Question about Friedrich QuietMaster RS10J10 Air Conditioner
Smart center The smart center displays F f touchpad is inoperable. This is after hosing debris ot of unit.
  • 86 Answers
Cirkit board need to check
Posted on Mar 17, 2008
SOURCE:
My bissell sprays solution and water but does not **** it back up. After the water and solution are gone the return tank is completely empty
1) check the tank is full of water
2)check gasket position,can be worn, or damaged fix it
3)check the belt worn for inoperable brushes.
4)check motor duct gasket, and test it. yif you notice suction in the duct, remove the tank, for assure is properly attached.
5)check the hose is attached properly at the back of the machine
6)check the lint screen in the water tank for trapped debris
7) remove any brushe from debris.
8) repair a tank debris.
God bless you
Jul 10, 2012 | Vacuums
When I touch the globe with my pen the sound is muffled and low,what can I do?
I can only suggest returning it for an exchange.
Also, looking at reviews you should not update the pen, many users claim this makes the unit inoperable.
Dec 10, 2011 | Oregon Scientific Smart Globe
I have a Yamaha PSR S700 keyboard. Whenever I play it, the OTS settings automatically gets changed and disabling all my other buttons on panel. Only if I select 'No' for the question displayed in...
It sounds like one of the OTS buttons is getting triggered accidentally. There may be a build up of residue behind the button. With the unit off, try rapidly pressing the OTS buttons, one at a time. This should help to move any debris which may be creating a false contact.
If you are feeling brave, you can try opening the keyboard and getting inside, under the button with some electrical contact cleaner such as DeOxit or Servisol.But be warned: it can be difficult to get the parts back together properly! So if you don't have much servicing experience, call your local music shop to find a service technician.
Sep 19, 2011 | Yamaha PSR-S700 ARRANGER WORKSTATION...
After starting the dishwasher with time 56 min, the time goes down to 55 min and after that time remains 55 min. After few min there it showed 0E in the display bar and it stopped working. Is that...
1. If the drain hose is kinked, water will not drain properly. Kinks will also catch food debris as it passes, clogging drain hose. Straighten any kinks or bends in the hose. Make certain that drain hose does not exceed 10 feet for proper drainage.
2. Check the drain air gap anytime the dishwasher is not draining properly. if the air gap is clogged the unit will not drain. The air gap is not part of the dishwasher. It is located on the sink and attached through the drain hose and garbage disposal. Not all homes are required to have an air gap installed.
3. Food residue or particles can prevent proper draining of dishwasher. Remove bottom rack and check unit for food debris or items that may have fallen into the bottom of the unit. Remove any items or food debris that may be preventing proper drainage.
4. If the unit is not leveled properly, OE Error may occur. Use a level to check sides and top of unit. if the unit is not level, adjust the leveling legs in the front and back (use leveling kit). Also check the mounting brackets. If one is tightened more than the other, it will offset the cabinet.
May 02, 2011 | LG Dishwashers
My Bissell proheat 2x cleaner will not spray the cleaning solution
- Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.
- Check for debris on spray tips. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.
- Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
If your machine continues to not spray we would recommend having your machine inspected by a technician at a local BISSELL Authorized Service Center.
To locate your nearest BISSELL Authorized Service Center, please go to www.bissell.com. Click on the Customer Support tab near the top of the homepage and enter your zip code in the Service Center locator box to perform your search.
You can also locate a Service Center by phone, 24 hours a day, by calling 1-800-237-7691 and choosing option #1.
Apr 19, 2011 | Vacuums
Why is my smart pad not working
I had issue with my Elan touchpad and my solution after a bunch of head ache was to shut down computer, unplug, and pull the battery out. After doing so I touched the touchpad while computer is off and the power button. Then put battery back in and started up and it was solved... Magic! It worked for my problem (Touchpad was not even showing up in device manager computer didn't think it had one, it wouldn't even work when I booted into Linux) There must of been some really weird charge on the capacitor so this allowed it to discharge. Think of it as hitting the reset button.
And of course make sure your touchpad is enabled in the bios or with the touchpad on/off button either on your keyboard F-Keys or a button next to the touchpad (that the touchpad off button is not set). Also check touchpad settings in your mouse settings section to.
Feb 16, 2011 | Acer Aspire One PC Notebook
Right touchpad button is not working. If I switch setting to left handed ot make it primary click it still doesnt work so pretty sure it is the button. Is the touchpad faulty?
It is probably either gone bad or a wire from it has come loose. Only way to tell would be to open the unit. Easiest and cheapest work around is to buy a USB mouse or trackball and use it instead.
Mar 19, 2010 | Computers & Internet
Led states A05 problem and machine stopped working
"Error A05 - Pressure switch has not been reset "
This is centered around the filter and drain area not working properly.
It is possible it just needs the filter cleaning and the hose flushing out, but also possible the pump needs to come out to clean it properly.
Drain it by putting the hose low down, and clean the filters of debris.
If this does not fix it, then remove the unit outside, lie on it's back and remove the pump to clean it.
Feb 09, 2010 | Indesit 24 in. DE73 Evolution...
Error code F21 - thanks for your help
The F21 error code is an indication that the unit has too long of a drain out condition. If the control calls for the unit to drain & the water does not drain out in 8 minutes or less the unit will stop & flash the F21 error code. I would recommend checking the drain pump & pressure switch circuit.
Clear pump of debris. Tilt machine. Take off front panel. Unscrew large white drain plug. Remove debris.
Unplug from power source...remove front lower panel (3 sheet metal screw wirh 1/4" drive head located on the lower lop of the panel)...open pump strainer (looks like a large stove knob, Turn it counter clokwise, lookout! lots of water will gush out... back flush the pump by filling the outet of the drain hose ( this may dislodge debris that may jam your pump)...re-assemble, plug to power, and turn-on. That will help get rid off the debris.
It can be done if you are patient and able to figure out how the plastic thing comes apart. Good luck!
May 09, 2009 | Washing Machines
Maytag neptune MAH 9700 AWW - error code nd
you need to remove the front cover by removing th escrews holding on the door hinge nad 2 other screws oppisite the hinge, after taking off screws the front "u" shaped panel will pull foward and off( hoeld on by 2 clips along the bottom. the drain pump is located right back corner of machine..ill assume that the machine is still full of water so youll need ot **** out as much as possible before removing the hose connected to the pump. theris going to be some water no matter how much you remove nut might as well get as much as you can. youll either find debris in hose, or debris lodged in imoeller of pump, even seen coins standing in the plastic hosing preventing flow of water.VERY< VERY rarely bad pump ussually just a clog.IMPORTANT UNPLUG UNIT FIRST LOTS OF LIVE WIRES UNDER HERE
Nov 05, 2008 | Maytag Neptune MAH5500B Front Load Washer
Friedrich QuietMaster RS10J10 Air Conditioner Logo
145 people viewed this question
Top Friedrich Heating & Cooling Experts
Bill Long
acidjazzok
acidjazzok
Joshua Jennings
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
