Sony Dvcam DSR-390P DV Digital Camcorder Logo
Posted on Apr 24, 2009
DSR 300P error 09-028 after loading casset - Sony Dvcam DSR-390P DV Digital Camcorder
1 Related Answer
pemring
PEMA TSHERING
  • 53 Answers
  • Posted on Jan 13, 2009
SOURCE: sony dsr-300p
Reel position sensor
detected STANDARD and
MINI at the same time.
I have in display error 09-020, what can i do
switch off the system and remove the power cord.
while pressing eject button ON the power switch.
I don`t have fotoprisa-300p-printer`s cd so Driver installation problem please detail and complete answer. thank your help
Hi, This printer is also known as a BENQ FotoPrisa 300P. You can download drivers from this page. http://www.techno-files.com/categories/printers/404/6984.html Please give feedback if this works for you Thanks
My dsr-45 no eject cassete
please follow this :-Remove the case, remove the mechanism cover, cut the mangled tape in pieces and take it out gently - you are going to have to rotate some part to untangle most of it. With all the tape that's out of the cassette removed from the mechanism put the unit back together and eject it.
i hope this will be helpfull to you .
goodluck.......
Error code 09-028
Servo and tape path system error.
0 : Mode cannot be identified, or mode identification is
not necessary.
2 : Threading motor/FG/sensor
8 : Abnormal current detected.
If it’s not just a simple tape jam, then you have a problem with the loading mechanism. The best solution is to take the deck to a service center.
5helpful
3answers
Sony DSR 25, error code C3140. Any advise. Only comes up when tape is inserted.
FG fault when starting drum.
It’s very possible that you have a bad drum motor.
2helpful
2answers
My cam is a sony dsr-390
Error code 91-258 is described as follows..
91- Microcomputer and its periphery device error
2- THREADING
5- S side reel FG
8- Detected abnormal current
Your camera got mechanical problem with Supply Reel and failed to load tape.
8helpful
3answers
Sony DSR 45P error code C3125
Press the power butten several times while holding down the eject button. It will solve your problem and clear the error. If it not then there is something wrong with your reel motor or the circuitery which deals the reel motor. You must consult your nearby sony service center.
Rajab Ali
1helpful
Sony dsr-300p
1helpful
3answers
DSR 25
C:31:23 on a DSR-25 indicates a supply reel problem, most likely caused by a defective cassette housing. Best repair solution is to send it to an authorized Sony repair center.
11helpful
3answers
Sony DSR-45 Error Code C3140
C:31:40 is "FG fault when starting drum." In plain terms, the video head assembly is not producing a feedback signal that tells the control circuitry that the heads are spinning. Most probable cause is a bad drum assembly, but check to make sure the flex cable going to the drum is properly seated.
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
