Question about Hilti TE 7-C 120V Rotary Hammer Drill
I have a te72 hilti and i need the plece roller No 72139 help.
Phoned hilti and they say the machine is to old for them to carry the parts, if they make such a good a machine to last this long why stop making the service parts for.
Hili Sucks
Posted on Apr 14, 2015
  • 154 Answers
This is a problem we have encountered many times. There is usually a good supply of Hilti for sale used. See if you can find a drill the same as yours and swap out the parts.
Posted on Apr 24, 2009
NEED CRANKSHAFT AND CONROD FOR HILTI TE72
Not sure if Hilti still carries them but you can contact them at 800-879-8000
Aug 06, 2011 | Drills
I am trying to find a trigger switch for a Hilti TE72 can you help? thanks colin.
Hilti only sells parts directly...
http://www.us.hilti.com/holus/
heatman101
May 14, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
I need swich hilti te72 power swich
The only place to get what your looking for is through Hilti, there are autherized dealers almost everywhere. Most times its cheaper to have them fix it for you.
Mar 05, 2011 | Hilti TE 70 Hammer Drill Performance...
I require a switch for a hilti TE72 where can i get one please
call them direct at 1-800-879-8000 and they can help either shiping from their warehouse or possibly finding one locally.
Nov 01, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
We have a Hilti TE72 Hammer Drill.... We have taken it to fix but they say they can't find parts... We think it is the piston and a rubber gasket that goes with the piston.... Do you have this?
Parts are no longer available for the TE72. You may find some used parts on EBAY. If the tool is not hammering it would need more than the piston and oring that goes on the pistion. Without all the proper seals and gaskets I would not even attempt to repair. If you do attempt to repair it do not put more than 70cc of lube in the drill. Too much oil will distroy the gears.
Aug 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
No power at all for te72 hilti. Changed fuse and plug and cleaned brushes. Any help please
There should not be a fuse in the TE72. Do you have a continuity tester to test the switch, cord and stator?
If you have had the brushes out then you have had the motor endcap, fan and brush holder out. This would allow you to all the wiring on the 72. There are no electronics so it can all be tested easily. You have two wires coming from the switch that go to the stator. Then two stator wires that connect to the brush holder. Check that you have continuity through the cord, switch and stator.
Jun 26, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Turns but does not hammer
Hilti no longer carries parts for the TE72. You would have to find parts on Ebay or somewhere like that. There is a good chance that the con-rod is broken. Taking off the selecter lever on top. Removing the snap ring and then pulling out the shift boss will allow you to view the con-rod.
Jun 03, 2010 | Hilti TE 70 Hammer Drill Performance...
Hi.I am trying to find a triger switch for a Hilti TE72 The switch fitted is a ''MARQUARDT 1264 1601 but any alternative would sufice. Thanks Keith
this is quite an old machine and the switch will no longer be abailable from hilti. However the TE805 has a very similar switch. instead of a trigger switch its a rocker switch, but it is possible to unscrew the top off your old switch and attach it to the new one. the part number is 17904
Mar 29, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Parts for a Hilti TE72
Ebay would be your best bet. Hilti has not produced that drill since around 1992. They no longer have parts for it. That is a double throw switch. Usually the side that is burned out will be discolored or loose at the contact. If it is the left side you can take the bottem left wire and hook it to the top left wire at the contact. Or do the same if it is the right one.
Feb 22, 2010 | Hilti Drills
Hilti TE 7-C 120V Rotary Hammer Drill Logo
1,131 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
