Question about Car Audio & Video
Muddy or burping sound coming from M&K V-2B subwoofer when music starts. What's wrong?
  • Wilson Wong
    Wilson Wong Oct 17, 2013
    The M&K V-2B was connected to my digital proccessor. I've checked all the cables connection & also the foam around the woofer. Everything were ok & intact. No sign of wear & tear. I suspect the driver or the voice coil are damage. Please advise.
  • 998 Answers
Bad connections and or your sub woofer has a "blown" voice coil. You will need a new speaker if the coil has blown.
Posted on Oct 18, 2013
How do I stop my Paradigm sub from humming and "burping?"
The amplifier that powers the sub is the source of your problems. Sounds like some power supply filter capacitors are failing.
Dec 31, 2014 | Paradigm Audio Players & Recorders
Won't to find out best encloser for my optsw124
bandpass box is a quick way to get a nice bass sound. First I would need to know what type of vehicle this is being installed in to come up with the corre3ct dimensions for a custom box.
Jan 05, 2013 | Lanzar Car Audio & Video
I have sylvania shtib1044p-l the big speaker lights up but no sound comes out of it, or is it that only the little speakers are the only ones that suppose to get sound n the big one is just like a desing?...
The big speaker is a subwoofer. Sound should be coming out of the subwoofer that is very low in frequency from a bass guitar or drum beats. Pop music usually has both those instruments pretty prominently. If no sound is coming out then something is wrong. It is more than just a cool design feature.
Oct 11, 2012 | Audio Players & Recorders
I just created my own pc. i decided to go against getting a sound card. My sound works coming from the mobo. I hear the music from my display moniter speakers. When i connect my headphones to the front...
You need to change the sound profile from 2 speaker system to surround sound. You will find this in the control panel area program.
Hope this helps.
Thanks
Jason
Oct 25, 2010 | Logitech X-530 Computer Speakers
I have a problem with my M&K v-2B subwoofer 120 vac 50-60 Hz, not getting good qaulity audio vocals, its real faint and when I hook up the speakers in the back the speakers aren't doing anything, not a...
Well, the subwoofer is not supposed to reproduce audio in the vocal range. It reproduces Bass frequencies. Check your set-up and connections to your satellite speakers. Based on what you have stated, this is all I can offer. Hope this helps.
Apr 06, 2010 | M&K Sound Mp Series MX-350 MK II THX...
Can the sony xplod 1000watt amp be bridged for more power to just one sub? also what problem would cause a subwoofer to make a slight burp noise whenever the car is shut off or into the non accessory...
This amplifier can only be bridged for a single subwoofer with an output rating of 380 watts bridged. The amp is not rated for 1000 watts.
The burping noise you here is the electronic switch discharging power off on the large capacitor that are used in high performance amplifiers. Regards, rcampsr
Feb 20, 2009 | Sony XM-2150GSX Car Audio Amplifier
JBL PB10 subwoofer, it makes a loud burp noise when it comes on.
In the industry - It is called "Turn-On Thump".
There are some manufacturers that eliminate components like noise filters on enry level lines to save money.
There is no way to lessen this noise without ripping the amplifier apart and having a technical knowledge of the way amplifiers work. It would involve hard-wiring a slow charge capacitor in the turn on line so it gradually builds power instead of getting it all at once.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 10, 2009 | JBL PB10 Subwoofer
No Sound for Velodyne VLF-1012
Sounds like your amp is damaged.
Jan 29, 2009 | Velodyne VLF-1012 Subwoofer
Home theatre subwoofer
Sounds like you have a loose signal lead. Check to see if this cab be tightened if not replace the cable as this could be the cause of the problem. Over time the leads/plugs do loosen especially on subs as they vibrate so much. If it's not this then it's probably something internal to which I am reluctant to advise you on looking at yourself unless you are pretty proficient with electronics :P
Nov 08, 2007 | Jensen XS-1010 Car Subwoofer
Car Audio & Video Logo
56 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
