Question about Kenmore 75085 Air Conditioner
Fan is running the compressor want kick on to cool the air zenith zw6500r
  • 236 Answers
SOURCE: Kenmore compressor cycles and does not cool
It sounds like you have a stuck compressor or bad start capacitor.
Stargazer
Posted on Mar 16, 2008
  • 327 Answers
SOURCE: Kenmore 596.73502201 Not cooling. Compressor , fan, seal ok
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Posted on Dec 19, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Freezer works Refrigerator will not cool down
The compressor should be OK this time because you caught it in time. But if the condenser fan stops you need to consider replacing the fan. I have had refrigerators do fine until the fan motor warms up and you are away, it stops. Don't think you should use the refrigerator until the fan is fixed. Sea Breeze
Posted on Apr 22, 2009
  • 233 Answers
SOURCE: Kenmore room air cond fan runs, no cool. checked
if the fan motor is on but the compressor is not : if the compressor has correct voltage up to the terminals and is not operating, the compressor is bad, if ther is not power to the terminals, the start components may be the culprit, if there is no power to the start componenets then the controller is the issue.
Posted on Jul 19, 2009
SOURCE: cooling fan does not work Compressor does whats wrong?
does the fan spin freely by hand? if not, the shaft ends that ride in the bushings need to be cleaned and lightly reoiled. i have fixed many a dehumidifier this way
Posted on Aug 20, 2009
Where do i put the freon in the zenith ZW6500R
Your uncertainty suggests this task is best left to a professional.
Aug 14, 2014 | Zenith ZW6500R 6,000 BTU WINDOW AIR...
Where can i buy freon for ZW6500R Zenith window unit. 66012
Freon is no longer used for window AC units. You need R142a refrigerant gas. Most auto supply stores and even Walmart carries it. However, having the gas is one thing. Having all the proper equipment to evacuate and recharge your compressor is another. Please be careful. It's best left to the pros.
Jun 30, 2011 | Heating & Cooling
I have a zenith AC model ZW6500R, It was installed one year ago, It simply dosen't blow cool air anymore. Any info would be very much appreciated. Thanks ...
Generally after one hard summer these units need servicing especially if it is running in a dusty area. Check the filter in the front and if possible, pull the unit out of the case and check the inside of the rear coil (located behind the motor fan blade) The coil is probably stopped up and the unit is overheating and not able to cool properly. You may be able to shine a flashlight through the side of the unit and see if the coil is dirty.
Apr 09, 2011 | LG ZW6500R Air Conditioner
Compressor appears to kick in, runs for short time
It sounds like your unit may have a bad run capacitor or start capacitor and relay. Low voltage will also cause this problem. First you need to make sure that you have the full rated voltages at the unit, if you do, then, have the run and start capacitors checked out and the start relay.
May 31, 2010 | Dometic Rooftop RV Air Conditioner
Zenith window a/c compressor keeps turning on an
Your compressor has an electrical protector that is heat activated. It will disengage the compressor under several scenarios. Most likely the unit filter is dirty or the unit has lost refrigerant. Also assure that the unit has adequate electricity supply,no extention cords or undersized wiring.
Jul 09, 2009 | Amcor NanoMax A12000E Portable Air...
Air conditioner is not blowing cool air, but fan still blows
check the compressor with the ac running and make sure the compressor is kicking in and out in not the compressor might be bad or te clutch on te front of te compressor, sometimes u can get to much freon in them to i did it ounce
May 30, 2009 | 1998 Cadillac Eldorado
Compressor not kicking on
What type of thermostat are you using? When was the last time it worked ? Do you just get fan on cool mode, or does fan only run on fan mode?
Aug 08, 2008 | Dometic Rooftop RV Air Conditioner
Kenmore 75085 Air Conditioner Logo
13 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
