Question about Epson Perfection 4990 Flatbed Scanner
Epson perfection 4990 photo scanner
When I try to scan 120 or 4X5 film (neg or pos), the scanner won't separate the images- it appears as a single scan, film holder & all. One of my 4X5 scans was split into 3 vertical 35mm size strips. The help section on how to improve film recognition didn't help. 35mm pos & neg seems to work fine. One help file said the scanner had a setting to select medium format film, but I can't find it. Also, is there intel based software so I can use my new mac? I'm using my old G3 ibook (OS10.3.2), but it's a little slow. I've called Epson support 3 times, but gave up after waiting about 30 min each time, and they haven't answered my email in a week. I'm using Epson scan software, but I see that Silverfast software is also included. Is this an alternate scan program? I've tried to use it, but it can't find the scanner. This is my first scanner, and at this point it's a lot smarter than me. I hope you can help. Thanks, Dana
  • Anonymous Mar 18, 2014
    scanned film negs have yellow line across
    Novelist:
  • 110 Answers
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Posted on Aug 22, 2008
Negative images
Check the settings and try to update the software/drivers if available from manufecturer's website. (ehteshamhusain@gmail.com)
Jul 19, 2009 | Epson Perfection 4180 Photo Flatbed...
Need a document feeder for 4990 scanner
I don't believe it is possible to add a paper feed to this scanner. The only hopper fed scanner of which I'm aware is the Kodak s1220.
Jeff Underwood 1Scan.co.uk
Feb 13, 2009 | Epson Perfection 4990 Flatbed Scanner
The scanner copies three photos as one
Assuming you're using the Epson Scan software, select Home or Professional mode and click Preview. When the preview image appears, draw a marquee around each of the three photos. (Note that as you draw each marquee the number beneath the little image of a marquee - the white square with the dotted line around it - increases.) After drawing your marquees, click the All button, then click Scan. The scanner should make three separate passes in succession, producing three separate images.
Nov 24, 2008 | Epson Perfection V200 Flatbed Scanner
Misalignment of scann after area selected
the 4990 often failed to detect automatically the film. Go manual, take the film zone, don't forget to specify it in the driver (the focus depends on it), and crop manually the picture. The result is perfect because it's yours. In many times, if the result is important to you, forget the automatisms.
Feb 24, 2008 | Epson Perfection 4990 Flatbed Scanner
4990 scanner
Nothing is wrong if your scan turns out good
Jan 22, 2008 | Epson Perfection 4990 Flatbed Scanner
Scanning slides -
Do try reinstalling the fotware this is where the trouble lies.
Or
Save the scans and in a suitable photo Editor revers the image Neg to Pos
Dec 29, 2007 | Epson Perfection 1660 Photo Flatbed...
Microsft Vista doesn't support 4990 negaives scanning
try using a third party scanning solution EPSON is known not to keep up their drivers so many third party solutions have popped up. I like one called vuescan http://www.hamrick.com/ it works for MAC and PC and is not very expensive
Jul 03, 2007 | Epson Perfection 4990 Flatbed Scanner
Scanner wont scan transparencies properly
I have the same problem with my 4990. This began when I moved to a new computer running Vista. I've updated all drivers to the latest version including Epson Scan for Vista but the only thing the 4990 "sees" is reflective documents. Negatives are not recognized at all. I know this is probably a different problem from what you are having but the effect is the same.
Apr 27, 2007 | Epson Perfection 4990 Flatbed Scanner
Film option is ghosted
try to reseat (unplug and replug the TPU cable at the back of scanner, and open epson scan go to professional mode and click on configuration button, go to OTHER tab and press reset all then restart computer and try if film is an option to select.
Jan 15, 2007 | Epson Perfection 4990 Flatbed Scanner
Epson Perfection 4990 Flatbed Scanner Logo
1,607 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
