GE 28300EE1 Logo
Posted on Apr 24, 2009
I can not register - GE 28300EE1
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on May 13, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1120
Points
Go to menu and under phone settings, select REGISTRATION. and when it tries to look for the base, press and hold the page button, and voila, the phone is registered to the base.
Looking t0 register my fire stick
How do you register a fire stick?
You can also view or change the account your device is registered to from the Settings menu:
  • Open Settings from the Home screen.
  • Go to My Account. If your device isn't registered, you'll see a Register option on this screen. Select Register and enter your Amazon account information when prompted.
Amazon.com Help: Register or Deregister Your Amazon Fire
https://www.amazon.com/gp/help/customer/display.html?nodeId=201452550Search for: How do you register a fire stick? register my fire stick Google Search
tip
Pairing a BlueRay remote to your PS3
Register Bluetooth® Device Register a Bluetooth®-compatible device with the system.
Registering a BD remote control
1. Prepare the BD remote control.
2. Select "Accessory Settings" under "Settings" in the home menu.
3. Select [Register Bluetooth® Device].
4. Select [Register BD Remote Control].
Only one BD remote control can be registered at any given time. If you register another BD remote control, information on the currently registered device will be overwritten.
5. Follow the on-screen instructions to register the BD remote control.
When the registration (pairing) is complete, a controller number is assigned.
tip
How to Register DLL files
On Microsoft Window's operating systems, a DLL stands for Dynamic Link Library. DLL's are relatively small files that include a library of functions- usually data that can be shared across multiple applications. DLL's are called upon by various applications and can be loaded and utilized by these applications concurrently.
Registering a DLL
There are two easy ways that a DLL can be registered in your Window's operating system's registry, the first is the simplest, known as self registering files, the second way is to manually register a DLL.
Self Registering Files
It should be noted that many DLL files are self registering, they include information required to store themselves in the operating system's registry. As the name states, self registering files require no human intervention. Self registering files will automatically store themselves on your machine and become accessible when needed. Besides DLL files, other types of files that are sometimes self registering include .EXE and .OCX.
Manually Register Files
The second method used to register DLL files on your computer is via manual registration. Manually registering a DLL file is quite simple and can be done in only a few steps.
1. The first step is turn on your computer, launching your Window's operating system.
2. Once your Window's operating system has loaded completely, click on Start and then click on Run.
4. Once the command is input into the Run field correctly, press Enter.
5. Once the DLL has been registered, you should receive a confirmation in the form of a pop up box. This message will list your newly registered DLL file and confirm that is was successfully registered into the registry.
on Aug 28, 2010 • Computers & Internet
My V-TECH CS6229-3 phone base does not register the base phone but i can change another phone on this three phone set and it is registered and the phone
Is the handset you are trying to register de-registered? if not it will not register to another base until it is.first de-registered.
To de-register the handset do the following-
With a charged battery in the handset Enter *331734# then without pause Press and Release the Menu Select Button. You will hear a Beep. Handset would then be De-registered..
Then place the handset on the Main Base cradle and follow the instruction that come up on the handset display.if the handset still does not register then most likely the base memory is full and will have to be re-set .
To re-reset the Base:- Remove any handset from the main base cradle. Then Press and Hold the Locator or find HS or handset Locator button until the IN USE light comes on and begin to flash then release it and immediately with out pause press and release it again. That will re-set the base memory. All your handset will then be de-registered and will to be re-registered. Place each handset to be re-registered on the Main Base cradle and follow the instructions on the the handset display and they will register.
3helpful
3answers
How to program a royal 210DX register
how do I reset the GT on my Royal 210dx cash register?
I want register my number
Register what number with whom? www.register.com is for registering domain names.
1053helpful
12answers
How do i link up a playstation 3 dvd remote
Registering a BD remote control 1.
2.
Select in_peripheral.gif (Accessory Settings) under in_setting.gif (Settings) in the home menu.
3.
4.
5.
I want to register my linkssys 10/100 Etherfast PCI adapter
you can register your linksys product by two methods
1 register your self on linksys then register your product
2 call linksys customer care and ask them to register your product
From here to register your self then register your product
Click here to Register
on the same register your account page you can see right side top corner to register product after register your account press that link to register your product
and here is the linksys customer care number to register your product
this is a us number
(800) 326-7114
if you live any other country so tell me i can provide you linksys customer care number for your country
if you think my answer is helpful for your query so rate my answer
Regards
manish
Unable to register
The website is good. Access it through blackanddecker.com. There it will prompt you for membership so you will exist in their system, and you can then register the product.
Dec 27, 2008 • Drills
Top GE Computers & Internet Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
