I don't like reading that much,i get bored easily when i'm reading.Then,i have to take an AR test,because in our school were collecting AR points and i need to have 18 AR points to pass this School Year.I know this is wrong but,what's the answers for Deep Down Popular Quiz?Pleaaasseee!!I Need it Badly :(
  • 11 Answers
I have no idea what quiz you're talking about, but I can tell you this... After school, you will be rewarded for working hard and you will lose in life if you don't. I know it's hard to read something that doesn't interest you but just think of it as training for real life. You will probably have situations in your future where you have to do things that you don't necessarily enjoy - just so you can get a paycheck. I say get used o it and don't be a lazy bum who is a loser later in life because you didn't learn how to work hard to accomplish a goal. Nothing worthwhile in life is easy, and rarely is something easy worthwhile. Trust my experience on this... 5 years after school - your 'friends' will be gone, you'll be in the real world with only your work ethic and school transcript to get you by.
Posted on Oct 15, 2013
3 Suggested Answers
  • 17 Answers
SOURCE: I need to get a
If you mean replacing the projector bulb, here is a video link that may help you change the bulb
http://www.youtube.com/watch?v=Y6fTxkjBRjg
Posted on May 19, 2011
bronk50
  • 27725 Answers
SOURCE: whats the lay out of
a CPU usually in the centre of a motherborad is an alluminium cube/block and is kept cool with cooling fins and a fan on top its purpose is to process all input data to a computer (central procesessing unit)
hope this helps
Posted on Sep 20, 2010
Have a spark plug not firing.
Are you sure it's actually a plug?
Are you getting oil on the plug?
The plug may be firing but you may be losing compression which gives the symptoms of a misfire. As you've changed the plug, lead and coil this points to to a problem elsewhere.
Your first course of action should be to get a mobile mechanic carry out a diagnostic check for you.
To put your mind at rest, do a 2nd compression test using a light oil squirted into the bores:
Doing a Compression Test
Warm the engine. Remove all the spark plugs.
Get a pencil and piece of paper to note down the readings.
Put the compression tester into the No1 cylinder and crank the engine for 10 seconds.
Note down the compression reading.
Repeat process for all cylinders.
Here's an illustration of what you may expect on a 4 cylinder engine:
Cylinder 1 2 3 4
psi 125 122 120 124
125 is the uppermost figure for that engine. Here, this engine is fine. There's a slight variation in psi figures, but that's perfectly normal.
Here's the same engine:
Cylinder 1 2 3 4
psi 110 112 114 112
The psi reading is down. However, as all the figures are pretty much equal it doesn't indicate head /gasket problems. It may point towards worn pistons or burnt valves.
Now consider these psi readings:
Cylinder 1 2 3 4
psi 125 84 86 124
There's more than a 10% drop - a difference - between cylinder 1 and 2, and cylinders 3 and 4.
The compression readings for cylinders 2 and 3 is down; low. There's something clearly wrong.
It suggests that there is a defective head gasket between cylinders 2 and 3 or a crack in the cylinder head. The rising piston compresses the gases which escape into the adjoining cylinder via the defective gasket or cracked head.
However, it could also mean that there is a problem with the valves (burnt/not seating properly) or perhaps piston / ring problems.
A burnt valve - it's usually the exhaust valve as they bear the brunt of the combustion - can cause a reduction in engine power simply because the combustion process isn't occurring properly. Compressed air/fuel gets squeezed out of that cylinder because of the damaged valve . There even may be a misfire - a surge as the car runs.
Worn or broken piston rings allow compressed gases to leak past into the crankcase. A compressed crankcase can force oil out of the dipstick tube. The pressure in the crankcase will leak to atmosphere anywhere it can find an outlet.
The 2nd Compression Test
The second compression test is known as a 'wet test'. The first compression test was the dry test because no oil was added to the bores. The second 'wet' test can give an indication of whether it is the rings or valves at fault (though bear in mind rings and valves do not cause overheating or water in the coolant symptoms).
Spray a liberal amount of light penetrating oil into each cylinder - aim for the cylinder walls, not the centre of the piston. You want the oil to run down the cylinder wall and around the piston to form a seal.
Place a rag over each spark plug hole and spin the engine to eject the surplus oil.
Then carry out a full compression test noting down the results.
Here's the previous results with the 2nd compression readings added:
Cylinder 1 2 3 4
psi 125 84 86 124
Wet 128 112 110 126
The readings have increased. This because the oil sprayed into the bores has formed a temporary seal around the piston, thereby enabling the compression to be raised. It also indicates that the bores/rings are worn on cylinder 2 and 3 - the 'oil seal' has increased the readings but is still low in comparison with cylinders 1 and 2.
This could also indicate that in addition to worn rings there is also burnt valves. Oil cannot form a seal around a valve. A worn or split valve will cause a low compression reading and misfiring symptoms.
Compressions readings should be taken in conjunction with other symptoms. It will help you identify the problem:
Low compression readings between two adjoining cylinders point towards a head gasket/head fault if your vehicle has shown signs of coolant loss, coolant in the oil system - mayonnaise, overheating, rough running and lack of power.
If those symptoms are not present it points towards burnt valves/piston rings. A worn engine may be difficult to start and pressurise the crankcase, but it doesn't cause overheating problems.
Feb 09, 2016 | Cars & Trucks
How to use redfieeld 3x9x42 scope
Depends on the scope and rifle type to which it is attached.
I invested in an inexpensive laser bore such as this one for an AR: SightMark AccuDot Laser Bore Sight - 223 Model SM39001 (for AR-15)
Once the scope is mounted properly, and assuming you have not made any vertical or horizontal adjustments, set the rifle on a stable platform, insert the bore sight, point it at a target 50 (rimfire) to 100 (AR) yards out (works best in low light situation).
Once you have the laser centered on your target, make elevation and windage adjustments as necessary placing the scope cross hairs over the laser. Remove the bore sight and fire 3 rounds, then fine tune elevation and windage.
Dec 27, 2014 | Optics
I need reading AR but log in my number and password but I can't open for that thank you
Looks like this item is a rack that fits on a treadmill, so you can walk and read at the same time. Is that what you want to buy? Or are you trying to log into an online AR reading program? Accelerated Reader at your school? If so, you need to ask your teacher what the number and password are. It is whatever they put in for your, like your student number or something.
Nov 04, 2014 | RTO 2-pack Compact Reading Rack/ Treadmill...
Look at bugs
Seriously?
Science has named and classified about 1 million distinct species of insect. You expect someone to name a million insects for you, so you can then go name a few bugs at school. Get real.
Do your homework properly. Get a book from the library and do some reading. You might learn something.
Sep 10, 2014 | Televison & Video
Maintain wireless connection at school, is ok everywhere else...
There are some points to consider: 1. It could be that your computer is restricted from the school's wireless access point. 2. It could also be that the wireless adapter is old and might be needing an upgrade. 3. You could also try to re-type the school's wireless password in your computer is there is any.
May 21, 2013 | Toshiba (PA3212U) Wireless Adapter
How do i use a tasco 28A
1. Insert the Bore Stud into the Stanchion while aligning the arrows as shows. Insert the assembled scope guide into the muzzle of your rifle with the grid pattern upright. 2. Select the Aperture Cap that fits your objective rim. Place it over the objective end of your rifle scope and press until it fits flatly against the rim. 3. Using the Adjustable Scale measure the top of your rifle scope tube to the center of the rifle bore as follows: Open the rifle breach. Rest the upper arm of the scale on the scope tube before or behind the windage and elevation turrets. The scale markings should be facing towards you reading vertically and ascending from bottom to top. Slide the lower end of the scale up or down until it is touching the center point of the bore. On center fire rifles the center point will be the firing pin. On rimfire models the center will be the shell extractor. Read the number that corresponds to the indicator marked "CF". Make a note of the reading. 4. Aim the rifle toward a light, flatly lit area such as a wall or open sky. Caution: Do Not Look At The Sun As Permanent Eye Injury Could Result. 5. While keeping the riflescope at the right distance to see the full field of view, sight through it on the grid pattern. Move the stanchion right or left until the bold centerline is parallel to the vertical reticule wire. Turn the windage dial right or left until the vertical reticule is aligned with the grid centerline. 6. Use the reading from the scale to align the horizontal reticule wire. Find the numbered horizontal grid line that corresponds to the number on the scale. Turn the elevation dial right or left until the horizontal reticule wire aligns with this corresponding grid line. 7. To make your final zeroing adjustments remove the scope guide from the bore of your rifle. WARNING: FIREING YOUR RIFLE WITHOUT REMOVING THE SCOPE GUIDE MAY CAUSE DAMAGE TO YOUR RIFLE AND OR CAUSE YOU INJURY At a range or other safe area test fire a group of three rounds of the same type ammunition at a target at least 50 yards away. Refine your scope alignment by adjusting the windage and elevation dials. Move to your desired distance from the target and test fire another group and make your final windage and elevation adjustments. 8. Restore the stud tension by pressing the end of the spring.
Feb 13, 2011 | Tasco Scope Guide Quickly Zeroing Rifle...
How to unblock your computer?
Understandable that you cannot get on My Space, and you are bored.
Your school, as have many others, have blocked your access to My Space, because they believe there are problems with the website.
Viruses could easily wind up in your computer, and affect the school computers, plus a host of other issues.
At least this is my theory of what they believe.
Install Ubuntu? NOT a good idea!
Why?
1.Because you if you override the settings on your laptop, the school will know it, for one. Could take the laptop away?
2.Can you access the administrator account? Nope.
You can't install programs, delete programs, or access any administrator functions.
3.Ubuntu Linux is a WHOLE NEW ballgame. It isn't anything like Windows, and isn't supposed to be. It's like comparing Apples to Oranges. Both are good, (IMHO), but they are different.
[I use Ubuntu Linux 8.10 - Intrepid Ibex]
Know someone that Does have a computer you can access My Space?
Oct 12, 2009 | Computers & Internet
How to unblock myspace off of a school computer
you wont be able to do this, this is a security setting that is set on the schools routers/firewalls. located on the main server at the school.
Sorry, their is no way for you to turn that setting off.
However, you can get the student staff, your teachers, and your parents involved. Start a "partition". (look it up and see exactly what it is and how it works).
in the partition make a valid point why the school should let the students get on myspace at school. I also suggest listing out some of the reasons why you shouldn't, and out weigh it for the should.. Then get as many people as you can to sign it.. (the more adults u get from the parents the better your gonan be).
Then maybe your school, will reverse their decision to unlock it.
Also could have your parents come and talk to the principle on top of it, or have them talk to the school bored.
Oct 05, 2009 | MySpace Social Network
Action Replay freezing and not reading.
This is one of those sucky problems that I don't really know how to fix but I do know kinda what to do. For me it's probably just lucky but I turn off my DS. Leave it be for a while. Make sure everything is cleaned out well. No grim or crud in there. Slowly put in back in, don't scape anything with it. Insert the game before putting the AR Reader into the DS. I always have my DS set to not read automatically though. If it doesn't load now then try again a few more times. You may need to inves tin a new AR Reader though.
(Btw, it's okay to cheat on games every now and then. I wouldn't make it a habit though. It gets adictive and sometimes the game gets boring way too fast. I never use the AR Reader until after I've beaten the game.)
Jul 07, 2009 | Datel Action Replay for Nintendo DS
I need a scope guide instruction sheet for the Tasco 28a
Dec 14, 2008 | Tasco Scope Guide Quickly Zeroing Rifle...
Computers & Internet Logo
171 people viewed this question
David Payne
David Payne
