another warm source like a furnace, hot water heater or washing machine it may make more moisture.
So check the humidity levels around your freezer for at least one week. Check it in the morning and afternoon after work lets say.
The humidity should be between 30-50%. If it is higher than this I would suggest a dehumidifier. High humidity in a house can cause wood damage , mold and other issues like excessive moisture on a freezer or older fridges.
If you find that the humidity levels are within range I might suggest that you use a small fan to circulate air around the area the freezer is in. The only other option is to replace the freezer with a new model the reduces exterior moisture.
I hope that his helps you in getting this issue resolved!
Posted on Oct 17, 2013
4 Suggested Answers
tborn6
  • 700 Answers
SOURCE: Can I Mount Casters with Screws into Bottom of Chest Freezer?
youyr best bet would be to build a frame that the casters are welded to and there are no holes in the outer shell of the freezer. some L shaped angle would work nicely for this application and then there would be plenty of support for when the freezer is loaded up with product. Be sure that teo of the casters are lockable and two in the swivel freely.
Posted on Dec 27, 2008
jumptrout51
  • 3361 Answers
SOURCE: frozen water on the bottom of my Amana freezer
Your drain line is clogged. Take a small diameter pice of wire and snake out the drain line from inside the freezer.
You may have to access the back rear near the compressor and separate the drain line there and clean it further.
Posted on Apr 07, 2009
SOURCE: Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
Posted on May 01, 2009
Why My haier model hcm070la Chest freezer the compressor is not kick on
check thermostat, or relay on one side or back cclose to the compressor area there is a removable lid. removed and look for a thermostat disconect the 2 wires and bridge them then plug the the freezer on if runs replace the temp thermostat for a new one should be freezer thermostat
Nov 07, 2016 | Haier 7 cu. ft. / 198 liter Chest Freezer...
After placing my Haier 7 cu. ft. / 198 liter Chest Freezer HCM070LA in a horizontal or tilted position it doesn't want to freeze
If you have run it in a tilted position, the oil has migrated from the compressor to the evaporator. You need a technician to flush the oil back to the compressor. Only run equipment like this on a flat level surface. and always allow to stand a few hours after moving before switching on.
May 01, 2014 | Haier 7 cu. ft. / 198 liter Chest Freezer...
Haier 5.3 Cu ft Chest freezer. power is on but compressor doesn't run. There is click sound but nothing happens after.
The click sound is the compressor starter relay closing but if nothing further happens it is likely that there has been a compressor failure
Apr 11, 2013 | Haier 5.3 cu. ft. Chest Freezer HNCM053E
Why can't a Haier chest freezer be put in garage?
The only problem that you might have is with the coils and the flux capacitor. If you clean the coils, it should be fine.
Dec 18, 2011 | Haier Freezers
Lost manual and need to defrost
This is likely a manual defrost freezer, which means you have to remove the food, unplug the unit, and let the ice melt on its own. Do not, and i repeat, DO NOT poke the ice away from the walls. I guarantee if you poke the ice away from the wall, you'll poke a hole in the wall, and force yourself to buy a new freezer.
SLOWER IS SAFER. put some boiling water, in the pot, inside the freezer, or use a hair dryer.
Sep 30, 2010 | Haier 4.5 cu. ft. / 127 liter Chest...
My Haier 7cu. ft. deep freezer gets hot on the outer walls. Is that normal? It stays hot all the time.
It 's builded that way so there's not condensation around the door frame and on the walls.
Nov 04, 2009 | Haier 7 cu. ft. / 198 liter Chest Freezer...
jim
Apr 30, 2009 | Zanussi 5.76 cu. ft. / 163 liter Chest...
Freezers Logo
115 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
