Gbc laminator docseal 3100
Laminator heats up green lights on and power supple fuse blown of
4 Suggested Answers
SOURCE: need parts for a gbc docuseal 95 laminator
Go to http://www.mybinding.com/.sc/ms/ch/parts.html, and scroll down the list of products to "pouch laminators" then choose your specific model. When you click you can access parts information as well as a diagram of the equipment. Good luck.
Posted on Sep 07, 2010
SOURCE: I have a gbc heatseal
There is a small 125 v 10 amp fuse in the circuitry on the right inside the unit. Whether or not this will solve your issue is unknown. I have one apart in front of me right now with other problems.
Posted on Jan 13, 2011
m4c2
SOURCE: a laminate and paper jam in a Gbc HeatSeal H425 Laminator
You need to loose the vertical plastic wall on the left side, and pull it up and to the left, only then you would be able to take pink rollers and metal piece away. Step by step do this (BTW, make pictures of each step if you think you will not be able to assemble it back) :
Download parts scheme here (if link is broken I can send you; write to ororeivis [at] g mail com):
http://www.gbcconnect.com/assets/docs/H425_PARTS_POUCH_LAMINATOR.pdf
Take the lid (3) off and hang it on the corner.
Next goes off (42) part.
Now focus on the left side. Take to the side part (30) with 7mm wrench. Then both parts (14) from both sides [4 in total]. Then both parts (2). Then take out screws that are holding this vertical plastic wall place. There is two screws from the outside of laminator in the bottom!
Then black roller (36) you lift up and take out by sliding to the side. Then two long black metal pieces.
Now you should be able to pull up and move to the left that vertical plastic wall on the left side of laminator. If not, try loosing some screws that are in this wall.
Be careful taking melted jammed stuff away from heating panel. Do not over-scratch it, as it is very sensitive.
floating cowboy
Posted on Jun 30, 2012
Testimonial: "Thanks! It's all fixed now and put back together!"
Does the GBC Ultima 65 have an adjustable pot to increase heat of rollers? If so, where is it located?
Ordinarily, laminators have speed controls to allow the laminated substrate to get hotter.
Feb 12, 2015 | Gbc HeatSeal Ultima 65 Roll Laminator
How do I feed New laminating film through straight? Top roll of new film is wrapping around bottom heat roller
go to youtube and watch the video on GBC ultima65 film loading. sounds like you are not using a threading card to load laminator. Manila File folders work great to load laminators Westco Laminating Svcs 405-324-6092
Aug 30, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Why won't someone answer the ??s about the GBC Pinnacle 27 power light in the back works, but no power
Each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime......
Westco Laminating Service 405-324-6092
Aug 09, 2014 | Gbc 1701720: Pinnacle 27 EZload Laminator
Gbc pinnacle 27 ezload power light turns on but the front panel does not
you have one of the TCO's that is blown out, To test them you need to take the right side cover off, and test continuity from one side of the tco to the other, start with the tco wire that is connected to the tray switch, the other end of the tco wire is connected to the wire block on the right side of the laminator. just follow the wires back to the heat shoe and check for continuity. A TCO is no more than a temperature fuse. you can actually make a test "jumper wire" and jump across both connectors and it should power right on. You need to be careful and follow the wires back correctly so you don't fry the laminator the rest of the way.
Mar 31, 2014 | Office Equipment & Supplies
Laminator won't heat up
This is just rediculous. Where's the friggin answer?
Mine won't even come on. JUNK!
Jan 28, 2014 | Gbc HeatSeal Ultima 65 Laminating System
GBC Pinnacle27 Laminator has no control board power
Each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime......Westco Laminating Service 405-324-6092.
Jan 08, 2014 | GENERAL BINDING CORPORATION Laminating...
Gbc ultima 65 won't heat up.
Could have a bad heat lamp, do your adhesive feel tacky on any of the rollers? Are you may have a bad triac
Oct 02, 2013 | Gbc HeatSeal Ultima 65 Laminating System
The heat button won't turn on
either the top or lower heater shoe TCO is blown out. take the right side cover off, trace the wires back to the heat shoe and check for continuity, (unplug machine first) find out which TCO is blown order another one, replace it and your off to the races. I've fixed many of them.
Mar 11, 2013 | Gbc 1701720: Pinnacle 27 EZload Laminator
GBC Pinnacle 27 won't come on
each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime.
Feb 20, 2013 | Gbc ® Pinnacle 27 Two-Heat Roll Laminator,...
20 people viewed this question
k24674
