Question about Myron & Davis Car Audio & Video
I have a AD-370A dvd disc receiver and V1/V2 headrest monitors. Was also a piece in the trunk. do not have it. What was it?
2 Suggested Answers
  • 149 Answers
SOURCE: Connecting headrest monitors to Kenwood DDX-6019
Youll have to run sets of cables from your head unit to the seats, youll prob only need video, power, and ground if the sound will come from your speakers. For the same display on either monitor run to first position then link the 2 monitors.
Posted on May 10, 2008
Headrest monitor says no video. I have 10 inch power connect headrest monitor/DVD player. One plays DVD and the other is a monitor. The DVD player headrest plays movies but the monitor screen is blue and...
Those cables can go bad easily. If you have a meter and know how to use it, try to test continuity on each pin. If that isnt the answer, then either the input of second monitor is faulty, or output of main screen.
Jan 05, 2015 | Car Audio & Video
How to install jvc kw-av70bt
Hello I am installing a JVC- kw-av71bt to 2 audiovox headrest monitors. can you tell me the easiest way to run the rca cables from the headunit to the monitors.
Apr 14, 2012 | JVC KW-AV70BT DVD receiver
I have a 370A steamer but have lost the two pieces
Hi there, SmartAlec from NelsonVacuums.com.au here. If you are in Australia i can certainly help you. We are a platinum electrolux agent so if you put in a request via our website we'll be able to sort it out no problem.
Happy Vacuuming
Feb 20, 2010 | Electrolux Envirosteamer 370A Canister...
Headrest built-in DVd with disc stuck...help
Look for a small hole under or on the side door assembly, if found use a paper clip or other thin metal straight object and insert into hole this will release the disc clamper and open the door.
Nov 25, 2009 | Televison & Video
Harmony 880 does not change input with Onkyo HT-R520 amplifier
You will either have to use your Onkyo remote to teach the Harmony those functions or try one of the similar model receivers in the Harmony software. I had to chose a similar DVD player in the list in order to get my Harmony to play nice with my DVD player.
Feb 14, 2009 | Logitech Harmony 880 LCD Remote Control
Installation of headrest dvd
yes the screen has to sandwich the material from the headrest to hold it in place.....
Oct 10, 2008 | 2006 Audi A8
Dvd hook up
Depending on what leads you have and what connections your equipment has depends on how you would wire it up for a basic setup you need a set of three male to male rca a leads consisting of a RED WHITE and Yellow plugs at each end. Now on the back of your dvd player there should be three female holes the same colou as your plugs and near those holes it should say input plug the leads colour to colour now the other ends of the lead plug into the section of your amp thats says dvd input with the same style holes as the dvd player. then you need to run another cable the same as you have just used to take the sound and picture to the tv you start of plugging one end into the amp where it says monitor or tv out and then at the other end of the lead will plug into the tv in A/V1 or A/V2 if the A/V1 is being used for a video player or camcorder Yellow is Picture Red is Right Sound Channel And White is Left Sound Channel so only plud the matching colours to each other or you will end up no better off hopefully this helped if you get stuck my email is warneatbribie@hotmail.com
Mar 23, 2008 | Pioneer VSX-108
Video output issues
this is probably a problem of the relays - yes, there are small relays inside to switch the video in/output.
In this case i think the contacts are the problem. you cant open the relays, so they have to be replaced...
better solution: use a better videostandard such as component or hdmi - do not use the receiver to switch the videosignals, use only for sound...
mfg
Feb 01, 2008 | Onkyo TX-DS595 Receiver
VIZUALOGIC Headrest monitor
press menu, under the sub menu turn the parking off
Jan 07, 2008 | TMI Products Vizualogic Headrest Pair...
Car Audio & Video Logo
21 people viewed this question
Top Myron & Davis Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Joe Ball
Joe Ball
Are you a Myron & Davis Car Audio and Video Expert? Answer questions, earn points and help others
