Question about Sky I Blade Mini IR Helicopter W/ Remote Control
How do u sync the remote control and the helicopter
Skygiant rchelicopter when i sync it and then give it throttle all the lights on the helicopter syart flashing red and it dosent do anything
I bought 2 off brand ,of the same remote controlled Helicopters which cost about $30.00 each. The controller has A_B_C setting helicopter has none, You can set them up any way, either all on one or separate channels per controller which is channel A.
1st turn off Helicopter switch to off and controller off .
Set controller -1 to channel C , , then (controller-1 ) throttle knob to max, turn power on to controller -1 , throttle down and up 3 cycles and left and right 3 cycles
Turn on Helicopter 1 with controller -1 still on, it should work on channel C
Jun 11, 2014 | Team International Hawk Talon V3 RC Indoor...
Stunt copter won't sync
I presume you have lights & sound on the controller when you turn it on - fourteen quick beeps and then a different toned fifteenth beep. The screen lights (blue). Insert the battery (lettering facing up toward the helo fuselage unitl it's seated all the way - an LED inside the fuselage, visible from behind, quick flashes and then begins a slower blinking.
Once the helo battery is inserted, turn on the controller, which starts the aforementioned beeping. On the last controller beep the helo's LED will stay lighted, indicating the helo & controller are synched.
I had a problem making sure the battery was inserted all the way into the helicopter. You'll know it's inserted properly when the LED inside the helo flashes.
Dec 26, 2012 | Brookstone Stunt Copter RC Helicopter
Hi, the issue I am facing is that my remote is not able to connect to the helicopter. Earlier when I used to put the battery the light used to blink, now as soon as I switch on the remote it just does...
Helicopter should be powered off when charging. After fully charged (charging light as bright as it gets) and given 10 minutes to cool after charging, turn on helicopter first and place on level surface, this allows gyroscopes to sync up. Then, after making sure the main rotor control (left joystick) is all the way down, turn on controller, and quickly push left joystick all the way up (just until the blades move) and back down. This will link them. Also, make sure the antenna is still wrapped around the landing strut and not contacting any metal on the craft. And of course, good batteries in the remote, and ALWAYS let helicopter battery cool for 10 minutes after charging AND after flying. Also, NEVER fully drain battery, as soon as you cannot maintain altitude, land and power off. Fully discharging a Li/Po battery will weaken it severely, and sometimes kill it.
Please let me know if this helps, I love Syma helicopters, but they can be tricky sometimes...
r
Sep 04, 2011 | SYMA Toys industrial Syma S032 Ready to...
I have an Air wolf UJ371 helicopter made by UJ toys. I was just wondering what is the purpose of the tiny LED light on the printed circuit board. Why does it flash when I first turn it on? What is it...
Paul,
That light is the gyro-sync indicator. It flashes briefly when you power on as a reminder to set the helicopter on a stable, level surface. Once the on board gyroscopes sync-up and set the "normal" head orientation, the light stops flashing and the helicopter will accept control signals from the remote.
Hope I've helped,
PvT
Jun 15, 2011 | SYMA Toys industrial SYMA S009 Micro...
The helicopter syma s032 not fly, noy function, not syncronize with the remote control. This charging for 90 minutes and the battery of the remote control is new. The helicopter light led is good, to...
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
This should get you flying. Let me know.
hope this helps,
r
Dec 28, 2010 | SYMA Toys industrial Syma S032 Ready to...
My s032 remote does not respond unless it is right next to the helicopter there is no throttle control or directional control somtimes it will start but then shutdowns unless you put the controller right...
Did you, by chance mess with the antenna? It's is the wire that came wrapped around one of the landing skids. It must remain like this, and ideally not in contact with too much metal. Also, on my s032 I've noticed that even indoors and at close range, the antenna on the remote should be extended fully. Is the helicopter charged fully?
Charging/Remote linking:
4) Power on remote.
As a safety mechanism, remote disables itself if throttle is engaged at all when remote is turned on. Turn remote off, pull left joystick (throttle) all the way down, then try again.
hope this helps,
r
The helicopter will not synchronize and I can't get it to communicate with the remote.
Press the throttle up and and back down and hold down a few times, sometimes it help to move left right knobs also. Try on each channel to get it synced
Dec 25, 2010 | Team International Hawk Talon V3 RC Indoor...
I have 3 s107 and I it says 3 channel on the box and the transmitter says A B C but will only let me select 2 of them. What's the trick on flying 3 at the same time?
Mine's exactly the same as yours. Although the transmitter shows A B C the switch has only two positions, so there's a choice of two only. I doubt it's possible to fly 3 at the same time.
Nov 08, 2010 | SYMA Toys industrial New Syma S107 Radio...
Sky I Blade Mini IR Helicopter W/ Remote Control Logo
27 people viewed this question
Top Sky Toys Experts
NOEL
NOEL
matt
matt
Are you a Sky Toy Expert? Answer questions, earn points and help others
