Question about Ricoh Aficio 1035 Copier
Richo 1232c Color Calibration is off
I installed a new cartridge in my Richo 1232C and now it will not calenrate correctly. A test pattern produces colors in staggered patterns-not on top of one another.
Please help.
  • 313 Answers
This can sometimes be caused by two or three faults fist take out the transfer unit and check the roller a the exit side if this is dirty the id sensors cannot get a good reading back to do the alignment.. next try taking the id sensor out.. this is fairly easy first remove the fuser unit.. then open up the drum/dev cover plate. then if you look in from the fuser side you will see the id sensor plate has two srews to hold it in place remove these and the id sensor has a small connector at the bottom take this off and the unit can be taken out open the shutter on the unit and clean the sensors...do this carefully with a soft clothe.. when you put the units back in go into the sp mides and to service mode 5. then sp 5-993 line adjustment you will need to execute a couple of times to reset.print out the test sheet in 5-995 do the dot pattern on an A3. you can make fine adjustments through the sp modes ...if this is a little too beyond your abilities try the easy option and go into user tools accessed with the 123 button at top left and then maintenance auto calibration and then colour registration you may get a failed come up on the screen if this happens then the above method ie the long way will have to eb carried out..
Posted on Jun 15, 2009
Ricoh 1232c sc 672
The correct way to get into service mode is to first press the Yellow "CLEAR" button then press the numbers 1 >0>7 then press and hold the Red "STOP" button.... Good Luck
Jun 08, 2012 | Ricoh Aficio 1232C Color Copier
I want to empty my used toner bottle on a Richo Aficio 1232C. Where is this located? Is there any particular sequence to the changing? Robert
you study this copier.If you are not have user guide you collect it by ricoh copier support webside.
Thanks
Tareq Bin Mostaq
Bangladesh.
Aug 13, 2011 | Ricoh Aficio 1232C Color Copier
How to remove drum unit for ricoh aficio 1232c.
Attached is an image of the page from the service manual on how to remove the PCU.
Mar 21, 2011 | Ricoh Aficio 1232C Color Copier
Ricoh Aficio 1232C rpcs When I try to print the red light appears on the printer saying 'load by pass tray' even though I have selected Auto tray. Normally the machine prints fine.
when you selected auto tray was that in the driver or microsoft settings ? microsoft settings will overide the copier settings driver. look under file then page setup to see what it is set for.
May 20, 2010 | Ricoh Aficio 1232C Color Copier
Ricoh Aficio 1232c REFILL
You can't use any other brand of color toner to refill the AF1232, you'll have all kinds of issues. They do have compatible toners (generic) for that model but highly recommend OEM.
Mar 31, 2010 | Ricoh Aficio 1232C Color Copier
Ricoh 1232c scan to email SSL issue
no work around for machine. you can scan to a folder on the network, than attach your doc to an email. only way to do it on a ssl.
Mar 24, 2010 | Ricoh Aficio 1232C Color Copier
Ricoh Aficio 1232C prints with red-violet tone
download the RPCS driver from the Ricoh support site and then when you will install the driver go to preference then user settings and adjust the contrast and other options until you get the color of the printed image as you wish to be
Dec 14, 2009 | Ricoh Aficio 1232C Color Copier
Ricoh Aficio 1035 Copier Logo
302 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
