Question about Kobo Arc
How do l turn off safe mode on my kobo arc - Kobo Arc
My Kobo Aura is not recharging. The charging unit seems "dead". Can the charger be replaced?
it can
Kobo Aura / Aura HD compatible Advanced Rapid Wall AC Charger ...
https://www.amazon.ca/Kobo-compatible-Advanced-Rapid-Charger/.../B00GNB08JS
Gomadic Powerful High Wattage wall charger for home or travel use. Customized circuit design is based on the latest in power regulation and is tailored to the ...
Kobo Aura One Charger, BoxWave® [Wall Charger Direct] Wall Plug ...
https://www.amazon.ca/Kobo-Charger-BoxWave®-Direct-Touch/dp/B01MA3NLF8 Pwr+ 6.7 Ft 2A AC Adapter Rapid Charger for Kobo VOX eReader; Kobo Arc 7 10 HD; Kobo Touch Glo Mini Aura Hd Ebook Tablet.... ... HQRP Micro USB Charger / AC Adapter for Kobo Arc / Arc 7 / Arc 7HD / Arc 10HD / Mini / Glo / Touch / Aura / Aura HD / Vox.... ... Pwr+ 6.7 Ft 2A AC Adapter Rapid ...
Kobo eReader Glo USB Cable - Micro USB: Amazon.ca: Cell Phones ...
https://www.amazon.ca/Kobo-eReader-Glo-USB-Cable/dp/B00AXZVE48 Rating: 4.7 - ‎11 reviews
Kobo eReader Glo USB Cable - Micro USB: Amazon.ca: Cell Phones & Accessories. ... Cable for Kobo eReader Kobo Mini, Kobo Touch, Kobo Aura & Aura HD... ... Pwr+ 6.7 Ft 2A AC Adapter Rapid Charger for Kobo VOX eReader; Kobo Arc ...
Chargers & Cables - Electronics: 146 products available ' chapters ...
https://www.chapters.indigo.ca/en-ca/electronics/chargers-cables/500151-cat.html Results 1 - 24 of 146 - Shop Online at Chapters.Indigo.ca for a wide selection of chargers & cables products, 146 items available. Enjoy free shipping on orders ...
kobo aura charger Google Search
Sep 24, 2017 | Tablets & eReaders
My kobo arc 7 screen is not responding to touches. Can it be reset?
1. Turn the power off and pull the battery out and reinsert it.
2. Hold the Volume Down button.
3. Then press and release the Power button.
4. Wait a minute,the menu appears that allows for Fastbook, Recovery, Clear Storage, and Simlock.
5. Ok,press the Volume Down button to choose Clear Storage.
6. Next,press and release the Power button,Wait for the Kobo Arc to restart.
7. You will see the two options: Volume Up for YES and Volume Down for NO.
8. If you choose YES, all data will be deleted from your Kobo Arc and including third-party applications.
9. The Kobo Arc will reboot to its original data.
10. This time you can restore your backed up data to your phone.
Nov 25, 2014 | Tablets & eReaders
Undefined
When your Kobo Arc 7, Kobo Arc 7HD, or Kobo Arc 10HD is connected to a wireless network, you'll see a and-wififull.svg Wireless icon in the System icons at the top of the screen.
  1. Tap the and-home.svg Home icon at the bottom of the screen.
  2. Put your finger at the top of right of the screen and swipe down.
    The Settings shortcuts will appear.and-shade.svg
  3. Tap the and-settings.svg Settings icon.
  4. If required, tap the slider button beside Wi Fi at the top left of the screen. The button will turn blue and display On.
  5. Tap Wi-Fi. The list of available networks will appear.
  6. Tap the name of the network you wish to connect to.
  7. Tap Connect.
  8. If you see a lock icon beside the wireless connection, it means that the connection requires a password. You'll need to enter the password to connect.
Turning off Wi Fi on your Kobo Arc 7, Kobo Arc 7HD, or Kobo Arc 10HD You can turn off Wi Fi to keep your Kobo Arc 7, Kobo Arc 7HD, or Kobo Arc 10HD to keep from connecting to the Internet, which is also known as Airplane Mode.
Turning off Wi Fi extends your battery life, and also lets you use your Kobo tablet on an airplane or in a hospital.
  1. Pull and hold the power slider at the top of yourKobo Arc 7, Kobo Arc 7HD, orKobo Arc 10HD until the power off menu appars.
  2. Tap Airplane Mode.
Oct 27, 2014 | Tablets & eReaders
My kobo wont turn charge and turn on
Broken psu connector or moethboard junk it its not cost effective to repair.
Aug 20, 2014 | Kobo Arc
My kobo wont open the book, keeps loading but does not open
Does your Kobo turn off and on normally? Or is it stuck loading the book and totally not responding? If so, reset your Kobo. Look on the bottom edge of the Kobo - see the little pinhole? Stick a paper clip into there until you feel it push against a little switch. Remove the paper clip.
Is the Kobo working, but simply can't open a book? If it's only affecting a particular book, try deleting it and downloading it again.
Dec 27, 2013 | Kobo Arc
Mini usb port on kobo arc is broken. Where can I get parts?
Hi i managed fix my usb port , open the kobo and remove the usb ribbon, the usb port is glued at the rear , you will see a black blob od adhesive at back of port , this comes unstuck if it gets a knock , i gently lifted this slightly then slid some super glue underneath and then applied pressure on top of the usb port to ensure the port was contacting the ribbon again until the glue set, my kobo is back in action again , hope this helps someone
Jun 20, 2013 | Kobo Arc
Kobo Arc Logo
791 people viewed this question
Top Kobo Tablets & eReaders Experts
Yoav Shilon
Yoav Shilon
Andrew Taylor
Andrew Taylor
Are you a Kobo Tablet and eReader Expert? Answer questions, earn points and help others
