Question about Seagate Barracuda 7200.7 40 GB Hard Drive
The disk in drive D: is not accessible
Local Disk(D:) is not accessible Access is denied
  • uniyal Dec 08, 2007
    I have 80 GB Hitachi IDE Desktop HDD. when i connect it with External HDD USB CASING when i want to access it showing access is denied.
  • Anonymous Dec 27, 2007
    when i put in a disk for the dvd drive, it does not read it. when i try to open the drive under "my computer" a dialogue box opens saying access is denied.
I had a similar problem.... but since it was on an extra portable hard drive so i backed up the entire data on it and went in for a full format that got me rid of this problem.... this peoblem came to me after norton discovered a virus on my drive and in order to remove that it deleted a couple of files maybe in that process i lost a couple of files required for dbl click access to the drive(though i was able to access the drive through explore in the rt click menu)......anyway format solved it so go in for that....
or run a virus scan
or i found another way on microsoft site try it maybe it ll help...not too complicated.... http://support.microsoft.com/kb/307874/
good luck.....
Posted on Nov 23, 2007
    Scholar:
  • 151 Answers
Unplug your harddisk and plug it again.
Posted on Sep 25, 2007
2 Suggested Answers
SOURCE:
babb
  • 104 Answers
SOURCE: The hard disk in drive D: is not accessible
Well this message can be two things(if not more) One of them being that the disk has security set and you wil need to change those settings if you want access to the drive the other scenario being that a program has locked the disk for exclusive access. Assuming you are using Windows XP. To check the security go to the properties of the disk then click on security(Tf the security tab isn't there, Open my computer then click Tools->Folder Options then the View Tab. Scroll to the bottom/last option then uncheck Use Simple File-Sharing press OK/Apply) Now back to Properties of the disk then Click the security tab. You'll need to try this first and tell me what's there, or if u got any error message etc. My explanation might be to long if i try to explain every possibility. regards, babb
Posted on Sep 27, 2007
If access is denied, right click on the drive and set administrator rights to gain access.
Oct 10, 2015 | Computers & Internet
In my system have c,d, e, and f drives.i can access c,d,e and but i can't access the f drive..while accessing my f drive ''f: drive is not accessible''.access denied.but it appeare in local disk manag on...
just format the drive and check . After that if the drive not opened then go to disk manager and delete that drive and again creat the drive then check
Jun 08, 2009 | Computers & Internet
Hope I can help you with your problem. If your hard drive was installed to be used as D: in your old computer then you will have to set it up to be D: in the new computer. This may be why it is not being recognized. You can do this by connecting it as a slave on the primary IDE cable.
Also you will need to check the jumper on the hard drive to make sure it is set in the slave position.
Dec 03, 2008 | Maxtor Hard Drive
"Access is Denied"
you need a file called takeownership which when run installed to the reg it gives you the option of taking ownership removing that anoying Access Denied screen.
google for it I did and it works a treat.
good luck
Jul 07, 2008 | Computers & Internet
My Toshiba lap top when i try and copy pictures to a disc it will not let me it says D:/is not accessable.incorrect function
I also tried downloading pictures from a cd and it would not read it though it did read a pdf file for documents on another disc
Mar 02, 2008 | Samsung Super-WriteMaster SE-S164L DVD?RW...
first u have format the c:drive the problem is solved
if not u should format all over the system
Feb 20, 2008 | Computers & Internet
I recently had this problem. Whenever I clicked on any of the drives a window appeared with warning which said drive not accessible. Access is denied. Previously I thought that it is a virus which has edited my registry and is not allowing me to enter or even view my content. So I formatted the whole system but that didn't help. Now I am sharing this with you.
  1. Open My Computer. Goto Tools>Options. Goto View Tab Pane. Uncheck the last Option in the Advanced Setting which says Use simple file sharing(Recommended). Apply the setting.
  2. Open the properties window of the drive you are unable to access.Goto Security tab pane.
  3. Goto Advanced.
  4. Now click on the Owner tab pane.
  5. It's very rare that the ownership of the drive changes. But it happens once in a while.
  6. So if you are the user say Admin then select Admin(ComputerName\Administrator).
  7. Click on the box which says Replace owner on subcontainers and objects and click over Ok.
  8. Apply the changes.
  9. Now you should be able to access the drive.
Feb 18, 2008 | Samsung (SP0822N) 80 GB Hard Drive
Sep 26, 2007 | Seagate Barracuda 7200.7 40 GB Hard Drive
Seagate Barracuda 7200.7 40 GB Hard Drive Logo
258 people viewed this question
Top Seagate Computers & Internet Experts
Ekse
Alun Cox
Argospete
Argospete
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
