Question about Roland JUNO-Gi 61-Key Mobile Synthesizer with Digital Recorder
When i trun on my juno gi display is show "program error" ,keyboard is on but no sound , no reset on fectoty setting ,version show 0.00 sub version 1.02 , how can i solv this problem
2 Suggested Answers
djlaplaya
  • 74 Answers
SOURCE: Where can I take my roland juno keyboard to be repaired lost soun
juno, lovely instrument, try the synthesizer repair centre in london
Posted on May 06, 2010
Roland juno d not work
Check the power adapter at the coaxial plug end that plugs into keyboard- is there power there? If so, is the socket on the keyboard loose at all? If so- the socket may be broken, If there is no power there, you either need a new power supply or you need to open it up to see if it is just the fues in that supply that failed.
If the plug inserts snugly as it did when new and it dopes not power up, the issue may be the power switch on the back- it may have dirty or corroded contacts- cycling the switch on and off several times rapidly should clean it.
If it still does not power up, there should be a fuse internal to the keyboard that would require you open it up to check it. If it is not under warranty, this is not an issue- if it is under warranty, it is something that should be checked in the shop.
Apr 06, 2012 | Roland Juno-D
HI, I have a Roland Juno GI, (5 months old), have not programmed anything into it or changed any settings. However, when I started it today it was flat by 50 cents. I was sure of this by checking a D or G...
It sounds like it is transposed. Look for the transpose function in your user manual. It shifts the keys by half notes either up or down. I would be surprised that factory reset would not clear the transpose setting. First, realize that these keyboards are controlled by a crystal oscillator and they just don't drift enough to shift even one cent worth.
IF the unit is NOT transposed, then the other problem is LIKELY with the pitch bend wheel. Try the action of the wheel and make sure it responds by moving up and down about 50 cents. If it doesn't go both ways, it is possible the mechanism has slipped or been damaged.
Jul 19, 2011 | Roland JUNO-Gi 61-Key Mobile Synthesizer...
Where can i get a screen replacment for the juno g ? and how much is it?
You will have to go to Roland parts to get the item and the price will vary depending on your location. The display is going to be expensive... Here is a site...
http://www.instrumentalparts.com/rojuglcdscju.html
$205 it looks like... I would contact Roland directly first. Use google to find their contact info.
Apr 11, 2011 | Roland JUNO-Gi 61-Key Mobile Synthesizer...
The fonts on my digital interface on my keyboard are sometimes upside down
I will note that MANY of the "smart" LCD displays have the ability to turn the displayed information upside down by either a command or a jumper. I did NOT find any parameter you can set in the Juno-Gi to set this in the manual... it is a mystery... Possibly there is a cable to the LCD that is loose. You need to correlate when this happens to other events or actions to narrow down the problem.
Feb 11, 2011 | Roland JUNO-Gi 61-Key Mobile Synthesizer...
A gap occur when i change tones on my juno G i.
Yep! When changing VOICE's (we don't call them tones) the generator chips and processing within the synth has to clear out the old voice generation and free up the generators for the new selections. As fast as the processors are, gaps can occur.
Some of the higher end synths are much faster or have so many generators available and processing power that they can do a more orderly transistion.
I am not sure how many generators the JUNO has, but tyoically two are used for every note being keyed. The specs say 128 note polyphony which should be the number of generators... HOWEVER they say these are SHARED with the audio track section. Layering of voices will also divide the number of available generators.
A lot of the arranger keyboards are NOT intended to be played LIVE and as a result transistions of voices are not done on the fly smoothly.
Feb 07, 2011 | Roland JUNO-Gi 61-Key Mobile Synthesizer...
When I connect my midi cables to my PC and use Fruity Loops or Mixcraft and I play notes on the Roland Juno D keyboard, some of the notes stick and dont stop playing once released and others are played...
You need to turn off the echo of the MIDI that sends the signals back to the Juno. When near simulataneous MIDI signals are mixed the decoder can receive "partial" messages that re-trigger the notes and then miss the note off commands. If you can't find the setting in the software, disconnect the input to the Juno MIDI while recording it.
Feb 05, 2011 | Roland Juno-D
On my yamaha v50 keyboard there is another sound on the keys after the c3 key how do i turn it off to just leave the synth sound?
you must do master reset!
1) Turn on the power.
TIP: All buttons must remain depressed and be pressed in the order mentioned in step #2 for proper execution.
2) Press and hold down the [SEQ] button, then the [CARD] button (located next to the Demo button), and then the [DEMO] button.
3) Continue to hold the buttons down until the dialog box appears in the display. The display will first indicate the V50 Test Program and Main Rom Version then will automatically display the question: 'Test Entry Manual?'
4) Press the [DEMO] button. The screen will display: 'Factory Set?'
5) Press the [+1/YES] button. 'OK' will appear beneath the 'Factory Set?' readout, indicating completion of the Factory Reset, and the V50 will automatically return to Play Mode.
Jan 10, 2011 | Yamaha Music
Can I update roland Juno G Old version to new?
Here is the link you need but pay absolute attention to the Please note section in each case as the Juno D LE and the original Juno D are different. If you install the wrong update you will have problems with the keyboard working at all.
Jul 17, 2010 | Roland Juno-D
Every sound is modulating as if there's tremolo on
If you have the new Juno here is a link to their update:http://www.rolandus.com/products/productdetails.php?ProductId=429 Also try looking in your manual for the initialisation procedure. This will return your keyboard to the factory settings .
Feb 28, 2010 | Roland Juno-D
Feb 06, 2010 | Roland Juno-D
Roland JUNO-Gi 61-Key Mobile Synthesizer with Digital Recorder Logo
95 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Roland Music Expert? Answer questions, earn points and help others
