Question about Sony Ericsson Z800i Cellular Phone
Sony Ercisson 1GB memory card not reading..it is asking for formatting and when i am formatting it is cuming as formatting failed
    Genius:
  • 1,234 Answers
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Posted on Aug 27, 2010
I have a Sony Ericsson w880i and all of a sudden last night it stopped detecting my sony 1GB memory card.. How can make it detect it again without formatting it as I do not want to loose the information!
1)disconnect the battery for 5-10 min. Then replace it &try to read card's info. OR 2)Select "restore factory settings" then try to read or 3)use a memory card reader to 1st backup info into a pc then format it by the pc.
Aug 27, 2011 | SanDisk 2GB Memory Stick Micro M2 Memory...
I try to record something and it says that the memory stick is full, than I put it into my computer and it says that is blocked how can i fix that?
Although the sony card is physically the same as an sd card, and will fit in a pc slot, the memory it contains is different, and is formatted differently, thus it cannot be read by a pc, it needs to be inserted into a sony machine that can read the files on it, then you can delete them, hope this helps
Mar 25, 2011 | Sony 1GB Memory Stick PRO Duo Memory Card
Can not read the MSPro Duo Card in my newly formatted Sony VAIO VGN-CR21S I lost the webcam driver too while formatting the the HDD
go to sony.com and under support list your model number and select drivers. then look for a chipset driver for the memory stick and a webcam driver for the cam . download each and then run each driver. heres the link to enter the required info to locate the drivers you seek.
http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DRIVER
Nov 29, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
My 1GB micro SD memory card needs formatting. But, when I am formatting it fails. ?What should I do?
Try formatting it in another device such as another card reader with another PC or formatting it in a digital camera
If that doesnt work, its likely the card is dead
Jul 21, 2010 | SanDisk 1GB microSD Memory Card
No source will read my memory stick pro duo mark 2
  1. Try re-formatting your memory stick from your PSP console. A memory stick that is formatted from a PC or other hand held console sometimes cause incompatibility problem with the PSP.
  2. If your PSP still can not read the memory stick, try checking your memory stick by using your friends PSP and see if they can access the memory stick.
  3. If the memory stick can be accessed by your friends PSP then there is a problem with the memory slot of your PSP.
  4. The only way to check the contacts of the memory slot of your PSP is to disassemble you PSP and take out the mother board.
Jan 23, 2010 | Sony PlayStation Portable (PSP) Console
I cannot formate my sony 1gb memory stick pro duo when i inserted in my computer it shows it cannot use it before formate disk when i tried to formate it shows window was unable to complete the format
Windows formatting tools are not good enough to format Sony memorysticks.
You need to use special formatting tool
Download that from here:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=MSACUS40&upd_id=2860&os_id=7
If this will not be able to format your memorystick - call sony support and report that repair of memorystick is necessary. It is a hardware fault with memorystick and it needs to be repaired or replaced.
May 28, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Formate memory stick
try formating the card using a digital device such as a camera or a playstation portable (PSP)
May 17, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
1GB MicroSD card detecetd by computer as 0 memory device
Please format it. It needs to be formatted to read them.
Jan 12, 2009 | SanDisk 1GB microSD Memory Card
Sony ericsson w200i mp3 playback problem
I was facing the exact same problem with my W200i. I formatted my memory card using the "Quick Format " option and then re-uploaded my songs. That solved my problem. There is no disturbance in between songs now, also the "Playback Failed" error has also not occurred again.
Feb 10, 2008 | Sony Ericsson W200i Cellular Phone
Sony Ericsson Z800i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
