Galanz washing machine error code 07 what doest it mean
SOURCE: code error f07 indesit washihg machine
Per Maytag, they suggest you unplug the washer for 20 minutes and see if that resets the circuit board.
Posted on Feb 27, 2008
barkencoa
  • 3463 Answers
SOURCE: Hotpoint WD860 - Fault Code F-07
F07 indicates heater relay stuck.
You need to check the heater to see if it is faulty, and fit new one if it is.
Please rate my solution.
Thanks.
Posted on Jul 10, 2009
  • 34 Answers
SOURCE: We are getting error code E3. What does this mean
Looks like you have either a stuck drum (does not spin) or an electrical fault that make the washer think the drum is not moving.
From a 2006 Technical Bulletin:
E3: Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Specifically, it could be:
1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause.
2. Hall Sensor (integral part of motor) fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Unless you are really overloading your machine you likely have an electrical fault, or a failure in the drive train--especially if the problem is intermittent. Probably time to call in a technician.
Posted on Aug 13, 2009
  • 6 Answers
SOURCE: code f23 for whirlpool washing machine
It means that there is a fault in the heating circuit and the heater is not working
The listed site deals with this problem so take a look and if you are fully capable of testing, follow the troubleshooting instructions but always double check that the unit is unplugged or disconnected from the electrical supply.
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
And remember kindergarten rule #1 "If in doubt, don't" with everything that is potentially dangerous. Electricity kills so a service repair bill may be a better solution.
Hope this helps.
jenni.
Posted on Sep 09, 2009
  • 174 Answers
SOURCE: What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Posted on Jul 16, 2010
My GALANZ air con is showing f8. what should i do ?
Galanz Air Conditioner Error Codes
Call a service company and request repair service. F8 means indoor coil pipe TEMP sensor faults
Feb 26, 2018 | Heating & Cooling
Tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/07 error code on...
The error F/07 is shown on the display due to Motor Control Unit Error in the washing machine. The motor speed is not getting detected by the control board in the machine or there is a confirm short in the motor control unit.
This will Help.Good Luck.
on Mar 11, 2010 | Washing Machines
What does error code E7:04 mean? Quicksmart 7.5 kg frontloader
To stop the sound, touch any button and perform the following steps:
  1. Turn your machine off at the power point.
  2. Wait one minute and turn it back on.
  3. Check your machine is correctly leveled .
  4. Remove your wash load.
  5. Perform a 'Rinse' cycle.
  6. If the fault re-occurs repeat steps 1 and 2.
https://removeandreplace.com/2015/12/07/fisher-paykel-aquasmart-top-load-washing-machine-error-codes/
Dec 15, 2017 | Washing Machines
I have an alonsa washing machine and it has an error 07..what's that it means
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Error code details to many popular brand washing machines are given. Surf the site by enter the keyword " Error codes " in its search box at the top right of the display window.
Jul 13, 2015 | Washing Machines
Error code 7 wot does this mean?
F/07 Error code
CCU senses short in motor control board on the bottom of the washing.
-Check wire connection on both the MCU and the CCU
-Check motor for proper operation.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jan 04, 2012 | Washing Machines
F-07 is flashing on my washing machine
If you have a Hotpoint, Creda or Indesit Machine the the F07 code means you have a heater fault and should check the heater, module and associated wiring. For more error code solutions click on the link
Mar 16, 2010 | Hotpoint Ultima WF860 Front Load Washer
Error code 07 on my Krups XP 7220 coffee machine
Error code 07 on my Krups XP 7220 coffee machine what to do? Nick
Oct 26, 2009 | Krups Small Appliances Espresso Machine
Thanks.
Jul 10, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
