My Fedder azhp12d2a portable air conditioner will not turn on, the light above the words "three minute cooling delay" is blinking red, and when I press the reset button all the lights come on and it begins to beep then turns off and the light continues to blink, my house is burning up! Any way to fix this??
SOURCE: blinking lights on control panel
Same issue, machine is about 30 days past waranty. Door switch broke, but of course they (GE repair) do not fix the switch, you have to order the Escutcheon Body (whole panel) to fix ~$350 total.
Posted on Aug 04, 2008
ginko
  • 19396 Answers
SOURCE: Power button blinks green about 1 minute then goes red
There is an additional problem,
if the bulb had been replaced by a technician, call them back and ask for additional support, since they did not fix the problem.
Posted on Oct 15, 2008
SOURCE: red light came on and air conditioner will not turn back on
I had a similar problem on a B&Q air conditioner and all it needed was the drain plug removing and the water draining out - then it started back up straight away
Posted on Jun 03, 2009
kaycee71
  • 37 Answers
SOURCE: I have HAIER HPAC 99ER Portable air conditioner
Make sure your filter & the coils (area under the filter) are clean or that the evaporated water is not overfilled by draining it manually by pulling the plug on the lower rear of the unit (into a bucket of course.) I'm hoping you had gotten an answer sooner...
Posted on Aug 28, 2009
SOURCE: Fujitsu Plasmavision PDS-4233
HI, I haHe a Fujitsu Plasma HDTV Model PDS4233. The TV won't power ON, When i turn on the master power button the light starts flashing a red light repeatedly. I also observed that the Fans power up for about three seconds immediatly after i press the master power button, after the three seconds the fans shut OFF and the light continues to blink.. I haven't observed the light to see if there is a pattern with the blinking..
Posted on Dec 14, 2009
Why is my Kenmore 72012 blinking?
Does the display blink no matter what is displayed? If the display always blinks the same info, what might that be(i.e. error code)? If you are able to cycle through settings and the display changes while blinking, the problem is likely in the control circuitry. The controls have a built in delay to protect the system from abrupt changes. You'll notice this delay, and the blinking display, when you first turn these units on and when changing modes.
Jul 12, 2014 | Kenmore 72012 Portable Air Conditioner...
My fedder azhp12d2a portable air conditioning unit will not turn on, the light above where it says "built in three minute cooling delay" is blinking red continuously. When I plug it in it beeps and...
every time when you turns your ac on it takes 3min , dear it is just a time delay to protect your ac comp , it is not harmful. You can by pass it by pressing turbo key in remote aur by switching off your ac by remote only not by mains. it is helpful , try it
Oct 14, 2013 | Heating & Cooling
There is a blinking blue light under the fan symble that comes on every hour, and wakes my wife up.
when mode you selected will be operational the blue light will blink.every time before the cycle begins the blue light will blink with the slight delay of 10-30 sec.
Sep 12, 2011 | Danby DPAC90061 Portable Air Conditioner
My unit to my house wont turn on outside. This happened last night at about 8:30. I have checked the circuit breaker/fuses and the little red switch on the unit itself-- I pushed that. I turned the...
Turn power off to indoor unit. Remove red, yellow and green wires from tstat and wire nut the three together. Turn power to indoor unit back on. This should bring on indoor fan and outdoor conpressor and fan. Let me know
Jun 22, 2017 | Fedders Q Chassis A6Q10F2A Air Conditioner
Brand new Whynter ARC 12 SD, just plugged in and red warning light about power button is blinking. Booklet says the light will blink when water reservoir needs to be emptied. But, it's brand new, no...
Check the positioning of the water bucket It may be slightly out of place and is not triggering the switch. If that doesn't solve the problem. Turn the Master ON/OFF Switch to OFF, unplug the unit for 12 - 15 minutes. Then plug it back in and turn the Master Switch ON/OFF Switch to ON. Set the controls and it may have reset itself.
If none of the above soled the problem contact the manufacture's Customer Support or Tech Service Dept.
Hope this helped you to solve the problem. Please let me know. Thanks.
May 05, 2011 | Whynter Portable Air Conditioner
The blue light keeps blinking and error e04 comes up
I have a DPAC 1200068 air conditioner and the red light keeps blinking and I need to know how to shut it off so it flashes when it is suppose to and go off when it is suppose to.
Jun 21, 2010 | Danby Portable Air Conditioner
Model # m6p09s2a portable maytag air conditoner unit...red light keeps blinking at the unit where power button is located....unit will not turn on. the light just keeps blinking
Greetings,
I have the same model air conditioner, and had the same symptoms. As you've probably discovered, Fedders is the company that actually built it, and went of business. No one is supporting it any more.
However, you may be in luck. I fixed the problem by simply tipping the unit almost all the way over on its back (leave a little gap) and letting the water drain out of the hose and the filter. After that, it started right up.
Hope that works for you. Stay cool. :)
Jun 16, 2010 | Maytag Portable Air Conditioner M6P09S2A
Snowflake blinking and air conditioner won't turn on.
If it is blinking it is in a 5 minute time delay.
It should settle to a steady snowflake after 5 minutes and come on normally.
May 21, 2009 | Heating & Cooling
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
