Question about Little Giant Vcma-15uls 554942 Vertical Condensate Pump
Pump hums wont pump water - Little Giant Vcma-15uls 554942 Vertical Condensate Pump
Won't pump water
UNPLUG PUMP AND SEE IF THE IMPELLER IS JAMED, IF IT SPINS FREE TRY IT WITH A SHORT DISCHARGE HOSE. POSSIBLE BLOCKAGE IN DISCHARGE HOSE WILL TRAP AIR AND WONT LET PUMP PRIME.
Apr 19, 2014 | Cal Pump 5500 GPH Waterfall Pump
Hi I have a fisher and pykel fresh smart drive 9 and its filled up with water but wont drain,ive tried advancing the cycle but all I get is a humming noise.please help
The humming noise is due to the drain pump being jammed due to clogging of dirt. All you need is to remove the drain pump and do a full clean up. You can also try to tap on the drain pump while it is humming as it will release the dirt and wash off.
Sep 07, 2013 | Fisher and Paykel GWL11 Top Load Washer
Wont ring water wont drain
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. Supposing that it does not, the unit could possibly be experiencing an issue with either the pump or timer. Contact a professional to move forward accurately.
Nov 03, 2012 | Frigidaire ATF6000ES Front Load Washer
Dishwasher wont wash! just makes a humming noise
Without knowing the brand and model it makes it a little hard to anser but I can tell you thats the typical sign that there is something wrong with in some machines, the pump/motor assemble, in others the recirulating pump, but a technician should be called.
Apr 29, 2012 | Dishwashers
Pump hums but won't run
awwhhh it sounds as if you stored your pump dry all winter long ill bet, well ya just cant do that after it pumps salt water all summer , salt has crusted up inside pump and valves , try a hot water dose (not on motor) that might get it going again (repeat several times)
otherwise your gonna need to take it all apart clean in hot water and grease all up with foodgrade waterproof grease (see kitchen faucet parts section of hardware store)
on a salt water pool you have to store your filter and pump filled/capped with RV antifreeze (foodgrade) any good rv store sells it
salt wont crust up inside then
Mar 23, 2012 | Intex Salt Water Saltwater System Chlorine...
Machine wont drain
check for faulty water pump or a blockage to the water pump see if you can here a hum when it is time for the machine to drain
NEVER OPEN MACHINE CASE WHILST STILL CONNECTED TO MAIN POWER SUPPLY
Jan 18, 2010 | Tecnik TKL9260 Front Load Washer
Water will not drain humming noise
Humming sound could be jammed pump.Remove th filter and check pump Blades are free, nothing is stuck in it....
Nov 25, 2009 | Washing Machines
Full of water wont drain
had trouble with some washers not dumping water found penny screws and other small material in the pump removed and worked o k .this might help.hum might be from restriction in pump.
May 21, 2009 | Kenmore Washing Machines
Fills washes rinses but wont spin properly or empty out washer, ends cycle half done, wont pump water out or spin out. i can hear the machine hum while trying to do so. Please any ideas. THanks
its likely the pump is blocked (hence the humming) with a coin or some foreign object. To check, lower the outlet hose to ground level to allow the water to empty. Tip machine back & lean against a wall, remove the pump & remove object if there is one! Reassemble & try machine again
Oct 19, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Little Giant Vcma-15uls 554942 Vertical Condensate Pump Logo
Top Little Giant Plumbing Experts
Mack Baxter
JOHN LAPIER
Gary Nitowski
Are you a Little Giant Plumbing Expert? Answer questions, earn points and help others
