Question about PANDIGITAL PhotoLink PANSCN06
Free calibration card for panscn06 - PANDIGITAL PhotoLink PANSCN06
Why won't my Pandigital photolink scanner scan
You must install drivers. If drivers are installed, take it to repair shop on warranty
Oct 11, 2014 | PANDIGITAL PhotoLink PANSCN06
Panscn06 how do I register my product
They are out of business,from what I have read.
customerservicenumbers.com/co-pandigital
Jun 29, 2014 | PANDIGITAL Office Equipment & Supplies
Need help with a Kodak Personal scanner
Kodak is passing the buck. You would think that they could provide a calibration card for their own scanner.
Jan 02, 2014 | PANDIGITAL Office Equipment & Supplies
Calibration
Dear Sir:
1)See the attached diagram for Reed switch , clean, tigh the connector very well.
Read carefully your instruction manual for software calibration for diagnose +trouble.
If you do not have go to the next web and download for free: www. fitness. manualsonline. com
sincerely. God bless you.
Apr 19, 2012 | Bowflex Treadclimber
I installed Scan2Mac n my iMac. Mac recognizes Scanner and I can read SD card. When I select Scan to Mac - and scan - it saves to SD card and not Mac. I reinstalled and same thing happens
Are you running OSX Lion? If so, that may be the issue.
I have 2 MacBook Pros, one running Lion, one Snow Leopard.
The Scan2Mac software works fine on the Snow Leopard machine - takes only a few seconds to create image in a MBP directory.
It does not work at all on the Lion machine. Worse, the scans to the memory card take up to 2 minutes, before the scanner will process another photo.
I installed the Scan2Mac app on both machines from the same dmg.
The Pandigital website offers no updates to the software, which was created in 2009.
Aug 24, 2011 | PANDIGITAL PhotoLink PANSCN06
My scanshell 800 DXN has started scanning lines over the card image almost like there's something on the scanner eye. Is there a way to clean it?
I am very familar with the scanshell scanner you have I have repaired several of them in the past.
There really isnt anything that wrong with your scanner it just needs to be calibrated. When you purchased it there was a calibration sheet included in the box that you need to use I hope you still have it. If not go here to purchase some new sheets http://www.scanshell-store.com/accessories.htm They used to be free but when I looked at there web page they are not listed any longer. Also here is a link to a 800 manual which describes how to run the calibration process http://www.id-reader.com/ftp/applications/manual/scanshell_manual.pdf This will correct your problem and your scanner will be as good as new again.
I hope this helps you out and if it does please leave me some feedback.
Mar 29, 2011 | Card Scanning Solutions ScanShell 800DXN
Pandigital mini photo scanner pictures have white lines on them
have a pandigital scanner that worked great for about 500 pics then lines stared to show up, tried cleaning and calibrating but did not help, decided to take apart and found that the glass on the surface of the scan part was dirty, cleaned the glass and put back together works perfect, took about 10 minutes to fix
Sep 05, 2009 | PANDIGITAL PhotoLink PANSCN06
Witcolor driver - photoprint dx witcolor edition 4.6v2
how many headers do you have? do you need calib1 or calib2? is it uncalibrated vertically or horizontally? Try to upload a pic with the jetpacks test
Aug 04, 2009 | Adaptec 1PK 29160LP ULTRA160 SCSI LP PCI...
PANDIGITAL PhotoLink PANSCN06 Logo
Top PANDIGITAL Office Equipment & Supplies Experts
Mike
David Payne
David Payne
Are you a PANDIGITAL Office Equipment and Supply Expert? Answer questions, earn points and help others
