Question about Klutz Gotcha Gadgets
No sound on door alarm - Klutz Gotcha Gadgets
How to disable theft alarm system in 2003 f150
After market alarm? Tear it out. Factory alarm/security. BCM/GEM is messed up. Could be corrosion problem. Check the plugs.
Dec 25, 2015 | Cars & Trucks
Sunfire alarm sounding for no reason
Focusing on switches: Start with the door switches. Pull the fuse for the dome lights. Reset the alarm. Does it sound off? The alarm feeds off the dome light fuse. Driver door is first: Often they wear out first and give us grief like this. Unscrew and disconnect the switch first. Replace the fuse. Carefully close the door so you don't loose the wire in the frame(attach a string to it so you can fish it back out if it falls in). Reset the alarm. Does it sound off or not? If it does, it is other than the switch or the passenger door switch (if a 2 door or 2 other passenger switches if a 4 door). Repeat process until the switch is found or all are eliminated. Switches are cheap, so replacing them will not break the bank. Disconnect the fuse again, unscrew the bad switch. Unplug it. Plug in the new. Screw it back in place. Reconnect the fuse and try it again. Repeat as needed until you have either found it or just limited your search area. Most often you will stumble upon it- chaffed wires, look plugs, bad switches). Yes, there is more, but I see this as the usual suspect. If you go back into the alarm, disconnect the alarm first, then observe the dome lights with the fuse in. It just may be a faulty control in the alarm, which is out of my territory. Let us know what you find, but start with the smallest things first. Good Luck!
Mar 31, 2014 | 2001 Pontiac Sunfire
Alarm keeps sounding and blue light is flashing on dash board, if I close the door the alarm starts all over again. The alarm sounds very weak and weird. Car won't start,
This may sound silly but it worked for me. Try sticking the key in the drivers side door with the alarm going off and go through the motion of unlocking the door. Good luck.
If I have helped you resolve your problem, please
consider giving me a good rating. Thank you.
Oct 22, 2010 | 2004 Mitsubishi Galant
When we use our key fob to lock the doors, i know we must use the key fob to unlock the doors to avoid the alarm from going off. Recently I parked in a parking garage at an airport (left key fob at home)...
You should be able to just unlock the door with the key, and even if the alarm is still going of try to start it the key should override the alarm.
Sep 15, 2010 | 2001 Toyota Tundra
2002 PT Cruiser inside alarm
its probably the key alarm the lock cylinder may need to be replaced
Jan 24, 2010 | 2002 Chrysler PT Cruiser
Alarm sounds when you open the drivers door...
Most likely a bad ground switch in the head light switch.
GE Side by Side Refrigerator
Door Alarm -
To set the alarm, press this pad until the indicator light comes on.
This alarm will sound if either door is open for more than 3 minutes.
The light goes out and the beeping stops when you close the door.
Jun 01, 2008 | GE PSS26MGS Side by Side Refrigerator
Klutz Gotcha Gadgets Logo
82 people viewed this question
Top Klutz Home Experts
Donni Steen
Tom Chichester
Are you a Klutz Home Expert? Answer questions, earn points and help others
