Question about Electrolux Oxygen 3 Upright Vacuum Cleaner - EL5035 Vacuum
Electrolux vacuum model el5035 brush won't turn
dragonsthatk
  • 547 Answers
SOURCE: older electrolux canister brush will not turn used reset button
change the belt
Posted on Feb 12, 2009
  • 260 Answers
SOURCE: Brush assembly will no longer spin on carpet however the suction from the system is still good. Unit is only 5 years old.
Open and check for belt damage. Also make sre there isn't debris causing this error.
Posted on Apr 16, 2009
  • 70 Answers
SOURCE: Electrolux Lux 5500 model Canister vacuum. Need
The part # is 32749.
Posted on Jul 15, 2009
  • 21 Answers
SOURCE: Need a belt for Pronto 2 in 1 stick vacuum.
Your not gonna find a belt because the belts on these units are not designed to be replaced by the consumer and would need to go to a service station
Posted on Jul 19, 2009
  • 5 Answers
SOURCE: Electrolux model LX vacuum- Problem, ejects empty
The vacuum is doing exactly what it is suppossed to do, on this model, the bag will eject when the suction is reduced due to the pores in the bag becoming clogged by dirt, dust, or fine powder. Try a NEW bag, and **** up less superfine dust such as baby powder or plaster dust that immediately clog the bag. Next, on later model LX's on the bottom of the canister near the bag door is a dial, setting the dial to a higher number will reduce the sensitivity of this automatic bag ejection operation and will allow the vacuum to continue to run until the bag is even more clogged, however, running the vacuum with a fully clogged bag causes the motor to overheat and reduces suction and damages the vacuum. If you have an early model LX, there may have been a "basement and attic" key mounted to the bottom, but often are lost by now and it is used to make such an adjustment. The 1952 model LX was the first with the diaphram automatic bag ejection system and the problem of the bag ejecting too soon was common. An improvement on the model LXI added the control dial with numbers 1 to 6 on it to adjust the sensitivity. I am looking up more info on adjusting a model without the dial because I just picked one up at an estate sale a few days ago and I've heard (some time ago) that the early ones with no dial had a "basement and attic" key that snapped to the bottom of the cleaner to make this adjustment, not sure where it is though and the one I have does not seem to have the key. Will let you know more if I find it! Thanks, I am an Electrolux fan and will use nothing else because I have used so many vacuums but love the convenience of Electrolux design and durability. They have been in my family since my grandparents came to America and are simply the best in my opinion.
Posted on Nov 22, 2009
Electrolux Vacuum Renaissance Power head brush won't turn
if it is making a humming sound but not turning you belt is broken, if it is not check the reset switch (little res button) if that doesnt work check the connections between the cord of the powerhead and the wand, the wand and the hose, and the hose and the vacuum
give the hose itself a good look over sometimes the wires up by the grip break in the casing
Mar 12, 2014 | Electrolux Vacuums
We have two of these vacuums and both of them have experienced the same problems. First the floor heighth adjustment doesn't work and now neither one will pick up on either carpet or floor when in the...
Did you check the powerhead for obstructions? With a bend in the tube just below where the hose connects, this is a common spot for clogs. To check, detach hose and drop a coin in the hole. If it doesn't drop through, a blockage is present. Use the handle of a wooden spoon to push clog back through to brush. It can be removed with long-nose pliers from there.
For height adjustment, check for debris that may be preventing the nozzle from raising and lowering. There may be something inside the powerhead preventing it as well.
The manual can be found at the following site. On the left side of the page, under the image, click on the Use and Care Manual button.
http://www.abt.com/product/20743/Electrolux-EL5035A.html
Jan 21, 2011 | Electrolux Oxygen 3 Upright Vacuum Cleaner...
Hello! I have an Electrolux Ultralux 2000,
Sounds like the belt on the beater brush has broke.replace the belt on the beater brush.
Dec 06, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Height adjustment
You'll have to turn the upright to its side to show the sole plate where the rolling brush is. Check where the front wheels are located and ensure there is no blockage obstructing the rotary dial. Sometimes the spring mechanisms can work themselves loose.
Inevitably you'll have to remove the sole plate and/or the rotary dial which may be screwed down. If it has cracked then you may have to seek a replacement.
Dont forget to rate this suggestion.
May 25, 2008 | Electrolux Oxygen 3 Upright Vacuum Cleaner...
Electrolux Oxygen 3 Upright Vacuum Cleaner - EL5035 Vacuum Logo
20 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
