Question about Frigidaire FRA052XT7 Thru-Wall/Window Air Conditioner
Did not get installation manual for mistral mss 3.3 split airconditinor
Need to know what error 6 on a minstrel air conditioner unit.Also can you scan and email me the manual for a Chunghop K 1028E 1000 1 Uinverisal remote. Thanks Gwenda
Hope this helps
error code is the fan in the head unit (indoor part) of the split system. After rining around for hours this morning - the number to get parts Mistral Bellini & Ringroup. 1300 373 199 They are based in Melbourne.
Apr 03, 2017 | Heating & Cooling
Hi I have a mistral reverse cycle a/c model MSS 15 the fan works but the air coming out is not refrigerated.
Check if your a/c unit needs cleaning dirt's sometimes causes not to cool the air. But if your unit is clean then your compressor needs to be re-charged with freon.
Nov 12, 2010 | Heating & Cooling
Mistral Air-con split system shows F6 fault! What does it mean?
F6 INDICATION MAY MEAN THAT THERE IS A PROBLEM WITH THE BLOWER MOTOR. WHEN THE BLOWER MOTOR GETS HEATED UP (WHEN ITS WINDING BECOMES WEAK) THIS MAY HAPPEN. SO U GET UR BLOWER MOTOR AND PCB BOARD CHECKED.
Nov 23, 2009 | Heating & Cooling
Low refrigerant?
never of you have no leak but if every thing is working and it is not cooling them you may need to do that...
Nov 08, 2009 | LG Art Cool LA1000PR Air Conditioner
Mistral mss15 aircon will not operate on heat setting , not sure if it is being set properly because cannot understand remote control symbols
My Mistral was working yesterday (on heat) now it won't. Just sits there as if warming up but actually blows out freezing air - on "sun" mode.
Jul 12, 2009 | Sanyo 24KS32A Cool Mini Split Air...
Need instruction manual for mistral mpac140 portable air con
They do not have a downloadable manual that I could find but I have included their contact info so you can contact them directly. They may be able to get you the info you are requesting.
http://www.mistral.com.au/contact_us/contact_us.asp
Apr 01, 2009 | Heating & Cooling
Instruction manual
Here is a link:
http://www.mistral.com.au/products/manual/BMH110.pdf
Dec 09, 2007 | Kitchen Appliances - Others
Frigidaire FRA052XT7 Thru-Wall/Window Air Conditioner Logo
26 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
