Question about Fisher Price Flutterbye Dreams Swing
Swing is working but not the lights and music and i just put new batteries in
Fisher price oceans wonders cradle swing music doesn't work ; help please
try looking at the stand that holds the swing, when you put it together maybe you missed some cords that would only connect together that do not plug into the wall.
Jul 16, 2012 | Fisher Price Ocean Wonders Cradle Swing
I bought it and put new batteries in it and the music will play and i press the buttons to make it swing and it doesnt do anything. It doesnt make any noise like its trying to swing or nothing. Could that...
Graco swing motors are known for going bad, sorry. I have had no luck trying
to fix them as you tear them down and the electronics are what has gone bad.
They have a motion sensor in them along with a complicated motor to swing swivel
that if you lose a small ball that is the interface, you are doomed.
Time for a new one and if you buy one at a garage sale be sure to run it with weight in
it for at least 5 minutes. That culls out the bad motor ones!
Feb 05, 2011 | Graco Baby Gear
The Bright stars swing is not working anymore. We put in 4 new D batteries but the swing does not have the same power? What can we do?
You'll probably need to replace the motor in the swing. Most of these types of swings work off a motor with a plastic gear attached, and the inside of the gear gets worn down over time. The motor still gets power and still turns the gear, but the gear doesn't have the grip that it used to so the swing doesn't move as much (especially with a baby in it).
Feb 04, 2011 | Kids II Bright Starts Travel Swing
I bought the swing for my daughter and put new batteries in. Music works but it won't swing at all. What is wrong? I hate that I spent 60 dollars on something that doesn't work.
It's likely the motor gone bad. The contacts inside the motor can get burnt out and prevent the motor from turning. Did you buy the swing brand new, or was it used? If you bought it new you should return it for a refund.
Dec 14, 2010 | Summer Infant Just One Year Travel Swing...
I bought a G2609 cradle swing, put it together, and opened up the battery pack to put in batteries, and noticed it was corroded, does any one have a simple fix for this? I tried to clean it with alcohol,...
I presume you bought it used. If it is new and has a corroded battery compartment you should return it to where you bought it and get a new swing. You should scrape as much of the corrosion as possible off the battery contacts. Use steel wool or sandpaper to make the contacts shiny. Bend them carefully to make sure they are tight to the batteries. If the contacts are corroded to the point that they cannot be cleaned or if they break then the battery pack will have to be replaced. You may also be able to use a paste made of baking soda and water to remove some of the corrosion. If the swing does not work after the battery contacts are clean and new batteries are installed then there may be a problem in the wiring, in the switch or in the motor.
Dec 10, 2009 | Baby Gear
Swing part doesn't work
the motor could be shot, thats what happened to mine, it was an older fisher price aquarium one, and i had to buy a new one.
hope thats not whats wrong with yours, good luck
Jun 19, 2009 | Baby Gear
Baby swing......graco doesn't swing
I had the exact same problem the motor worked fine but when we took it apart the gear inside was stripped. i hate saying it but best thing you can do is buy a new swing. i personally recommend http://www.toysrus.com/product/index.jsp?productId=3420749&camp=PPC%3A204318389. its a little bit high but so worth the money. my 8mo old baby girl loves it. it also has a AC adapter so no more batteries and an ipod hook up as well so you can pick what music you want your baby to listen to. best of luck.
Mar 29, 2009 | Baby Gear
Fisher Price Nature's Touch Cradle Swing - Not Swinging
Parts for your model can be found on amazon, here:
Amazon com fisher price swing replacement parts. I hope this helped you. Best of luck
Oct 03, 2008 | Baby Gear
Fisher Price Flutterbye Dreams Swing Logo
56 people viewed this question
Top Fisher Price Baby Gear Experts
romney2012
Lyle Siemens
Lyle Siemens
Josh Whitehead
Josh Whitehead
Are you a Fisher Price Baby Gear Expert? Answer questions, earn points and help others
