Question about Car Audio & Video
Where is rem on a gm-3000 pioneer amp - Car Audio & Video
3 Suggested Answers
  • 19 Answers
SOURCE: i have a pioneer gm-d8400m the amp isnt working
flashing light could mean a few different things. 1- constant power may not be there. check with a test light or multimeter. should read around 12 volts. it would be a good idea to check all the power and ground leads. make sure u have a good ground. 2- bad sub. im assuming sub since its a monoblock amp. you can meter the subs. make sure the total ohm load is no less than 2 ohms. any lower the amp will go into protect mode. 3- bad amp. power supply may be bad. the newer pioneer amps are full of protection circuits. ive been a professional installer for a shop about 8 years and we sell pioneer. hope it helps.
Posted on Dec 27, 2009
thunderkiss9
SOURCE: alpine 6x9 speakers 90 watt rms.Are they compatable with a pioneer gm 3000 amp
the alpines will take every drop of power from that pioneer and smile... it will sound quite good,and if you ever want to you can actually put about 2x that much power to them 1 of those amps per 6x9 would rock
Posted on Apr 09, 2013
I need wiring for pioneer gm 3000 amp?
Here is the pinout. You need to solder your own connections.
Oct 15, 2014 | Pioneer Gm-3000t Car Amplifier
Alpine 6x9 speakers 90 watt rms.Are they compatable with a pioneer gm 3000 amp
Apr 08, 2013 | Pioneer GM-3000T Car Audio Amplifier
Can not find where to hook the rem wire on my pioneer gm-h100
This remote wire requires a switched 12 volt .This can be connected at fuse panel and or to radios remote out or power antenna wire.
Sep 22, 2011 | Car Audio & Video
W__How do i wire two pioneer GM-D9500F amps i only have two rca outputs on head unit one sub output that is being used with a D class mono amp for sub the other rca to one pioneer GM-D9500F amp but i have...
Hi, you can split the preamp RCAs with Ys available everywhere. The amp input impedance shouldn't cause much load on the head unit. Let us know if you have more questions, and thanks for using FixYa.
Jan 18, 2011 | Car Audio & Video
Where is the power switch, or how do you get the power running through to get blue light to turn on?
There is a terminal marked REM it's between the + 12 volt and Ground terminal.
The REM terminal needs a power source connected to it to turn the amp on and off. It's usually the blue remote wire coming off the head unit.
This turns the amp on when your head unit is on and turns the amp off when the head units off.
May 21, 2010 | Pioneer GM-3100T 300W 2-Channel Amplifier...
Where do I plug in my REM wire from my amp to my
on the back of your head unit is the remote arial wire. this is the one you connect to the rem on your amp
Apr 05, 2010 | Pioneer DEH-P80MP CD Player
There is no sound coming from my 15's when my stereo is on
it is Either the RCA Jacks or the Blue Remote Lead Wire is Bad or Loose in the Harness inside the Dash. Please Rate My Response! Thanks!
Feb 03, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Not working
Make sure the remote (rem) port is powered, if not take another look at your inputs from the head unit as sometimes we tend to forget the channels orientation of ground and positive left and right.
If all else fails, have an audio installation expert help you out, a pari of extra hands would be helpful too...
Dec 09, 2007 | Pioneer GM-X372 Car Audio Amplifier
No power to amp
Are you sure it has the full voltage going to both BATT and REM? sounds like the REM signal is weak.
Aug 23, 2007 | Pioneer GM-7200M Car Audio Amplifier
Car Audio & Video Logo
18 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
