Question about Klutz Gotcha Gadgets
Gotcha gadget Door alarm lights up, but has no sound ?
Hazard lights flashing and alarm sounding. How do I stop these?
Every car brand and model has its procedure to stop the flashing light and alarm sounding.
But still the common procedure is Make sure boot and bonnet are closed properly.
It can also be a switch, but check your alarm by locking yourself inside the car, and then press the close button on the key 2 times repeatedly until the lock control on the door doesn't make anything. Then open the door by pushing the lever or open the hood . If the horn sounds and the lights blink your alarm is ok , if only the lights blink you should take it to dealer. You can stop the hazard lights and horn sound by pressing the unlock button on the key.
May 12, 2016 | Cars & Trucks
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Sunfire alarm sounding for no reason
Focusing on switches: Start with the door switches. Pull the fuse for the dome lights. Reset the alarm. Does it sound off? The alarm feeds off the dome light fuse. Driver door is first: Often they wear out first and give us grief like this. Unscrew and disconnect the switch first. Replace the fuse. Carefully close the door so you don't loose the wire in the frame(attach a string to it so you can fish it back out if it falls in). Reset the alarm. Does it sound off or not? If it does, it is other than the switch or the passenger door switch (if a 2 door or 2 other passenger switches if a 4 door). Repeat process until the switch is found or all are eliminated. Switches are cheap, so replacing them will not break the bank. Disconnect the fuse again, unscrew the bad switch. Unplug it. Plug in the new. Screw it back in place. Reconnect the fuse and try it again. Repeat as needed until you have either found it or just limited your search area. Most often you will stumble upon it- chaffed wires, look plugs, bad switches). Yes, there is more, but I see this as the usual suspect. If you go back into the alarm, disconnect the alarm first, then observe the dome lights with the fuse in. It just may be a faulty control in the alarm, which is out of my territory. Let us know what you find, but start with the smallest things first. Good Luck!
Mar 31, 2014 | 2001 Pontiac Sunfire
Today was the first time that when I turned the car off an "alarm" went off until I closed the door. I have only had the car for one month and this is the first that this has happened.
the "alarm" goes off if the key is in the ignition and the door is open..take the key out first......then open door.you have a car that is bristling with gadgets youve yet to find.....and they are not in the book like .....put key in door and unlock/hold key over......what happens..???
Aug 17, 2010 | 2004 Volkswagen Beetle
2002 PT Cruiser inside alarm
its probably the key alarm the lock cylinder may need to be replaced
Jan 24, 2010 | 2002 Chrysler PT Cruiser
Alarm sounds when you open the drivers door...
Most likely a bad ground switch in the head light switch.
Alarm will not go off
Answer
Gotcha, let's put it into valet/service mode,
and try to reset the alarm to default mode.
Look under the dash area for a button or, a toggle
switch. When you locate it, turn on the ignition
key, press and hold in the button (little
spring loaded micro button, red or black possibly)
until the alarm chirps 1 time. This should over ride
the system, and only the keyless entry part,
if installed, would still be operating.
The LED (light emiting diode) light in the dash
should also go on solid.
At this point. the alarm would have reset.
If this had a starter kill relay installed,
it would now be opened, and the engine would
turn over when tried.
You would repeat these steps to go back to
user mode to see if this was corrected.
Let me know if it works for yours.
ALARMTEK
INSTALLSUPPORT.COM
Nov 07, 2009 | 1995 Chevrolet Lumina
GE Side by Side Refrigerator
Door Alarm -
To set the alarm, press this pad until the indicator light comes on.
This alarm will sound if either door is open for more than 3 minutes.
The light goes out and the beeping stops when you close the door.
Jun 01, 2008 | GE PSS26MGS Side by Side Refrigerator
Klutz Gotcha Gadgets Logo
205 people viewed this question
Top Klutz Home Experts
Donni Steen
Tom Chichester
Are you a Klutz Home Expert? Answer questions, earn points and help others
