Question about Hotpoint Ultima WF860 Front Load Washer
Dishwasher SPI 2465 - Hotpoint Ultima WF860 Front Load Washer
Owner's manual 2000 Viking 2465
Try Googling (Viking)(2465)(manual) without parens.
May 14, 2017 | Sewing Machines
1997 olds gutless. Fuel gauge stuck past full. How to reset
Need to replace the instrument cluster or fuel gauge sending unit in the fuel tank or there is a BCM problem .BCM is a computer module if your not familiar with that . The BCM controls the instrument cluster indicators through the SPI serial data communication bus. Refer to Body Control Module System Check in Body Control System.
Serial Peripheral Interface (SPI) Data Line
The serial peripheral interface (SPI) is a three wire interface connecting the BCM to the instrument cluster. The SPI allows for the exchange of information. This interface is a synchronous serial data link where the BCM is the master and the instrument cluster is the slave. Because of the need for modules on the different serial data links to communicate with each other, the BCM acts as an interpreter, or master, for data communication between the class 2 and SPI data lines.
Driver Warning System
The BCM is responsible for the following functions:
  1. Interpreting all of the driver warnings sent by the control modules on the class 2 serial data line
  2. Sending the information to the instrument cluster in the form of a SPI serial data bus message
The following list of messages are sent by the BCM to the instrument cluster:
Fuel gauge position
Temperature gauge position
Oil pressure
Low engine coolant
Check oil
Volts
ABS
High beam
Low fuel
High temperature
Washer fluid level low
CRUISE
BRAKE
SERVICE VEHICLE SOON
Door ajar
Seat belt
THEFT SYSTEM
PRNDL
your best bet is to take your vehicle to a ASE certified repair shop an have it diagnosed .
Mar 02, 2016 | Cars & Trucks
Why does my dishwasher most of the time not desovle the dish soap
make sure when you load it that nothing is stopping the soap door from opening all the way,, most common mistake is loading a cutting board or tray in the front of the lower rack
Nov 20, 2015 | Frigidaire Dishwashers
Bosch sps/spi 64 dishwasher not starting cycle
Check if the pump impeller is free and not blocked with anything.TAKE GREAT CARE!! ISOLATE THE MACHINE BEFORE YOU DO THIS AND IT MY BE BLOCK WITH GLASS ETC!!!
There are u tube vids for this.
Oct 13, 2014 | Dishwashers
What is the best thing to use to clean the inside of the front door seal that has sludge in it.
Bosch Classixx WFC 2465 Front Load Washer how to
clean door seal.
This video will show you
how to change a door seal on this Bosch front loader washing machine .
we have all bosch repairs in our channel
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 22, 2011 | Bosch Classixx WFC 2465 Front Load Washer
I don't know where to put the Rinse Aid
It might seem silly, but you open the front load fully, so that's it's lying flat and then you pour the rinse aid over the holes in the near left hand corner (where you might otherwise think you have to open the trap door for the rinse). The rinse aid will flow quite neatly into the reservoir and hey presto, once it's full (you'll know it's full because it'll start to back up and overflow) you're back in business. No more annoying rinse aid light!
May 22, 2009 | Bosch Exxcel WFO 2465 Front Load Washer
Water won't empty
Remove filter and within the sump is a finned cover screwed down with either a 10 or 20TX screw(starshape) remove the water with a kitchen syringe and check normally it's broken glass or seeds.Good luck.
Apr 17, 2009 | Bosch Classixx WFC 2465 Front Load Washer
How and where are batteries installed for spi-dog??
On its underside, there should be a screw that, when unscrewed, allows you to open its stomach and insert batteries.
Oct 22, 2008 | Hasbro SPI-DOG for Most Audio Devices
Horiz. lines across top of screen.
I agree with solution #2
I recently had my phillips 27" model 27PT6341/07 repaired after warranty expired due to white lines appearing at the top of the screen. The shop advised that it was a capacitor giving me the problem. So, after getting it back, I examined the repair job and the shop had replaced a capacitor at the back of the main board, next to the rear rca inputs. It is labeled 10uf 100v. I was told that it would fail again soon because it is a manufactures defect. For me it is at location 2465. Here are a couple of photos of the part.
http://farm4.static.flickr.com/3215/2337629026_eaa30cfa18.jpg?v=0
http://farm3.static.flickr.com/2411/2337627420_b45bbf1a74.jpg?v=0
Good luck,
Ed
Nov 13, 2007 | Philips 27PT6441 27" TV
Hotpoint Ultima WF860 Front Load Washer Logo
24 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
