Question about Acoustic Research AW825 Outdoor Wireless Speaker
Acoustic research wireless speaker aw825 on light blinks will not turn on
5 Suggested Answers
sleepy_user
  • 140 Answers
SOURCE: Can Acoustic Research wirless speakers be used for surround?
yeah, I looked it up on thier website. Here is what they say.
Warning: This product is designed to work with line level outputs or headphone outputs only.
DO NOT connect it directly to speaker outputs as it will permanently damage the transmitter.
You can use these as surround speakers if you like. You just need a line level surround output on the receiver. Most high end receivers have this feature but, you may only have speaker level outputs.
If that is your case the only option you have is to use a "speaker to line level adapter".... http://www.crutchfield.com/p_543ADP12/Russound-ADP-1-2-Speaker-level-to-Line-level-Adapter.html?tp=9070
Now crutchfield.com is always a little high on prices but if you look around I have seen them around $10 online.
Good luck with your project.
Posted on Jan 29, 2009
  • 19 Answers
SOURCE: I have a set of Wireless Acoustic Research
Try using a different source than your television. If it works, then there's an issue with the output of the TV. However, if you use the same cables as you were using with the TV, they may be bad. Try using another device with a different set of cables to plug into the transmitter, which should help identify where your problem really is. Please rate my answer, thanks.
Posted on Jun 18, 2009
ripleymojica
  • 643 Answers
SOURCE: I want wireless speakers for a 25'X 30' room to
they are wireless but need to be plugged in for power. or batteries. can be used as mono or left and right. i sell these spkrs and have had no complaints. hope this helps.
Posted on Jul 10, 2009
bigbudget
SOURCE: Acoustic Research AR-1 Qusetion- LFE Input and Output functions??
using the LFE input will give you cleaner less distorted bass. You must have a sub out on your receiver or pre-amp. it will give you greater control over the bass output of your system. If you only have one sub-out on your receiver simpley run a 10ft rca from the sub-out of reciever to the rca input of either speaker than use the rca out of 1st speaker to the rca input of second speaker. check to see if you have control of the level of your sub-out on your reciever. adjust the 30hz boost on rear of speakers. now you will have bass that most people only dream of having.
Posted on Oct 26, 2012
I love my speakers, but when iTunes stops playing music, they make a horrible scratchy crackling noise....any suggestions?
is your itune also connected for charging when you connected to your speaker? it could be the possible causes during itune finish playing the internal charging noise from switching supply adaptor come into the audio line get into your speaker, so you may hear the noise. If this is the problem, you may try to use differentiate line in isolator. mostly people use in the car to isolate engine alternator noise. you can find in car accessories shop.
Jul 20, 2011 | Acoustic Research AW825 Main / Wireless...
Acoustic Research Model AW871 wireless sterio speakers
Your connection between the AR transmitter and the ONKYO receiver sounds solid. I'd guess it's the wireless speakers that are the wrong point, or at least that's what I'd look at first. Doing a bit of research, I noticed a couple minor points. First, these seem prone to RF interference from other RF devices. Have to tried switching channels on them? Second, someone reported theirs would not work properly unless the speakers were turned on just before the transmitter, and turned off shortly after the transmitter. Apparently you have to hold the button on the front in for 5 seconds to turn the speakers on or off. I know that's rather basic, but it's been a few days and no one else has responded, so I figured we should start somewhere.
Aug 27, 2007 | Audio Players & Recorders
My Acoustic Research HTB-80 Speaker Bar stopped working after a storm. No lights/power. Is there any fuses in the unit that I should check?
if your unit come with external Adaptor power up type. then mostly is the adaptor already blown, replace the adaptor will do.
Jun 24, 2011 | Acoustic Research HTB-80 Speaker
Help----i have aw825 wireless speaker and a yamaha rx-v730--how do i connect the two?
You need to connect a stereo out from the amplifier to the transmitter for the speaker. I believe the speaker unit comes with the required adapters which will probably be rca/phono's to stereo mini-jack.
Jul 19, 2010 | Acoustic Research 900MHz Wireless Stereo...
TRANSMITTER FOR A AW811 NO LONGER WORKS.. DID WORK TOO LONG AFTER I GOT IT...HELP
did you change the distance between the two ? assuming they are plugged in, does a power light come, maybe a fuse.
Feb 05, 2010 | Acoustic Research 900MHz Wireless Stereo...
I want wireless speakers for a 25'X 30' room to connect to a stereo. would the Acoustic Research be powerfull enough. Are the two speakers truly wireless or do the need to be connected to each other
Jul 10, 2009 | Acoustic Research 900MHz Wireless Stereo...
Jan 28, 2009 | Acoustic Research 900MHz Wireless Stereo...
Wireless speakers AW872 transmitter won't power on anymore
Idhager,
I have the same set of speaker and had a similar problem. what I did was disconnent and reconnect the transceiver (sort of a reboot) and then powered everthing back up and that solved my problem.
Hope this helps
Dec 23, 2008 | Acoustic Research 900MHz Wireless Stereo...
Wireless speaker won't come on after plugging in now....
Try the adaptor that you know works in the speaker that doesn't. That will eliminate if its the adaptor or the speaker. You will need a multimeter to check if its the on /off switch or not. A quick alternative is to "bridge" out the on / off switch wiring. (Use a piece of wire to join the wires going through the switch together.)
Sep 04, 2017 | Acoustic Research 900MHz Wireless Stereo...
Acoustic Research AW825 Outdoor Wireless Speaker Logo
24 people viewed this question
Top Acoustic Research Audio Players & Recorders Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you an Acoustic Research Audio Player and Recorder Expert? Answer questions, earn points and help others
