Question about Skullcandy Inkd Earbuds Black/Red
Everytime I plug them in and dont hold down the little button thing with the skull on it, they play extremely loud music and microphone feedback.
I have a peavey VIP2 amp.Can I use my acoustic/electric guitar in the electric guitar setting
You can not only play it on electric guitar setting, you can play it LOUD. Its all about what YOU do and what YOU like. Dont accept it when somebody tells you that the music you're playing doesnt sound good to them. ITS YOUR MUSIC !
Do whatever you want. And NO it wont hurt guitar or amp. Rock on or whatever it is you do.
Oct 26, 2015 | Peavey Vypyr VIP 2 40W Modeling Combo...
Logitech speaker feedback
Feedback is a sharp, loud noise that can come through the earphones of a headset unexpectedly---it occurs when the headset is getting sound (feed) from someone else speaking or playing music into a microphone. This sound can create a dangerous situation for someone who is operating expensive equipment or flying a plane at the time since it can disable hearing temporarily.
If you experience feedback often, it could also lead to serious hearing problems.
Mic Too Close to the Speaker or Volume Too High
The main cause of a feedback sound in a headset is proximity to a speaker. If a person holding a microphone on the other end gets too close to a speaker, it creates a loop of re-amplified sound that results in the loud, screeching noise. When the volume on the other party's microphone is too high, it is more vulnerable to picking up unwanted noise and feedback from speakers and sound output devices in the room. So make sure that you ask the other party to turn down the microphone to a normal level and stay far from speakers. b> Two Microphones Gathering Same Sound b> When the other party places two microphones too close to each other, it could cause feedback. When positioned toward the sound source (such as a person speaking) the microphones will both pick up the same audio and compete with each other when creating the output of sound, causing a sharp noise in your headset. This problem, called acoustic phase interference, is resolved by simply ensuring that the other party uses one microphone at a time. Poor-Quality Headset or Microphone b> One common cause of feedback is simply a poor-quality headset or microphone. Most modern headsets and microphones have noise-canceling features that manage and kill feedback before it has a chance to occur. These noise-canceling headsets are essential for pilots and aviation crew members. If you hear sudden feedback that is strong enough to hurt your ears, the headset or microphone is simply not properly equipped to actively cancel that unwanted noise before it hits your ears. Buy a higher-quality noise-canceling headset to manage the feedback noise when you're going about your tasks. Hope this helps.
Dec 23, 2012 | Logitech Z623 Speaker System
Peavey Valveking head strange feedback.
Sounds like one of your tubes going bad and becoming microphonic...
Google "Microphonic Tube" for additional info.
Oct 25, 2012 | Peavey Valveking Vk100 Guitar Head
Humming sound when I record
Sounds like it might be feedback from another source or perhaps a loose connection. Try moving the microphone away from power sources or anything that might cause feedback, such as speakers etc.
Apr 24, 2012 | Samson Meteor Mic - USB Microphone
Controller giving feedback?
If you are not using a microphone, then you are not the feedback source.
That being said, a blue-tooth headset still qualifies as a microphone, and is capable of generating feedback.
If using blue-tooth, then switch to a standard wired headset to determine if the feedback diminishes.
Regardless of headset type, be sure to have game chatter through the headset only setting as opposed to through the TV speakers, and keep the TV turned down. There will be an obvious lag between TV speaker and headset microphone which can create a feedback loop.
If other gamers can hear your TV when you are talking, then the TV output is too loud and will create feedback opportunities.
If none of the above applies, then the feedback is generated elsewhere.
Hope this helps!
Apr 22, 2012 | Microsoft Xbox 360 Wireless Controller
The internal laptop microphone above the screen is producing feedback from the speakers and everytime the volume is raised above half way the feedback starts (very loud). It's definatley the mic because...
Most likely there's a shortage with the microphone connection, or is gone. You can turn if off if you dont use it via the control panel. But if you use microphone quite often then you can buy an external mic off ebay or some place you like. They come in elegant designs as well and they are fairly cheap.
Hope this helps.
May 03, 2011 | Toshiba Computers & Internet
I have a 4 month old Dell Studio 1535 laptop, with audio problems
Firstly check that the microphone level is down or turned off as this sounds like some sort of feedback that's being produced.
Check the microphone and try to play music again.
Please post back
Good luck.
Oct 02, 2009 | Dell Studio 1535 Notebook
Logitech microphone
have you checked the settings under control panel/sounds and audio devices?
open that up click the voice taband under voice recording press the volume button, check to see if the check box has a tick in it under microphone and that the volume is turned up. try the test hardware button to test your mic and adjust the levels from within the wizard.
hope this gets you headed in the right direction
Apr 23, 2009 | Computers & Internet
HOW DO YOU CONTROL THE VOLUME ON THIS DARN THING...WHEN I PUT MY HEAD PHONES ON...THE MUSIC IS SO LOUD IT HURTS!!!!!
hold the volume button untill the speaker immage @ the top highlights red then use the << and >> pads to turn it up or down
Jul 22, 2008 | Kaser Corporation Mambo Mano Digital Media...
Skullcandy Inkd Earbuds Black/Red Logo
22 people viewed this question
Top Skullcandy Audio Players & Recorders Experts
Robert Graf
Robert Rankin
Andrew Taylor
Andrew Taylor
Are you a Skullcandy Audio Player and Recorder Expert? Answer questions, earn points and help others
