Question about Refrigerators
Water line problem? please help
Water line had a leak. Disconected it from the back of the fridge. pulled little white tight washer type thing off and pulled out metal piece now can't get little white washer back over hose
    Sergeant:
  • 150 Answers
Start with a new supply line and the inlet valve for the frig
Posted on Apr 24, 2009
Inconsistent leaking coming the back of the washer.
The inlet water valve for the cold water has three connections to it. There are a total of 5 hoses that put water in the machine. These are on the cold water side. Check them for leaks, cracks and tight connections.
Jul 24, 2015 | LG WM3470HWA Front Load Washer WM3470HWA
Fridge freezer gurgle noise problem. Freezer window flashes replace filter . New filter installed. Noise continues emanating from freezer. Help please
The problem is AIR In The Line. Either you have a leak in the water line or the filter was not tight. In some cases, people screw the filter in wrong, and cross-tread when screwing the filter back into the fridge. If the filter gasket failed to make a tight seal, air can enter and cause a noise. If the water l;ine has a small pin hole, when water is flowing within the tube, it too can make a noise. That can happen when drawing water down for drinking or when the ICE Maker is reloading the tray.
Feb 03, 2015 | Siemens Bosch Neff Integrated Fridge...
Whenever the water dispenser is used, a leak occurs in the back of the refrigerator where the water line connects.
Pull the fridge out and tighten the nut,they are usually a compression fittting,somtimes they are not tight enough. Hope this helps if so give us a 4 thumbs up.THANKS
Mar 03, 2011 | GE Refrigerators
Water not working but still makes ice
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , turn on the dispensor light for several hours , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE has a dispensor heater pt. # WR49X10173 to keep this from happening again ( comes with instructions ) .
May 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
How to replace an icemaker hose
Turn water off from the supply. There should be a valve that the 1/4" water line connects to, if not you will have to shut off the water main. Using a wrench remove the nut from the water line connection (usually a compression fitting. You will need a need compression sleeve with the new line x2, one for the valve and one for the fridge. Next disconnect the line from the back of the fridge. Run the new line the same way the old one was run, for easiness. Make sure you leave enough slack behind the refridgerator to allow it to be pulled out and cleaned behind. Once all connections are tight you can turn the water back on and ensure you don't have any leaks. Hope this helps.
Mar 30, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Dishwasher is leaking water. Water is puddling
There is a tube on the side of your dishwasher for over flow. It sounds to me like your washer was moved and it banged against that line. You can put some caulking around where it enters the washer and that should be fine. The bottom can be several things. If your washer was removed and reinstalled like say maybe floor installation the supply line, or waste line may not be tight. If your unit has not been moved recently it is most likely the motor housing. Take off the one or two covers on the front bottom of the washer. Place the washer through the cycles and with a flashlight see at what cycle and where the water is coming from. It it appears to be coming from the white housing it's the motor. It's cheaper to just replace the unit as these motor housings are around $150.00. Check out craigslist. Hope this helps.
JimmyC
Sep 25, 2009 | GE Dishwashers
I have water leaking out the back of the freezer side of my side
Pull the fridge away from the wall and check where the water line enters the fridge for the ice maker. If there is a fitting there, make sure that it is tight or the clamp is secure. If it looks cracked or split in any way, remove it and replace it with new hose.
Hope this helps,
Jeff
Jul 08, 2009 | Frigidaire GLRS264ZA Side by Side...
WATER DRIPPING FROM BACK
I assume its on the refrigs side? Either the water valve "blue thing" is cracked or broken or the water line hooking up to it needs an new washer and or tightening.
If this helps you please rate me as high as you can and or get back to me. Thanks for using fix ya.
May 06, 2009 | Refrigerators
WATER LINE 90 DEGREE ELBOW LEAKING FRONT LEFT
Did you actually break the elbow? you may be able to cut the tubing back and get a new surface for the elbow to push back into. if not a 5/16" push in connector is what you need you may be able to find this at a water condition store such as culligan.
Feb 03, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
