Question about Lasko 42" Wind Curve Fresh Air Ionizer Fan With Remote Control Air Purifier
Cleaning fans cleaning my fan
How do I Open the Vorando Tower Fan to clean
Use a flashlight to look through the vents on the front. You should see screws.
Mar 24, 2014 | Frontgate Vornado Tower Circulator Fan -...
The Fan on my "Fresh
It could be getting clogged up. The lint screen has GOT to be kept clean or the machines fan will pull dust into the machine and it will cake on everything inside, including the fan(will make more sound while running) and can get into the bearings of the fan causing the problems you mention. It may also be a poor electrical connection. If you have ever OILED the motor...you'll have to clean it. It's not meant to have a lot of oil or grease on it.
Jun 10, 2011 | Ecoquest Fresh Air Air Purifier
How do we clean the fan on our Flair?
take the grill of and get a soft cloth and lubricate the center of the motor
Mar 17, 2010 | Ecoquest Flair Air Purifier
Do I need a new fan blade if I replace the fan or will the old one go back on fairly easy? Ecoquest fresh air
If you need to replace the fan motor, the fan blade can be removed by grasphing the center hub of the fan and pull the fan straight out of the purifier. I remove it every time I clean my machine, since it easy to clean it once it is removed.
Nov 21, 2009 | Ecoquest Fresh Air Air Purifier
I need to lubricate the fan. How do I get to it?
Email to miller@healthyti.com and ask for free supplemental cleaning instructions. The cleaning instructions include detailed fan removal instructions. The cleaning instructions may be beneficial as well, since proper cleaning is critical to satisfactory operation.
Aug 09, 2009 | Ecoquest Breeze AT Living Air Purifier
Fan blade broke
Remove the 4 screws on the front grill. Grasp the fan with both hands and pull the fan off. Kind of prying it out using your hands as levers works best. It may be stuck if you have never removed it for cleaning, which you should do, periodically. The new one slides on flush with the end of the shaft.
Mar 30, 2009 | Ecoquest Breeze AT Living Air Purifier
Honeywell HFD 135 FAN BLADES DIRTY
I used a can of compressed air to clean my fan blades and this did the job. I bought a 6-pack of 3M Dust Remover at Sams Club to save money. Hope this helps.
George
Dec 18, 2007 | Kaz Honeywell QuietClean HFD-135 Air...
Unit stopped smelling
Whenever you clean or replace the plate, you must also clean the contacts that touch the plate, and all supports for the contacts. Clean them with 70% or higher isopropyl alcohol and Q tips. You should also clean the ionization point with a Q tip and alcohol, remove and clean the fan and oil the fan motor front and rear with a drop or two of sewing machine oil. Replace the fan so that it is flush with the end of the shaft. Make sure that the contacts are firmly against the ozone plate when you replace it. They sometimes barely make contact and then don't work well. You can bend them enough to make them fit firmly.
Nov 06, 2007 | Ecoquest Breeze AT Living Air Purifier
Fan is not turning on
The fan motor is probably locked up. You can either put a little oil to free it up (usually a temporary fix) or better yet replace the fan motor.
Oct 26, 2007 | Ecoquest Living Air Classic Air Purifier
Air Purifiers Logo
Top Lasko Air Purifiers Experts
Tom Chichester
Vignesh
Vignesh
Level 1 Expert
Are you a Lasko Air Purifier Expert? Answer questions, earn points and help others
