Question about Whirlpool LGR8648 Gas Dryer
Stopped turning pulled front off belt is off and there is a pulley small wheel support not sure where it goes there are two separate slots where the wheel might go?
    New Friend:
    Problem Solver:
  • 12 Answers
Pulley and wheel are tensioned so smooth wheel side goes against smooth side of belt. Try each slot and use the one that gives tension to the belt. Should have grooves in other side of belt that fit in grooves on motor shaft. May be able to get at it better from back of cabinet.
Posted on Oct 22, 2013
  • 708 Answers
SOURCE: bELT REPLACEMENT WHICH BELT GOES ON TOP AT PULLEY
Try the following site, Not sure it will help but gives you a parts breakdown. http://shared.whirpool.com/assets/pdfs/literature/Repair Part List-8180371.pdf
Posted on Apr 04, 2009
  • 68 Answers
SOURCE: Hi. I have a Whirlpool dryer Model le5800xsw3.
The ***. has an edge that fits into a slot on the bottom .The other side goes into another slot.check the internet for your dryer belt config.
Posted on Sep 24, 2010
Testimonial: "Thank you! Once I saw a picture of how it was supposed to look, it took me 30 seconds to fix it."
  • 39 Answers
SOURCE: i have a wheel(might be a pulley)where does it go?The belt is fine but the dryer drum doesn't turn
Try this ...
Posted on Apr 19, 2012
hunter19_46m
  • 7482 Answers
SOURCE: need to know if I can get parts and what part #'s available for Whirlpool/ Roper electric Dryer lme4600w2. For blower wheel,blower wheel belt, idler pulley, & drum belt.
Hi Alisa Wilkerson...
Try one or both of these on-line websites...they also have phone support (free)
1... http://www.appliancepartspros.com/ (1-877-477-7278)
2... http://www.partselect.com/ (1-888-895-1535)
Good luck, I am sure they will be able to help
Bud
Posted on Sep 21, 2012
richroth
  • 9472 Answers
SOURCE: wed8200yw
Can you spin the drum freely by hand?
Posted on Nov 25, 2012
How to replace belt instructions
Disconnect cleaner from electrical outlet.
1. Place handle in operating position and turn cleaner over so bottom side is up.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear. Repeat in left-hand slot.
3. Lift extension of bottom plate, rotate plate and remove from cleaner body.
4. Remove agitator and broken agitator belt.
5. Slip agitator through new belt. (With lettering toward outside of cleaner) and position belt in belt guide. Push end of belt into opening in cleaner body. Reposition agitator making sure to align flat sides of projection on belt end of agitator with flat sides of slot in cleaner body.
6. Place the three tabs on bottom plate into slots in front of cleaner body. Snap bottom plate into place over agitator.
7. Remove hood by turning cleaner over and removing nozzle control knob on front of hood -- grasp knob and pull up.
8. Place handle in operating position and turn cleaner over. Insert end of flat screwdriver into one of the four slots beside an arrow on bottom of cleaner.
9. For slots nearest the rear wheels, push handle of screwdriver toward cleaner handle; for remaining two slots, pry outward to release latches.
I0. Turn cleaner over and lift off hood.
Il. Stretch new belt onto motor pulley.
Extra effort may be required to stretch new belt onto pulley.
Turn agitator, making sure the belt is not pinched between agitator and cleaner body. The belt must rotate freely inside the belt guide. If agitator does not turn, remove bottom plate and reposition belt in belt guide.
Aug 08, 2014 | Hoover Vacuums
How to belt replace instructions
Hi! Below are instructions to replacing the belt on a Hoover U5064-930.
2. To remove bottom plate, insert end of flat screwdriver into wide area of right-hand slot and push handle of screwdriver to the rear.Repeat in left-hand slot.
Hope this helps!
Aug 05, 2014 | Hoover Platinum Lightweight Upright Vaccum...
How to change belt on hoover runabout 44258-930?
Jun 28, 2014 | Hoover Runabout U50-940 Bagged Upright...
How to change a belt on a hoover u 4266-940?
Hello! Below are instructions for replacing the belt on your U4266940.
Hope this was helpful!
Jun 20, 2014 | Hoover Soft Light U4266-940 Bagged Upright...
I have a wheeled trimmer with broken belt?
Pretty simple, take bolts out that hold front gaurd on move it out of the way ther are two small pulleys that the belt passes through, take the 2 nits off that hold the pulleys on. Remember which pulley goes where as they are different. Put the new belt on, makin sure the v side of belt goes into v shaped pulley grooze and flat side of belt goes on flat pulley
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_a3dac712db4ca1a6
May 17, 2014 | Husqvarna 22" High Wheel Trimmer With...
I have a Honda HRR2165VXA mower that is having issues with the smart drive.
hello, hello, Drive belt replacement for front drive mowers. remove the belt coved on top of deckand clean out grass,turn mower on side where carb is facing up,use a pair of vice grips on side of mower deck so the blade can stop,remove the blade,remove the belt cover and clean out the grass,remove belt from rear and front pulley pulleys. install new belt,put belt cover and blade back on,put front belt cover on, should work,if that is not the problem; wheels will not prepeal the mower,wheels turn only when raised off ground, Check the gears or groves on the inside of the wheel for access wear that is a common problem,check the axle drive gears to make sure turns ok, to check gear box if ok pull mower back wards while drive is engaged,if wheels turn backwards than the trams is bad,all of this is caused by the operator,by not disengaging drive while pulling mower backwards or by holding mower back not allowing to propel self completely,hope this helps,any comments welcome,thank you.
Feb 15, 2012 | Garden
Hi. I have a Whirlpool dryer Model le5800xsw3. The drum stopped turning so I opened the front panel, thinking that the belt was broken. Turns out the belt was fine but the idler and pulley assembly...
Sep 24, 2010 | Whirlpool Dryers
As soon as i turn on my 360 the disk tray light wont stop blinking and disks wont read
Listen close and see if you hear the tray motor running. If you do then, most likely, the belt and pulleys that move the disk tray are dirty. Which might also explain not being able to read disks. Here's what to do: Pull the face plate off of the 360. This will NOT void your warranty. Beneath the disc tray (look under and "into" the tray) you should see a gear wheel on your left side. Push eject. Use a toothpick (or similar object) to turn that gear from left to right. Keep turning and the tray should pop open. Unplug (WITHOUT turning off) the 360. Pull the disk tray to full extention and look through the slot in the center of it. You'll see the belt and pulleys. Tweeze the belt out small pulley first clean the belt & pullies w/alcohol. Put belt on big pulley first. Then run a lens cleaner disk when you get it opening again.
Nov 24, 2009 | Microsoft Xbox 360 Console
Dryer belt has come off tensioner.
The idler pulley fits in the slots on the bottom of the cabinet (in front of the motor) with the wheel or glide facing the left side. Place the belt (grooves inward) around the drum. Pull the belt through the middle of the idler pulley from the left side. Once the belt is pulled through the idler pulley, loop it around the motor pulley (this should force the idler pulley to "open up" and add tension).
With the belt and idler pulley in place, it should look like this...
Let me know if you still need help.
May 03, 2009 | Kenmore Dryers
Replacing both Drive belts on toro 832 snowthrower
If you tie both the auger and the drive handles down that will give you enough room to get the belts out, and when you put the new belts on be sure to get the belts inside the belt guides otherwise you'll be replacing them again.
Jan 10, 2009 | Craftsman 16" High Garden Tractor Snow and...
Whirlpool LGR8648 Gas Dryer Logo
42 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
