Question about Samsung RFG296HDRS
Turn the filter light off - Samsung RFG296HDRS
Diesels filter light
The sediment filter needs to be drained. There should be instructions in you owners manual or you could take back to mechanic & they will do it for yu.
Jun 22, 2012 | 2007 Toyota Quantum 2.5
How to change water filter?
Hi
Find the indication light, located at the top of the Whirlpool refrigerator just inside the door. This tells you when to change your water filter. A green light indicates the filter is good and a red light indicates you need to change the filter.
Find the filter knob. It is usually located at the base of the refrigerator in the kick plate or grill.
Turn the knob a quarter turn to the left to unlock the filter. Pull out and remove the old filter.
Add a new filter and push in. Turn the filter a quarter turn to the right to secure it in place.
Reset your filter indication light inside the refrigerator. Press down and release the switch five times within 10 seconds. The filter indication light should then turn green.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 07, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
I have a Maytag window air conditioner unit (model M6T12FSA). The 'check filter' light came on and after I cleaned the filter, the 'check filter' light remains on even after a few hours of...
Turn the unit OFF & Unplug it. Remove the filter and reinstall it, being sure that it's installed properly. Particularly, which way the plastic filter frame is facing when installed.
Plug the unit back in and turn it ON. Hopefully, the electronics now will accept the filter being properly in place.
Hope this helps and thanks for choosing FixYa.
Jul 25, 2011 | Maytag Heating & Cooling
I'm using whirlpool mastermind chrome split ac.. clean filter light started blinking so i cleaned and replaced the filters but still CLEAN FILTER light is blinking. please give a solution
If you didn't turn the Master ON/OFF Switch to OFF, before removing the filter. That is the problem. To clear the error message. Turn the Master ON/OFF Switch to OFF, unplug the unit, remove the filter and reinstall it. Wait 10 minutes, plug the unit back in, turn the Master ON/OFF Switch to ON. The controls should have reset themselves and the clean filter light should not appear.
Hope this helped you solve the problem. Please let me know. Thanks.
Jun 12, 2011 | Whirlpool ACC108PS Air Conditioner
Where is the filter located in the refrigerator?
1. Find the indication light, located at the top of the Whirlpool refrigerator just inside the door. This tells you when to change your water filter. A green light indicates the filter is good and a red light indicates you need to change the filter.
2. Find the filter knob. It is usually located at the base of the refrigerator in the kick plate or grill
3. Turn the knob a quarter turn to the left to unlock the filter. Pull out and remove the old filter.
4. Add a new filter and push in. Turn the filter a quarter turn to the right to secure it in place.
5. Reset your filter indication light inside the refrigerator. Press down and release the switch five times within 10 seconds. The filter indication light should then turn green.
Jan 03, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Have replaced the water filter - how do i reset/turn off the "change filter" light ?
Press and hold the "Reset Filter" button until the indicator lights go off if your model refrigerator has a "Reset Filter" button on the control panel.
  • Step 4 Hold the "Lock" and "Light" buttons on the control panel until the filter indicator lights turn off if your model refrigerator does not have a "Reset Filter" button. For models that do not have a "Light" button, press and hold the "Lock" and "Water" buttons.
  • May 18, 2010 | Maytag MZD2766GES Side by Side...
    Turn off the change filter light on maytag refrigerator
    For my Maytag Refrigerator Model # MSD 2756 GE, I had to hold the "Light" & "Lock/Unlock" buttons simultaneously until the "Change Filter" light went off instead of the "Water" & "Lock/Unlock" buttons.
    Oct 09, 2009 | Maytag MSD2651 HE Side by Side...
    HOW TO TURN OFF THE "CHANGE WATER FILTER LIGHT"
    Press light and lock and hold until light blinks release and the light will go out
    May 02, 2009 | Maytag Refrigerators
    How do I turn off the "change water filter light" on the door? I just changed the filter
    Hold the lock and light buttons in together for 3 secs. or so and the light will go out! You don't even need to change the filter to do this.
    May 02, 2009 | Maytag MSD2732GR Side by Side Refrigerator
    Press the ?filter? button to turn off the indicator light !!!
    Try pressing and hold the filter button for about 15 seconds. See if this works for you. If I can help further, I am here......Eric Campion
    Feb 26, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
    Samsung RFG296HDRS Logo
    15 people viewed this question
    Top Samsung Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
