SOURCE: LG Top loader not draining water to rinse and spin
YOU NEED TO CHECK THE WATER PUMP,SO LAY THE MACHINE ALL THE WAY DOWN ON ITS FRONT,NOW YOU HAVE ACCESS TO THE PUMP.Remove any debris that may be lodged inside of it.
SOURCE: LG WF S5605PP Not Rinse
hi
here the steps
Of all washing machine parts, the water pump probably takes the most punishment, because it is constantly in use. When the pump fails, you can hear or see the trouble: a loud rumbling inside the machine, or a failure of the water to drain out of the tub. Here's what you can do to fix the problem:
Step 1: Check the drain hoses to make sure they are draining properly. Remove the water supply hoses from the back of the washer. With long-nosed pliers, extract the filter screens from the valve ports in the washer or from the hoses themselves. Wash the screens thoroughly. Then replace them and reattach the hoses. If the machine still rumbles or doesn't drain, examine the pump.
Step 2: To access the pump, first bail and sponge out any water in the machine's tub. Then tip the washer over on its front, using a heavy blanket or pad to protect the washer's finish. Remove the back service panel. The pump is usually located along the bottom of the machine, but with the unit tipped on its front it's easier to remove the pump through the back than through the bottom of the washer.
Step 3: Locate the pump. It has two large hoses attached to it with spring or strap clips. If the clips are the spring type, pinch the ends of the clips together with pliers to release them, and slide the clips down the hoses. If the clips are the strap type, unscrew the metal collar to loosen the clamp. Disconnect the hoses by pulling them off the connections. If the hoses are kinked or crimped at these connections, straighten them as best you can and reconnect them. Then try the machine again to see if this kinking was causing the problem. If the machine still doesn't drain, you'll have to remove the water pump.
Step 4: To remove the pump, loosen the bolt that holds the drive belt taut and move the washer motor on the bracket to loosen the belt. Move the motor out of the way and unbolt the pump; it's usually held by two or three hex-head bolts located on the bottom of the pump housing. As you loosen the last mounting bolt, support the pump with your hand. Then lift the pump out of the washer.
Step 5: You should take the pump apart if you can, because the trouble could be lint, dirt, or pieces of cloth or paper clogging the pump impeller. Clean away all debris inside the pump and clear any debris out of the water tubes. Then reassemble the pump. Hook up the pump again and test it. If cleaning the pump doesn't put it back into working order, or if the pump housing can't be removed, replace the pump with a new one of the same kind.
Step 6: To install the new pump, set it into position and connect the mounting bolts to the pump housing. Move the motor back into position. Tighten the drive belt on the motor by prying it taut with a hammer handle or pry bar; it should give about 1/2 inch when you press on it at the center point between the two pulleys.
SOURCE: LG WF-17014PP will not rinse or spin
I have the some problem with LG type WFC 5856 TC. The motor can't turn for water
SOURCE: my LG washing machine WF-950 had stuck with
did you try little door at bottom left of machine? there is little hose in there that drains tub or haul it outside and unscrew filter.
SOURCE: when going on to rinse cycle machine keeps filling
pressure switch needs to be replaced or repaired
