Question about Dell Dimension Computers & Internet
When I turn on my Dell DM061 (Windows Vista) Desktop the Microsoft Windows loading screen doesn't load properly and immediately goes to Startup Repair- which says it can't fix the problem. Before this started happening (when I was able to login in and use it) A random blue screen with a lot of writing about my memory? (RAM) quickly appeared and then my computer would restart. It won't enter safe mode when I press F8 on boot. I've tried Memory Diagnostics Test, Hard drive Test and a disk check -(chkdsk c: /R chkdsk /p fixboot c: bootrec.exe /fixmbr) in the Command Prompt. But each time I restart my computer, Startup Repair still pops up and I cannot login. I don't own a Windows Vista CD to try and recover my hard drive.
    Top Expert:
  • Dell Master
  • 45,628 Answers
All these symptoms can be from ram stick fault, graphic card or graphic section of the mother board or a failing hard drive
you will probably have to have it properly diagnosed by a computer repair shop to find out exactly the failing component
Posted on Mar 25, 2017
SOURCE: After loading Window service pack 3 update, comes up blue screen
i think theres a spyware or u have to repair ur windows
Posted on Sep 23, 2008
Nic61
  • 1073 Answers
SOURCE: vista goes blue and restart after unnistalling intel turbo memory
I'm afraid that the only way is to reinstal Vista. If you recive a message that says that Vista arent capeble to repait it self ther is no other way. I Guess that the instalation of the driver for Intel Turbo Memory messed up Vista pretty good and uninstal it dosent help. You will always have bad file system on Vista. Better then to star from the begining with a fresh reinstal.
Good luck
Posted on Dec 03, 2008
  • 565 Answers
SOURCE: Dell E310, XP2 Home Edition
Its mostly because of bad hardware or wrong drivers try to reinstall win dows with clean drivers if it doesnt help. then its problem with some hardware like memory or hdd. if u need drivers u can find them here
If it was helpful rate fixya
Posted on Dec 27, 2008
  • 186 Answers
SOURCE: Can't factory restore dell inspiron 531 (windows xp).
You might want to try going into setup and setting your boot drive options to DVD drive as your 1st, HD as 2nd and Floppy as 3rd. Put your windows disk in the DVD before boot and run the program from DVD.
Posted on Jun 23, 2009
SOURCE: Can't System Restrore Dell Inspiron 531.
This can usally be sorted by inserting your Dell windows OS restore disc & choosing the repair option.
T61 won't go past the Microsoft loading screen
Press F8 during boot, and load Safe Mode. A program may be preventing a proper startup.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig > Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running.
This just disables them in startup. Programs will still load, but when you initiate.
Oct 01, 2012 | IBM Lenovo ThinkPad T61 Notebook
File: \Windows\system32\ntkrnlpa.exe. status: 0xc0000098 windows failed to load and no recovery disk
Running the Windows Memory Diagnostic Tool
If Startup Repair is unable to get your system running again, and if neither System Restore nor Windows Complete PC Restore has returned your computer to a condition of reliable health, consider the possibility that you have failing memory. To test this hypothesis, click Windows Memory Diagnostic Tool in the Startup Recovery Options menu. The Windows Memory Diagnostic Tool will ask whether you want to restart now and check for problems (the recommended option) or check instead on your next startup. Because you're having trouble getting to that next startup, you presumably want the first option. For more information on this you can refer the link below.
Make system repairs from the Windows Recovery Environment
http://windows.microsoft.com/en-US/windows-vista/Make-system-repairs-from-the-Windows-Recovery-Environment-from-Windows-Vista-Inside-Out
Run check disk command from Windows Recovery environment to fix bad sector on your hard drive
a) Insert the Vista DVD, and boot from the DVD.
b) As you want to boot the computer from the Windows Vista DVD, you need to press a key, on your keyboard when you see the prompt. You should now see a black screen with a white status bar at the bottom stating Windows is loading files.... After a while, the status bar will turn completely white and you will see a screen stating that Windows is loading. The Windows Setup environment will continue to load and when finished you will be presented with a screen that prompts you for information about your location and language.
c) At this screen you should configure the Language to install, Time and currency format, and Keyboard or input method options so that they are set correctly. When done, press the Next button. You will now be at the main Windows Vista setup screen where you would normally install Vista on to a computer.
d) As we want to repair the computer, you should click on the Repair your computer option. This will bring you to a new screen where the repair process will look for all Windows Vista installations on your computer. When done you will be presented with the System Recovery Options dialog box
e) Select the Vista installation you would like to repair
f) From the system recovery options, choose command prompt and enter the command chkdsk /r.
For both the above steps you can refer the link mentioned below.
http://windowshelp.microsoft.com/Windows/en-US/Help/95b4c03a-ac42-49a4-a90d-8f3736a995271033.mspx
Jun 13, 2011 | Dell Computers & Internet
DELL INSPIRON 1525 NOTEBOOK : HELP !! my dell inspiron 1525 notebook will not start windows. the battery is fully charged and when i press the power button a black screen comes up and it says : "windows...
This sounds like the dreaded Windows Vista Black Screen of Death (KSOD). you might have a bad hard drive, but even more likely some software or a driver is causing a problem and caused Vista to get stuck. The repair will not work. You might be able to run a complete repair from the Windows Vista CD, if you have one. If you are not too experienced, take it to a reputable computer service center. If you are at all technical and have time, google your problem and you will see thousands of similar users with same problems.
This is one reason Microsoft released Windows 7 so soon.
Feb 16, 2010 | Dell Inspiron 1525 Notebook
Startup screen goes black except for the cursor
Get a new OS Installer, I suggest you take Windows 7
Oct 18, 2009 | Dell Inspiron 6000 Notebook
Dell inspiron 1525 notebook will not start windows
Usually this happens when the vista boot loader fails. During boot up, keep tapping F8 and then select Disable Automatic Restart... and get the stop error code which usually starts with 0x
Jun 09, 2009 | Dell Inspiron 1525 Notebook
Dell wont load icons or nothing
HI ^^
use tune up utilities 2008
and let it search and repear your pc problems am sure you will resolve this
plz rate it fixya ^^
Jun 08, 2009 | Dell Microsoft Windows XP Home Edition
Cant get to windows
Is it XP or Vista? I would load the recovery cd and attempt a repair( not an install).
Sep 06, 2008 | Dell Dimension C521 PC Desktop
Computers & Internet Logo
51 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
