Question about Black & Decker Saws
PHS550B saw blade change
Black Decker PHS550B saw blade change
    Sergeant:
    Champion:
  • 226 Answers
MOST TIMES THERE IS A ARBOR LOCKING BUTTON ON THE HOUSING NEXT TO THE BLADE HOUSING.YOU HAVE TO HOLD THIS DOWN WHILE TURNING THE BLADE SECURING NUT TO LOOSEN OR TIGHTEN THE BLADE,OR YOU CAN DO IT THE OLDFASHONED WAY FIND A VENT HOLE IN THE BLADE,STICK A SCREWDRIVER IN IT LOCK THE SCREWDRIVER IN PLACE THEN TURN THE NUT(WHILE UNPLUGED OF COURSE)HOPE THIS HELPED
Posted on May 23, 2009
How do I change the blade on the black & decker powered handsaw PHS550 type 2
Go to http://www.manualowl.com/m/Black%20%26%20Decker/PHS550B/Manual/412144?page=2. Follow instructions.
Oct 05, 2014 | Saws
How to put the blade into the black and decker 3.4 amp powered handsaw
#1) You have to locate the blade release button on the saw (see your manual). The opposite side of the release button is a screw-like OVAL shaped PIN. To insert the blade, the direction( or position) of this OVAL shaped PIN has to match the OVAL shaped hole in the blade. You could use a screw driver to change the direction/position of this OVAL shaped pin. You have to push down the release button when you use the screw driver to turn.
#2) Hold the blade in Vertical position in your right hand. The "Oval" hole is on top. The teeth is facing your left hand. You will see that the "oval" hole on the top of the blade is a "horizontal" oval.
#3) Hold the saw (handle) in your left hand as if you were going to saw using your left hand.
Now peek through the hole of the saw and find the direction of the OVAL PIN. It has to be a "horizontal" (or lied down) OVAL. If it is not, use the screw driver to adjust it.
#4) Hold the blade using your right hand. Oval hole on top, teeth facing your left hand. Insert
the blade from the bottom of the saw. What you needed to do is to insert the PIN into the hole
of the blade. When you inserted the pin into the hole of the blade, slowly turned the blade upward, the blade will lock by itself.
Oct 15, 2013 | Black & Decker PHS550B Powered Handsaw...
Change blade Black and Decker jigsaw 7568 Type 1
I had a heck of a time. The set screw was not anywhere I could acess it. Finally figured out that the motor had stopped in the 'up' position. Once I got it back down the set screw was right there.
Mar 06, 2013 | Black & Decker Scroll Jig Saw Blade
Hi I have a Black and Decker Jig Saw 7588 Type One that works fine but I can not find replacement blades for it here in San Diego, California. Where can I find the blades?
I have the blades and the 7588 jigsaw. thinking about selling on ebay. search for black & decker jigsaw w/ blades in next couple days if interested in buying saw with 6 blades. thankyou, makthriftsales
Jan 14, 2013 | Black & Decker Single Speed Jig Saw
Black & decker 10" table saw -where is the blade
The Blade is held on by A Nut and Washers. Remove the Blade insert and you should see the nut and washer
Jun 26, 2011 | Black & Decker Saws
We can't get the blade to go in
There should be a button on the right side of the saw to press in to open the clamp for the blade.
Blade changes require no tools. There will be a pin that engages the hole in the blades.
May 09, 2010 | Black & Decker PHS550B Powered Handsaw...
Black & Decker Blades
the blade jig saw does not stay in on black &decker js2500
Mar 07, 2010 | Black & Decker Scroll Jig Saw Blade
How do I change the blade on a Black & Decker JS500 jig saw?
Go to Dewaltservicenet.com and type in your model number and you can download the instruction manual for this tool with detailed instructions on how to change the blade. It is 8 pages long.
Oct 03, 2009 | Black & Decker Scroll Jig Saw Blade
Saws Logo
417 people viewed this question
Top Black & Decker Saws Experts
Jason
Mike Carew
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
