Question about Samsung DVD-HR775 MULTI REGION 250GB DVD RECORDER
Samsung dvd manual hr775
Unable to record
Dvd does not work
Clean the sensor/probe locate under Dvd tray (when you take off a cover you see it.
Apr 13, 2013 | Samsung DVD-HR775 MULTI REGION 250GB DVD...
Lost users manual for sumsung P1000
Please click on the link below to be able to access the manual of your samsung dvd-vr375 recorder/vcr combot thi
The exact manual for Samsung DVD-VR375 DVD Recorder / VCR Combo is not available but this is the best manual that fits in for your Samsung DVD-VR375 DVD Recorder / VCR Combo
http://www.samsung.com/africa_en/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=501&prd_mdl_cd=DVD-VR355%2FXFA&prd_mdl_name=DVD-VR355&srchword=DVD-VR355
paste the link in the url position and download the manual.
Hope this helped.
Jun 21, 2011 | Samsung DVD-VR375 DVD Recorder/VCR
Unable to record free-to-air television. by the way the television is samsung
Does recorder have Digital receiver - meaning can you watch tv through the dvd recorder? If it's a year or two old, it may no be able to pick up the new digital signals.
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
My instructions are in spanish need english
There are three models: DVD-R150 , D-R150 and DVD-SR150M: I hope your model is one of these.
The english manual for DVD-R150 can be found at:
http://downloadcenter.samsung.com/content/UM/200703/20070320093749218_01273A-R150,155-XEU-ENG-BM.pdf
The english manual for DVD-SR150M can be found at
http://downloadcenter.samsung.com/content/UM/200708/20070821193220921_01452A-SR150M-XEU-ENG-BM.pdf
Nov 07, 2009 | Televison & Video
Why can't l play DVD's recorded on this recorder on other player
DVDs come in different versions.
Try using the -R DVDs. Once your DVD recorder finalizes the DVDs they should on any DVD palyer.
Check your manual to find out the finalizing method for your DVD recorder.
I hope this solution is helpful. Let me know.
Feb 11, 2009 | Samsung DVD-HR735 DVD Recorder/HDD...
User manual in French - need English version
Yes, there is a site http://camera.manualsonline.com that is an excellent source for Samsung user manuals and other information that you can find it in English. I have used them alot to locate Samsung related user manuals in my troubleshooting. Just register in and then search for your model and it will pop up with several options and tips. God bless.
Jan 09, 2009 | Televison & Video
Have a samsung Samsung LE26A456C and a toshiba dvd recorder. Have set up telly fine, set up video to play fine but cannot record
What is it that you are trying to record? If you are trying to record a DVD you have purchased onto a DVD-R, you will almost always run into a problem because most purchased DVDs have copyright codes burned into them, making them unrecordable. Most VHS tapes have these copyright protection codes in them as wel. If you are trying to record a television show, and are unable to do so, make sure that the DVD that you are using is compatible with your burner. If your burner is set up to record only DVD-R, then you must use only the DVD-R discs. If your burner is set up to record only DVD+R, then you must use only the DVD+R discs. Some burners will record both the DVD-R and DVD+R. If you have the right discs for your burner, make sure that the discs are correctly formatted to be recorded. Also, make sure that if you are recording from a cable box or other input that you have the correct unput channel selected on the burner. If these suggestions don't work, then it could be the brand of DVD that you have purchased (i.e. Sony,Maxell,TDK,Fuji,etc.). Check your manual for acceptable brands. I hope this helps you out. Let me know if I can be of further assistance.
Sep 08, 2008 | Samsung Televison & Video
Samsung DVD-SH855
Hi Thanks to all. Problem was solved by my son who suggested that I turn the unit off in standby mode. Samsung DVD-SH855 will not record via timer settings when the unit is left with pwr on. Only works if pwr switched off.
Had I known this prior to purchasing I would have purchased a brand that worked with pwr on.
See:
http://www.avforums.com/forums/archive/index.php/t-617483.html
Apr 30, 2008 | Televison & Video
Unable to record.
Have you initialised the disk? The manual states that for the first use a DVD-RW has to be initialised first.
Apr 08, 2008 | Toshiba D-R5 DVD Recorder
Samsung DVD-HR775 MULTI REGION 250GB DVD RECORDER Logo
24 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
